RE: what is "pattern" flying
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Black Magic VF3 Nearly finished
Seller:  cmoore806
Details:   $2,100.00   |  11/8/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> RE: what is "pattern" flying
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: what is "pattern" flying - 11/9/2006 9:59 PM
RICMOD5634
Score: 100
Last Login: 11/22/2009
Status: offline
Hi all; I'd like to get veiws as to weather this is considered a patteren or 3D aeroplane. Wt 5.5lbs/span 59"/Saito 82a. Pic showes max throw avalibble, but I have it at Low rate 25%, 15% expo -- and High rate 50%, 60% expo. Just getting into aerobatics and lean towards patteren, but would like to leard to hover and harrier.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"DUTY" "HONOR" "COUNTRY"
U.S.Army=Ft. Knox KY 65,Korea 66/67,Viet Nam 67/68,Ft. Bragg N.C.(ABN) 68/69 Viet Nam 69/70
Hide Signatures
(in reply to bkelly)
       Post #: 26
RE: what is "pattern" flying - 11/10/2006 4:33 AM
firebld
Score: 100
Last Login: 1/13/2009
Status: offline
my 2cent opinion is more towards 3D then a pattern plane. I have See Bee & Imagine 50 which lean more toward pattern. anyway edge 540 can just do about any routine precisely in the right hand...
good luck...
Hide Signatures
(in reply to RICMOD5634)
       Post #: 27
RE: what is "pattern" flying - 12/12/2006 4:49 AM
protectedpilot
Score: 100
Last Login: 8/31/2009
Status: offline
quote:
ORIGINAL: Eric.Henderson
"If it has wings, I'll fly it"
At this point, it should be mentioned that a landing, actually on the runway, is also a required maneuver. (Just picking, Eric!)
Brian
Hide Signatures
(in reply to Eric.Henderson)
       Post #: 28
RE: what is "pattern" flying - 1/12/2007 4:34 AM
AIRDEL
Score: 100
Last Login: 11/6/2009
Status: offline
This thread has most of the info I've been looking for!! After seeing this I will definately hang on to my Jester and Lucky Fly. Are these 2 decent pattern planes or not? Hope so. Also would these be adequate 2nd planes or 3rd. Got my feet wet last year but going to jump in head first this year!
Thank
Del
Life is full of ups and downs, Hopefully the downs aren't permanent!!
Hide Signatures
(in reply to protectedpilot)
       Post #: 29
RE: what is "pattern" flying - 1/12/2007 9:05 AM
Robbidos
Score: 100
Last Login: 11/9/2009
Status: offline
I'm looking to get into Pattern flying. I have an UltraSport 1000 w/Saito 1.50GK. 79.5" wingspan and I have to weigh it to make sure I am under the limit. I have modified the tail feathers to be a bit larger than a stock US. Would this be a good plane to get started with or should I purchase something else to begin with? I'm just getting back into flying and I'm refreshing with a H9 Ultra Stick 40 with a Saito FA-80 on it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Robbidos -- 1/12/2007 9:06 AM >
- Robert Beaubien
- Sun Valley Fliers
Hide Signatures
(in reply to AIRDEL)
       Post #: 30
RE: what is "pattern" flying - 1/12/2007 10:08 AM
perttime
Score: 100
Last Login: 11/16/2009
Status: offline
quote:
ORIGINAL: Robbidos
I'm looking to get into Pattern flying. I have an UltraSport 1000 w/Saito 1.50GK. 79.5" wingspan ... Would this be a good plane to get started with or should I purchase something else to begin with?
There is no reason why you could not practice with your plane. Not sure what rules exactly are applied in the lower level competition classes in your area, or how strictly they are applied.
If you can fly a straight line and do a loop, roll and stall turn with your plane, go and practice to make them perfect.
Hide Signatures
(in reply to Robbidos)
       Post #: 31
RE: what is "pattern" flying - 2/4/2007 3:53 AM
sparky925
Score: 100
Last Login: 9/28/2009
Status: offline
Ultra Sport is a fine plane to start with...
The AMA patern says under 11 lbs, and under 2 meters long, and under 2 meters in wing span...BUT..
I believe that if you show up at a contest to fly with that plane, you will be fine..
Patern is fun, you compete against your self in that you want to fly to what you percieve is the best of you ability!!
sure there are others you are flying against, BUIT 1st and foremost fly to suit yourself!!
just my opinion!!
< Message edited by sparky925 -- 2/4/2007 3:54 AM >
Do it high, Do it low, just do it!!
Hide Signatures
(in reply to perttime)
       Post #: 32
RE: what is "pattern" flying - 2/6/2007 3:16 AM
greengoose
Score: 100
Last Login: 11/18/2009
Status: offline
Pattern flyers make smooth passes!
