RE: Norvel Engine FAQ
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Norvel Engine FAQ Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Norvel Engine FAQ - 6/13/2006 5:02:44 AM
stillbrandon
Status: offline
can anyone tell me where I can find a norvel .074 ? Please e-mail me at stillbrandon@aol.com I have looked everywhere and can't find one.. Quan don't have any.. thanks so much.. Brandon..
(in reply to bogateer)
       Post #: 101
RE: Norvel Engine FAQ - 6/21/2006 1:18:29 AM
chad500_0
Status: offline
Why does Norvell say not to use a syringe with black rubber as a fueling tool?
chad
(in reply to stillbrandon)
       Post #: 102
RE: Norvel Engine FAQ - 6/21/2006 2:48:27 AM
Bipe Flyer
Status: offline
Regular rubber breaks down in glow fuel. Silicone doesn't.
_____________________________
1/2A all the way!
Club Saito #151
(in reply to chad500_0)
       Post #: 103
RE: Norvel Engine FAQ - 6/22/2006 11:09:23 PM
chad500_0
Status: offline
Is this harmful to the engine?
(in reply to Bipe Flyer)
       Post #: 104
RE: Norvel Engine FAQ - 6/23/2006 12:51:22 AM
Andrew
Status: offline
quote:
ORIGINAL: chad500_0
Not to the engine, per se. NORVEL contends that minute amounts of dissolved rubber would be deposited on the glow element, causing poor performance. The ignition process in glow engines is started with an external power source to heat the element, but the element remains hot in part due to a catalytic reaction between platinum in the element and methyl alcohol vapor. If the element becomes coated, it can reduce the amount of surface area of the element that comes into contact with the methyl alcohol and reduce generated element heat.
Is this true?? I don't know -- I had used a Sullivan fuel bulb for years without problems or so I thought. Perhaps the Sullivan rubber was not as prone to breaking down.
However, I now use an all nylon syringe for fueling -- just to be safe (bought it from NORVEL -- maybe I'm another victim of marketing strategy). Even with a nylon syringe, I have noticed some of my NORVEL plug elements seem to grow a gray fur!!!
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
       Post #: 105
RE: Norvel Engine FAQ - 6/30/2006 9:29:47 AM
chad500_0
Status: offline
All,
I just nose-dived my AT-6 into the ground and the carb broke off at the body of the engine (Norvell .061 R/C). Is there a way to repair it? Can I weld or glue it back together or is it better to order a new carb? The engine was running great and I want to keep it running that way. (I know that running it into the ground is not a good way to prolong it's life.)
chad
(in reply to Andrew)
       Post #: 106
RE: Norvel Engine FAQ - 6/30/2006 10:54:38 AM
SGC
Status: online
Chad,
Best bet is a new carby or carb body, failing being able to locate one I only know of 2 options to repair yours.
First the carb must be dismanted and thougholy cleaned - boil it it dish detergent and water, then thougoly wash with alcahol. then------
1/ Braze it together useing the low temp aluminium(zinc) rods useing LPG torch or
2/ glue it together useing the original slow set "Araldite"
maybe superglue will work too, not sure how it stands being in contact with nitro fuels
Stewart
       Post #: 107
RE: Norvel Engine FAQ - 6/30/2006 11:53:10 AM
rrragmanliam
Status: offline
Chad,
Clean it. JB Weld it. Cheap, simple!
Darren
       Post #: 108
RE: Norvel Engine FAQ - 6/30/2006 1:27:15 PM
Andrew
Status: offline
quote:
ORIGINAL: rrragmanliam
Yep! Just make sure all mating parts are absolutely oil free -- a good cleaning with acetone will work well.
You might find a replacement on-line, but parts are pretty scarce now. Since SIG dropped their dealer network pricing, buying directly through them is very expensive.
the "other" andrew
(in reply to rrragmanliam)
       Post #: 109
RE: Norvel Engine FAQ - 7/3/2006 12:02:25 AM
andrew66
Status: offline
this is a question possibly a little off topic, but i was wondering just how much noise these little engines make (norvel big mig .061)
the reason im asking, is the club i fly at only has one undisturbed night to fly per week, b/c of the dirtbike track right beside it. there is a nice open field about the size of a soccer field and was wondering if a .061 would make too much noise and irritate anyone living in that area?
an audio clip or video would help alot.
thanx,
andrew66
cheers to old buggers! they paved the way for us.
       Post #: 110
RE: Norvel Engine FAQ - 7/7/2006 5:14:40 AM
bogateer
Status: offline
I have an AME .061 that'll go in something someday...hopefully soon (well...it might just be a 1/2A Pathfinder). Never having done so just how does one run a pressure tap off the muffler? Never flown an external tank before. I noticed the tap on the muffler was much larger than the line they give you with the engine. What am I missing?
Rob
(in reply to andrew66)
       Post #: 111
RE: Norvel Engine FAQ - 7/7/2006 5:23:31 AM
D Bronk
Status: offline
Pressure line goes to a brass tube that sits inside at Top of tank. Fuel Feed is on a Clunk/weight on the bottom of tank and runs to Carb..use the fuel feed line,that goes to carb to fill the Tank..Pretty simple..Ideal tank location is , Center of tank, at the height of carb fuel inlet.
Dave B. ------ Corsair Brotherhood # 11-------
I am a,#11,cause,,I`m 10% Better,than a perfect "10".
       Post #: 112
RE: Norvel Engine FAQ - 7/7/2006 6:44:34 AM
AndyW
Status: offline
quote:
ORIGINAL: andrew66
this is a question possibly a little off topic, but i was wondering just how much noise these little engines make (Norvel big mig .061)
thanx,
andrew66
Andrew,
Unlike 1/2As of the past, the newer offerings do give you a muffler that is fairly effective. Still 1/2As run at relatively high RPMs, 18K as opposed to 8K for a .40, for instance and it's not the decibels that the neighbours find annoying, it's the pitch. We are designed, by the miracle of evolution, to respond to higher frequencies in the environment. As in the higher pitched wail of a baby gets a mother's attention real quick. Or the higher pitched meow of baby kittens or yip of puppies etc.
You can get them real quiet but this takes a lathe and some FlyQuiet tubing. I typically install a bolt on header to my Norvels and install FlyQuiet tubing as per the Low Stik below. What you get is a muffler with huge volume, which helps but what really does the trick is to install a baffle inside the tubing portion, about halfway. This really helps.
The best set up is much longer tubing with the baffle adjusted to create a tuned pipe effect. You get a boost of power about 500 RPM and a very quiet airplane. Cumbersome but it works well on my Tsunami.
Orrr, you could just fly at the site in question and see what happens. I fly my now Brodak powered Low Stik at the local park and so far, despite the conventional muffler, no one has complained and the park is quite a busy place.
Well, RCU won't let me download any pics right now. I'll sign off and maybe try again tomorrow.
< Message edited by 1705493-AndyW -- 7/7/2006 6:45:42 AM >
Andy Woitowicz
       Post #: 113
RE: Norvel Engine FAQ - 7/7/2006 1:49:14 PM
Wayne C
Status: offline
Not to mention the buzzing of stinging and biting insects.
Do norvels absolutely need pressure or is it just an added bonus?
Sticks and tissue and real light glue, a couple of good rubber bands and whew!!
(in reply to AndyW)
       Post #: 114
RE: Norvel Engine FAQ - 7/7/2006 2:52:40 PM
