what .40 for aerialphoto?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> what .40 for aerialphoto? Page: [1]
Login
what .40 for aerialphoto? - 1/12/2006 4:40:59 PM
youngpilot
Status: offline
i want to build a spad i can use a .40 engine for aerial pics let me know a good one.
_____________________________
Tolerate no unclenliness of body, cloths or habitation.
-Bejamine Franklin
       Post #: 1
RE: what .40 for aerialphoto? - 1/12/2006 4:48:20 PM
CGRetired
Status: offline
Anything that is smooth with lots of wing area and a great glide slope with great stability. The Debonaire seems to be a floater.
DS.
Skylark 70 - OS 75 AX; Venus II - OS 1.20 AX; Tiger 120 - OS 1.20 AX; Protege - OS .75 AX. Airtronics - Spektrum. AMA 705964. Semper Paratus!
(in reply to youngpilot)
       Post #: 2
RE: what .40 for aerialphoto? - 1/12/2006 5:54:27 PM
bkdavy
Status: offline
I use a Debonair with the RNAF wing, no dihedral, with an OS 46 LA for aerial video. With the RNAF wing its definitely a floater.
Brad
(in reply to CGRetired)
       Post #: 3
RE: what .40 for aerialphoto? - 1/12/2006 6:47:33 PM
Villa
Status: offline
A pusher engine Canard as a photo platform will keep the exhaust out of the camera. Unfortunately mine uses an OS .46 FX engine.
(in reply to bkdavy)
       Post #: 4
RE: what .40 for aerialphoto? - 1/12/2006 9:29:23 PM
Spadinator
Status: offline
You might take a look at the Coro cub on the Spadworld web site. It's a great flying plane for a .40.
SPAD repair .....Zip ties, CA, duct tape....back in the air in ten minutes
(in reply to Villa)
       Post #: 5
RE: what .40 for aerialphoto? - 1/13/2006 2:59:31 AM
THoffman550
Status: offline
What kind of camera do you guys use and how do you trigger the shutter?
(in reply to Spadinator)
       Post #: 6
RE: what .40 for aerialphoto? - 1/13/2006 4:54:39 AM
youngpilot
Status: offline
thanks i am looking into all of your ideas. i think i might try the cub but that looks like a tricky one to build
-Bejamine Franklin
(in reply to THoffman550)
       Post #: 7
RE: what .40 for aerialphoto? - 1/13/2006 5:09:17 PM
Spadinator
Status: offline
quote:
ORIGINAL: THoffman550
I bought a 20 buck vivitar camera from wal-mart so that if I destroy it i'm not out much. I crashed by coro cub and have not rebuilt it yet so I haven't done a trigger yet. I am planning on just using a servo on the l/g channel. I am going to use an external battery source on the USB cable....the camera won't shut off on it's own with usb power.
       Post #: 8
RE: what .40 for aerialphoto? - 3/18/2006 7:45:33 PM
Mitty
Status: offline
I know what debonair.But what is RNAF wing?
quote:
ORIGINAL: bkdavy
Brad
http://aviaportal.net is biggest online community of avitors.
       Post #: 9
RE: what .40 for aerialphoto? - 3/19/2006 12:53:55 AM
MrGreenSpeed
Status: offline
RNAF is a flat bottom wing.
It uses 4mil on the bottom, with the flutes span wise, the top is 2mil flutes cord wise.
With a single spar made from yardsticks.
One of the best coro wing designs out there.
Jeff
(in reply to Mitty)
       Post #: 10
RE: what .40 for aerialphoto? - 3/19/2006 4:14:56 AM
Mitty
Status: offline
Any references to a building manual of some sort or plans or how-to ?
Thank you for the info!
Mitty
quote:
ORIGINAL: MrGreenSpeed
Jeff
(in reply to MrGreenSpeed)
       Post #: 11
RE: what .40 for aerialphoto? - 3/20/2006 3:51:08 PM
Spadinator
Status: offline
This LINK shows how the build the RNAF wing for the DPS. The same principal applies to all RNAF wings dihedral or not.
(in reply to Mitty)
       Post #: 12
RE: what .40 for aerialphoto? - 3/21/2006 2:51:34 AM
Pa-18cub150
Status: offline
I have been thinking of making a spad camera ship also but the oil issue was a concern.
I hadn’t considered a pusher. My answer was a twin with a center pod like a P38 or OV10. I think I will consider the pusher idea as there would be only one engine.
How are you guys dampening vibration? I have some friends trying to shoot video on balsa models but the vibration is to much.
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
       Post #: 13
RE: what .40 for aerialphoto? - 4/5/2006 9:57:03 PM
smokehole
Status: offline
The royal thai airforce used a single pusher trainer made from a bronco with an air research stuck in the cargo bay. Skymasters were also converted to single pushers with a 750 hp pusher turbo. Almost double the power with a 2+ meter nose ext. It no longer looks liks VW bus with props and wings but very sleek. Not everyone likes VW buses. Anyway both have ample noses where lots of gear could fit with vibe isolation and protection.
(in reply to Pa-18cub150)
       Post #: 14
RE: what .40 for aerialphoto? - 5/4/2006 6:07:38 PM
smokehole
Status: offline
Hi mister Pa-18,
I was just looking around on some Ruskie sites and saw what would be a very interesting and suitable candidate. The yak-58. Low hershey bar wing with rear engine, nice naca type cowl, twin boom, high tail and an ample 6 pass gondola, as they call it. 3view at www.yak.ru/PIC/VIEWS/58.gif. Looks quite spadable. It has the good old 9cyl radial that all the little yaks use. It reminds one of the Adam500? All Russian aircraft are built to take a beating, Yak-58 does not appear to be an exception.
(in reply to smokehole)
