HELP! How do you replace a Rotor Head Core?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> HELP! How do you replace a Rotor Head Core?
Page: [1]
Login
HELP! How do you replace a Rotor Head Core? - 1/11/2006 3:18:56 PM
mukes1
Status: offline
I recently flew my Dragonfly #4 helicopter, but the Rotor Head Core snapped from the flybar area to the main rotor head. I've been trying to remove the Rotor Head core (Part # HM-004-Z-14), but have been unsuccessful. I have removed the Flybar, but I am not sure on how to remove the Rotor Head code. Is it connected to the Guiding Ring by a small metal pin? It looks like it is, I'm not sure how to remove the metal pin. I was hoping it would be easy. can you give me instructions or point me to someone that can help. Do you know where to get these parts? thanks!
       Post #: 1
RE: HELP! How do you replace a Rotor Head Core? - 3/29/2006 10:57:36 PM
parsec
Status: offline
Did you find out how to do this ? - I'm in the same position now!
_____________________________
There are 10 kinds of people in the world - Those who understand binary and those who don't
(in reply to mukes1)
       Post #: 2
RE: HELP! How do you replace a Rotor Head Core? - 3/30/2006 7:13:08 AM
g13b
Status: offline
you should be able just to pull it out with pilers, or tap it out a bit then pull it.
I was stuck tyring to take it off a while ago, but i just didnt see the small allen keys that hold the stablizer bar in place
(in reply to parsec)
       Post #: 3
RE: HELP! How do you replace a Rotor Head Core? - 3/30/2006 2:08:27 PM
parsec
Status: offline
Thanks for that - I wans't sure if the little rod was threaded or could just be pulled out.
(in reply to g13b)
       Post #: 4
RE: HELP! How do you replace a Rotor Head Core? - 3/30/2006 5:29:45 PM
credence
Status: offline
The flybar is held in using grub screws. The main rotorhead mast is held in by a shear pin. You need to use something pointy to push it out a bit and then use pliers to pull it out the rest of the way. Then the head should just slide off. For future reference, i'd suggest changing that shear pin to one that's a bit larger. I believe it's the same stuff they use for the pushrods. Atleast thats what I used to replace mine and it worked fine. If you make it long enough that you can just grip it with some needle nose pliers then it makes removing the head alot easier.
Daniel
True Northern Hobbies, Inc.
       Post #: 5
RE: HELP! How do you replace a Rotor Head Core? - 3/30/2006 11:22:56 PM
parsec
Status: offline
Thanks for the help everybody - removed successfully! - for a cheap little model these things seem to be put together quite well!
(in reply to credence)
       Post #: 6
RE: HELP! How do you replace a Rotor Head Core? - 3/2/2008 8:25:10 PM
hotrodtool
Status: offline
theres a pin that you pull to remove it.once the pin is removed rotor head core will pull off with some efert.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.420RCU1
