mglavin
CA, USA Status: offline
quote:
- As we understand it, the problem is specific to the control signal voltage level and is only an issue when two Hitec digitals are ganged together on one channel of a Futaba PCM reciever which pulls the control voltage below a threshold on the V1.04 servos. Is this correct? Test we ran here at home with an early release v1.04 5955TG required sinking current (0.35 milliamp). This causes the sink voltage on a Futaba R149DP receiver to be about 0.45 volts (two servos on a 'Y' would be about 0.9 volts). The switching threshold on the 5955 was about 0.75 volts. So it's easy to see why they won't work on the 'Y'. For comparison, the Hitec analog 945 and the Futaba digital 9451 servos have little or no current sink requirement and the pulse sink voltage is zero in both cases on an R149DP quote:
-Since this is a control signal issue, and it has nothing to do with battery voltage, it should show itself on the bench if the problem exists. Correct? Yes. quote:
- A person using the V1.04 digitals on seperate channels of the Futaba PCM receiver would have no reason to send in the servos unless he planned to gang two of the servos on one channel in the future. Please confirm if you agree. Yes and no. I believe it’s prudent to update v1.04 servos when used with Futaba’s R149DP (the R148DP output is about the same) marginal pulse sinking could be considered a weak link in the control circuit IMO. quote:
- One fellow who had the update done by Hitec Service referred to it as changing out a resistor. To be honest, hand soldering on a surface mount PC board concerns some of us. Can you confirm if that what is involved with the update? Or do they replace the board? Yes, a resistor value has been updated and in fact a resistor is replaced. I would worry not about a hand soldered and attended solder joint verses a machine solder joint. SMT = surface mount technology. The procedure for attaching resistors in either circumstance is the same no special procedures are in play for resistors, SMD’s (surface mount devices) on the other hand and multi-layer boards are another story. In its broadest interpretation, SMT keeps components-and their interconnecting leads-on one PC-board surface, rather than feeding the component leads through the circuit board.
_____________________________
Michael Glavin RCU Community Moderator Hitec * Multiplex Field Representative
