RE: Dirt Burner MT racers!!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Dirt Burner MT racers!!!
Page: <<   < prev  265 266 [267] 268 269 270 271 272 273 274   next >   >>
Login
RE: Dirt Burner MT racers!!! - 3/30/2007 4:05 AM
elite
Score: 100
Last Login: 1/26/2008
Status: offline
nice head..
quote:
ORIGINAL: Ken448
Hide Signatures
(in reply to Ken448)
       Post #: 6651
RE: Dirt Burner MT racers!!! - 3/30/2007 4:11 AM
Bria1
Score: 100
Last Login: 11/22/2009
Status: offline
That's funny Ken.
Matt, thanks for the link. Looks like it is worth trying to do.
_____________________________
http://www.motocross-dirtbikes-atvs-guide.com/
Hide Signatures
       Post #: 6652
RE: Dirt Burner MT racers!!! - 3/30/2007 4:49 AM
ThermalRD
Score: 100
Last Login: 10/6/2008
Status: offline
LOL. OMG Ken... Friggin checkers... Ade, i've heard of CEO power mods, but didnt know they made their own engines. I see CEO modded engines on A-main. I've seen the OPS, and the Radical engines. The Radical look interesting. I have never seen em run though. And havent heard too much about either brand.
Hide Signatures
(in reply to Bria1)
       Post #: 6653
RE: Dirt Burner MT racers!!! - 3/30/2007 5:37 AM
rdub202
Score: 100
Last Login: 10/12/2008
Status: offline
im almost done !
normal flm upgrade, shaved hubs. wing coming, and mgt mid tank possible. x towers (its a s25 truck), 4 gear diff mod.
now what i have to do is rebuild the shocks and attach
attach wing, motor, radio box, tank, flm skid, and whatever else is missing
and then work on the midtank when i get my dremel
oh also i have a rush battery box thing. gotta get a bracket cut for the x towers lazer cut soon to replace the scrawny one ive got
|/|Academy SBV2 PRO|:|Losi xxx-bk2|\|
|/|Team Upgrade-RC|:|Team MRC/Academy|\|
Hide Signatures
(in reply to ThermalRD)
       Post #: 6654
RE: Dirt Burner MT racers!!! - 3/30/2007 6:13 AM
GT Batman
Score: 100
Last Login: 3/14/2009
Status: offline
Hey Matt, the paint looks killer in person More of the same thing on the others please
As you can see, it looks much better than Matts original picture...time for a new camera Matt
< Message edited by TQ Batman -- 3/30/2007 6:37 AM >
Maintenance is overrated!!!
Hide Signatures
(in reply to rdub202)
       Post #: 6655
RE: Dirt Burner MT racers!!! - 3/30/2007 1:35 PM
ThermalRD
Score: 100
Status: offline
The savage is lookin good Rdub. Ya Batman, i know. My camera is showing its age... I'll eventually get a new one.
Hide Signatures
(in reply to GT Batman)
       Post #: 6656
RE: Dirt Burner MT racers!!! - 3/30/2007 8:11 PM
ThermalRD
Score: 100
Status: offline
Well, i decided on the V-spec today. Dropped by DB's and got the V-spec, and a Team Orion 1600 pack. Everything is installed. All the trims, epa's, etc... All set. Charging up the battery, then i'll double check everything. I can see how people will trash throttle/brake servos on this setup. The brake arm setup, is an extremely short throw design. But i got it all setup now. The brakes seemed to be set stronger on the fronts out of the box. I changed that up a bit. I've got more towards the rear, and then an overall light brake setup. I really like the air filter setup on this truck too. The way it mounts, holding the filter secure with a body clip. I like that alot. So the truck is pretty much ready. I also setup the TTR starter box for this truck. Atleast until i get my hands on the new TL starter box. I also need to throw on one of my pipes here, or buy another one. I'm thinking i'll end up with an OS pipe as well. I'll get pics later.
Hide Signatures
       Post #: 6657
RE: Dirt Burner MT racers!!! - 3/30/2007 9:14 PM
Ken448
Score: 100
Last Login: 1/8/2009
Status: offline
why would you want more brakes the ther rear? I thought it was opposite....
Ken
S/E Michigan
Hide Signatures
       Post #: 6658
RE: Dirt Burner MT racers!!! - 3/30/2007 9:30 PM
GT Batman
Score: 100
Status: offline
quote:
ORIGINAL: ThermalRD
Get the upgraded chassis braces. Be sure to get the upgraded KH throttle servo plate too to save the servo, make sure you keep the carp straight across, even if you have to dremel a little. THis will keep that throttle from dying. Some tips from the DBs crew.
