wkevinm
AB, CANADA Status: offline
Hi I am making a quickee from scratch and would like opinions on the following moments: Fuselage Firewall to Wing LE 4" Firewall to end of tail - 34 3/8" Firewall to hingeline on V tail - 32 5/8" widepoint of fuselage - 12 3/4" High point of fuse / wing - 8 3/8" Wing Wing chord - 9.63" Span = 52" Airfoil - NACA 66-012 Engine - Nelson Q40, back plate mount What is the CG range for a 66-012 airfoil, my guess is 3 1/2 (36%) to 4"(41%) from LE but an earlier post suggests 2.75 - 3"? Any comments would help, I will be racing in the CPPRA (Canadian Prairie Pylon Racing Association) rules are slightly different than the AMA (wing thick, wide and high points). Thanks for your support, Kevin Moorehouse