Hide Signatures
(in reply to Kruzer)
       Post #: 33
RE: what is "pattern" flying - 2/22/2007 7:51 PM
randy10926
Score: 100
Last Login: 11/20/2009
Status: offline
The winspan of the ultra sport 1000 is over the 2M limit. Most CDs will allow this for the sportsman or beginner class. I sure do at my contest. We allow up to 26 pounds in sportsman. We are trying to let people fly what they have; so they can see if they like pattern. Personally I get a little worried about safety issues if someone is flying something bigger than 26 pounds and is just learning aerobatics.
Fly Safe and Straight
Hide Signatures
(in reply to greengoose)
       Post #: 34
RE: what is "pattern" flying - 2/22/2007 7:59 PM
Robbidos
Score: 100
Status: offline
Another question. What do you use to weigh your planes?
- Robert Beaubien
- Sun Valley Fliers
Hide Signatures
(in reply to randy10926)
       Post #: 35
RE: what is "pattern" flying - 2/22/2007 8:09 PM
randy10926
Score: 100
Status: offline
At most local contest we use the trust the flyer to tell us the weight and look at the plane. At the National Contest they use a digital gram scale set to 5kg or a balance the plane with a 5 kg certified weight.
For myself I use a fishing scale to get the ball park and go to the UPS store or the Post Office. My pattern flyers have their own digital gram scale. The worry at a 2 gram difference in the wing masses.
Hide Signatures
       Post #: 36
RE: what is "pattern" flying - 2/22/2007 8:12 PM
Robbidos
Score: 100
Status: offline
Well I was considering purchasing said digital gram scale. I find I often have need to weigh stuff < 30 lbs and need more accuracy than the difference between me and me w/item on human scale. :-)
Any recommendations?
- Robert Beaubien
- Sun Valley Fliers
Hide Signatures
       Post #: 37
RE: what is "pattern" flying - 2/22/2007 8:34 PM
Anthony-RCU
Score: 100
Status: offline
Check any search engine. Had good experience with old will knott scales (website is same no spaces). Reasonable digital with a 15lb capacity and many others.
< Message edited by Anthony-RCU -- 2/22/2007 8:39 PM >
Anthony Romano
Team Airtronics
Hide Signatures
       Post #: 38
RE: what is "pattern" flying - 3/8/2007 3:55 AM
overbored77
Score: 100
Status: offline
For anyone who has never seen a pattern ship with an experienced pattern pilot flying it, I highly reccomend getting out to a field to watch it. I was still being instructed when I saw a team JR pilot do the FAI sequence, I was so impressed 9 minutes of the smoothest flying I have ever seen. I am now building a tiger 60 to the specs of our veteran pattern pilot so maybe I can try my hand at precision aerobatics.
Chris Murphy
WildHare Extra 260,Focus II,QQ Yak, tigerII, Tiger60, Ice Point, Reactor, Futaba 9C, OS ENGINES. Power HD
Hide Signatures
(in reply to psookdee)
       Post #: 39
RE: what is "pattern" flying - 3/11/2007 2:24 PM
BERUSTY
Score: 105
Status: offline
What is pattern flying...
More than likely you saw Dave Lockhart fly...Dave is a excellent precision aerobatic pilot who is also very generous with his ideas and experiences. Which is one of my favorite qualities of flying pattern and more specifically, flying in a contest.
The photos below are of an event I traveled to in South Carolina last year (Dave Lockhart, Troy Newman, Dean Pappas, Joey Hayes, Arch Stafford, Dave Guerin, Matt Kabajian, Tom Miller and Don Sczcur also attended). Of particular interest were the efforts to complete a new design/model "The Outlaw". These guys had a geat time traveling together in Joey Hayes' mondo fifth wheel, wrenching on the models and working through the first flights.
Chosing the path of precision aerobatics may improve your flying, increase your confidence, expand your modeling knowledge AND give you the opportunity to meet some very nice individuals!
Rusty Dose
Team Futaba
Team YS Performance
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BERUSTY -- 3/11/2007 2:29 PM >
Rusty Dose
Team Futaba
Hide Signatures
(in reply to overbored77)
       Post #: 40
RE: what is "pattern" flying - 3/12/2007 4:27 AM
overbored77
Score: 100
Status: offline
Berusty, Yup D. Lock it was. Actually I spent about 4 hrs at the field today with his father today. I am entering the beginning phases of pattern and I was working on the sportsman routine with one of our other Pattern guys. Flying a Tiger II until my modded Tiger 60
is complete. It takes alot of practice and work but when you finally get one or more of the manuevers correct it's worth it.
One of the nicest things about learning from the guys at my field is they won't lie to you, cause if you go into a competeion they will be the judges.
