Irvine 52 Questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Irvine 52 Questions
Page: [1]
Login
Irvine 52 Questions - 1/19/2002 10:04:01 AM
SINYFLY
Status: offline
Just got a brand new Irvine 53 engine. For some reason, mine did not come
in with instructions. Usually instructions give some suggestions for needle
settings, fuel type and break in suggestions. So my questions are:
1- How many turns should the needle valve be. I hate guessing.
2- I have FAI, 5% and 10% fuel. Which one should I use. What Oil content
3- Should I run it in in the air or run a few tanks on the ground?
4- I have a 11x4 top flite and 12x6 APC prop. Which should I use first?
Or should I go to the hobby store and get a different kind.
Thanks in advance!
Phil
       Post #: 1
Irvine 52 Questions - 1/19/2002 10:13:33 PM
ChuckAuger
Status: offline
The instructions say 1 3/4 turns out on the main needle, and adjust from there.
Mine have always been right on the money as they came.
(As a side note, I have some Irvine 25's that I bought for Combat..they were mounted on the plane, started and flew with no running in at all...one of them I NEVER touched either needle!! That is the first time that ever happened.)
The instructions say to use anything from FAI to 15% depending on the style of flying, with 20% oil.
I use Powermaster 10% in mine with fine results.
The instructions say to run the engine for short periods of 2~3 minutes with cooling periods in between, and a needle setting that is just slightly richer than peak (do not run this engine in a rich, four-stroke for break-in!) and to do the run-in at full throttle.
There are as many different methods for break-in as there are engines, this is what the instructions for this engine say.
Either of those props will run on this engine..the prop selection has a lot to do with the type of plane the engine is mounted in.
I use an APC 12.25 X 3.75 and APC 12X4 props as my favorites on a SE.
_____________________________
Breaking the Speed of Sound, Straight Down!
(in reply to SINYFLY)
       Post #: 2
Thanks - 1/19/2002 10:41:07 PM
SINYFLY
Status: offline
Chuck thanks for the reply.
Phil
       Post #: 3
No problem... - 1/20/2002 7:48:16 AM
ChuckAuger
Status: offline
If you would like the entire set of papers that came with an Irvine 53, just e-mail me your address and I'll mail them to you.
       Post #: 4
Irvine 52 Questions - 1/22/2002 10:57:15 PM
SwampFlier-RCU
Status: offline
I might be wrong, but did you check between the foam and the cardboard top of the box?
When I (hurriedly and excitedly) oppened the box of my .53 I noritced that there were no instructions...
Luckily when showing off to some buddies the foam pried away from the top of the box and voilá there were the instrucions
Best Regards,
Patrick
       Post #: 5
where? - 1/22/2002 11:34:04 PM
eness76-RCU
Status: offline
where did you guys get your .53s? Sig's price seems a little steep for a .53? Thanks,
Eric
       Post #: 6
Irvine 52 Questions - 1/23/2002 1:11:03 AM
SMALLFLY-
Status: offline
Just engines in london is the cheapest I have seen.
I have purchased 2 there, around 100 dollars and shipping is about 10 bucks. got it 3 days after ordering
       Post #: 7
thanks guys - 1/23/2002 2:44:35 AM
eness76-RCU
Status: offline
thanks for the help small, mine is on the way. Hey Chuck, I too am mounting one in a Somethin Extra, how well does the irvine perform in this application? I've heard good things.
       Post #: 8
Irvine 52 Questions - 1/23/2002 4:16:32 AM
SwampFlier-RCU
Status: offline
I hope the Euro doesn't mess a good thing up but the Irvine .53 at around US$100 is a good deal... you can get them at:
[url]www.justengines.unseen.org[/url]
Bye
Patrick
       Post #: 9
Thanks! - 1/23/2002 5:19:09 AM
SINYFLY
Status: offline
I bought the engine from justengines and the total cost delivered to New York was $107.
I checked the box and, no, the instructions were not in the top.
Phil
       Post #: 10
eness76... - 1/23/2002 7:45:49 AM
ChuckAuger
Status: offline
I think it is about the perfect engine for this plane...even with the stock muffler I think it would be great, but the UT muffler/12.25 X 3.75 APC combo is gonna be hard to beat IMHO.
       Post #: 11
just one more question - 1/23/2002 8:53:36 AM
eness76-RCU
Status: offline
Chuck, thanks for all the great info, but if I could ask you just one more question......Where can I get an Ultra Thrust muffler? do they have a webpage? Thanks again,
Eric
       Post #: 12
Right here... - 1/23/2002 9:17:56 AM
ChuckAuger
Status: offline
http://www.pspec.com/
Click on the UT Muffler tab..the OS 46 is the one I use...seems like they are both the same (SF & FX), ask Dave.
My 53 turned the 12.25 X 3.75 14,700RPM on 10% fuel..15.5K on the 12X4. That was when it was being broken in..I haven't tached it since then.
       Post #: 13
Irvine 52 Questions - 1/23/2002 5:13:58 PM
J. Peek
Status: offline
Just to clear something up, the reason the price you see from Sig is high is because Sig is the US distributor for Irvine, and since they only discount to authorized distributors (i.e. hobby shops), they will only quote/publish the full LIST price. There are discounted Irvine prices from many hobby shops in the US. That said, though, as others have said, the folks at Just Engines are great to do business with.
Joe
       Post #: 14
Sig SE and Irvine .53 - 1/23/2002 8:38:40 PM
Steve
Status: offline
I am also running a Sig SE with a Irvine .53 on an APC 12.25 X 3.75 prop and I can do a verticle take-off out of my hand. Running Sig 15% champion fuel.
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