Chris Murphy
Hide Signatures
(in reply to BERUSTY)
       Post #: 41
RE: what is "pattern" flying - 6/25/2007 5:12 PM
rclement
Score: 100
Last Login: 11/19/2009
Status: offline
Is there any videos out there of people flying pattern? I am very interested but I don't understand what the manuvers are in the diagrams that I've seen. TIA
The hardest part of this hobby?......waiting for the UPS truck.
Hide Signatures
       Post #: 42
RE: what is "pattern" flying - 6/27/2007 2:45 PM
greg_m
Score: 100
Status: offline
Hi Rusty
Any follow-up on the "OUTLAW" test flying - it looks a rather nice pattern plane. I would enjoy more photos posted of it if possible or perhaps a lead to where it may be shown on a website.
Greg
Hide Signatures
(in reply to rclement)
       Post #: 43
RE: what is "pattern" flying - 6/28/2007 3:58 PM
BERUSTY
Score: 105
Status: offline
Greg,
I have no additional information or photos...
Rusty
Rusty Dose
Team Futaba
Hide Signatures
(in reply to greg_m)
       Post #: 44
RE: what is "pattern" flying - 7/23/2007 4:28 AM
BERUSTY
Score: 105
Status: offline
What is Pattern Flying?
10,000 hours of practice
$5,000 for a World Class model
Standing on the podium at the 2007 USA F3A Team Selection Event...Priceless
Rusty Dose
Big Fan!
Click for fullsize
Rusty Dose
Team Futaba
Hide Signatures
       Post #: 45
RE: what is "pattern" flying - 7/25/2007 3:57 AM
BERUSTY
Score: 105
Status: offline
What is "Pattern" flying?
Trust...knowing that your coach/caller is their to calm you down and keep you focused.
The photo is of Troy Newman and myself before I flew the finest P-07 of my life (898.00) against the best. Thank you Troy for your wisdom, Bill Cunningham for lending me the model and Jason Shulman for a few trim flights Monday before the NATS!
Rusty Dose
Team Futaba, Team YS Parts and Service
Click for fullsize
Rusty Dose
Team Futaba
Hide Signatures
       Post #: 46
RE: what is "pattern" flying - 7/28/2007 3:29 PM
PA BEN
Score: 100
Last Login: 7/15/2009
Status: offline
I just purchased a CMP Giles 202 140. http://www.egrandbuy.com/aegi20214072.html
First of all will this plane make a good Pattern plane? I’ve never tried pattern before. I’ve been on the 3D thread looking for the right engine for this plane. But it looks like it will be under powered for 3D unless I get a larger engine. But, I hear I need to stay away from the extra wt. a larger engine will add. I’m looking at a 26cc gas. This site has the engine I'm looking at. http://www.greenmodelusa.com/SPE_GasEngine.html
Also the box says its wt. is 10lbs. What it doesn’t say, is this just the plane or plane w/engine wt? Also the instructions don’t have the throws on it. Any recommendations for High and Low rates? I’m new to R/C flying about 2 years now. I fly 40 size, Ultra stick, Heckler, P-51 PTS, Sky Rader Trainer with floats. I fly and screw around. No rime or reason to my maneuvers, just having fun. I think Pattern will give me some discipline in my flying. Any good videos out there that give good instruction on pattern, 3D etc. One that just doesn’t show the plane but one that’s shows what you are doing with the controls to do that maneuver? Thanks.
Hide Signatures
       Post #: 47
RE: what is "pattern" flying - 8/3/2007 8:16 PM
dirtmagnet
Score: 100
Last Login: 1/8/2009
Status: offline
this is probably a dumb question but bare with i'm just kinda getting into pattern myself. what is a 2m airplane. i've seen that in forums and magazines but it just never really registered what it is.
King Kobra, Kougar, 2 Magics, Harmon Rocket, Mach Racer, Midget Stang, Showtime 50 For Sale or Trade
Ultra Sport 40
Hide Signatures
(in reply to firebld)
       Post #: 48
RE: what is "pattern" flying - 8/4/2007 1:16 AM
iflyrctoo
Score: 100
Status: offline
dirtmagnet, A 2m airplane is a 2 Meter sized model. Usually the fuselage length will be close to 2 meters and the wing span will be slightly smaller. The smaller wing span will make the plane snap better. AMA / FAI pattern rules say that the model must not be more than 2 meters long or have a wing span greater than 2 meters. It must also weigh less than 5 kg. or 11 lbs.
Hope this helps
Joe Dunnaway
Hide Signatures
(in reply to dirtmagnet)
       Post #: 49
RE: what is "pattern" flying - 8/4/2007 3:24 AM
dirtmagnet
Score: 100
Status: offline
oh ok. i figured it would be some where along those lines but wasn't sure. thanks
Ultra Sport 40
Hide Signatures
(in reply to iflyrctoo)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.625RCU1