Hide Signatures
       Post #: 6659
RE: Dirt Burner MT racers!!! - 3/30/2007 10:58 PM
Ken448
Score: 100
Status: offline
quote:
ORIGINAL: TQ Batman
http://www.rap-cat.com/
.....need I say more? Is that the Fab "FUR" mascott?
Ken
S/E Michigan
Hide Signatures
       Post #: 6660
RE: Dirt Burner MT racers!!! - 3/31/2007 12:26 AM
ADE
Score: 100
Last Login: 3/8/2009
Status: offline
Thanks Brian!
quote:
ORIGINAL: Bria1
http://www.upgrade-rc.com/rcid1/rcid-index.html
quote:
ORIGINAL: ADE
Where can I get some of those stickers/decals with my name on them. I really like those.....
Tony (ADE)
Don''t look back, they may be gaining on you!
Hide Signatures
(in reply to Bria1)
       Post #: 6661
RE: Dirt Burner MT racers!!! - 3/31/2007 1:02 AM
ThermalRD
Score: 100
Status: offline
Ken, the pivot action you see when a center diff vehicle turns, is from that brake bias. If you have strong brakes up front, you'll go straight to the outside of the turn. Stronger brakes in the rear, and you'll get nice tight steering. Same concept behind the center one ways for the Revo. It frees up the front drive shaft upon braking.
Mike, i've got my linkage setup real nice right now. My carb is pretty straight right now too. Like i mentioned in my previous post, i think alot of those servo problems are caused from poor setup. That brake linkage has a VERY short distance to travel. Im probably set at 30-40% of my travel for brakes. It takes time to setup properly, but nothing is binding, and my servos arent making any noise. So i think im ok in that area. As for the extra bracing, im not sold on that being the reason for the servos going out. I mean anything is possible, but i dont think thats the cause. But hey, if im wrong... I'll be replacing a servo soon eh? LOL. Since these things supposedly destroy servos in a big ugly way. Here are a couple pics. I still have no pipe. I was gonna buy the older style OS pipe, but didnt care much for the return line nipple. The new design is supposed to be out late April.... I'll see how long i can hold out. Possibly just run with my JP-2 for a while.
Hide Signatures
(in reply to ADE)
       Post #: 6662
RE: Dirt Burner MT racers!!! - 3/31/2007 1:09 AM
hunter306
Score: 100
Last Login: 9/15/2009
Status: offline
That thing looks good with the engine in there... Bet it feels a little bit more balanced too, with the motor all locked in.
Still, you won't get the true feel until you plop it down on all 4 and start running
Nothing but boxes of old parts...
Hide Signatures
       Post #: 6663
RE: Dirt Burner MT racers!!! - 3/31/2007 1:25 AM
ADE
Score: 100
Status: offline
She looks good Matt! That V-Spec looks really good in there. I know OS is killer but I heard alot about the bearing in that motor....not sure how much of it is true. Im with you...I think its poor setup thats destroying servos. I decided to install a less expensive servo first to make sure I have it all installed correctly. EPA is critical on this setup! I also think its critical that you have the grommets installed on your servos too. I bought and installed the front, rear braces and servo tray stiffener because I liked how they looked. I like how they make everything feel more solid.
Good Luck to all the new 8ight T owners!
Tony (ADE)
Hide Signatures
(in reply to hunter306)
       Post #: 6664
RE: Dirt Burner MT racers!!! - 3/31/2007 1:36 AM
GT Batman
Score: 100
Status: offline
Hey Matt, that 8T looks just like mine now Still no go with starting that vspec though...but really close I will try a new plug tomorrow. It is firing right up now but it dies when I pull the igniter.
Just did a few more mods to the LST that worked out really well, allot faster all the way around and much more controllable speed
Hide Signatures
(in reply to ADE)
       Post #: 6665
RE: Dirt Burner MT racers!!! - 3/31/2007 1:38 AM
GT Batman
Score: 100
Status: offline
quote:
ORIGINAL: Ken448
quote:
ORIGINAL: TQ Batman
Yes
Hide Signatures
       Post #: 6666
RE: Dirt Burner MT racers!!! - 3/31/2007 2:45 AM
ThermalRD
Score: 100
Status: offline
Ya Hunter, the suspension felt wayyyy off right out of the box. With the gear installed, it feels alot better. I actually put it on the scale today. Showing 8.2-8.3 lbs. Only thing its missing is the pipe. So it outta move along real nice with this V-spec.
ADE, i went with the high end servos right away. I think im pretty safe though. I spent alot of time today doing that setup. I still need to slip on some CVD boots to keep those pins in place. Just in case they come loose during a race. I've also gotta get a PT in here. Its currently on the muggster. Im still debating sending one off to that MRT company, and getting a bunch of clones. Would make things real easy at the track. I also might throw on one of those Odonnell cooling heads. I really like the look of those heads. But i will break it in first. See how it runs.
Batman still cant get the batmobile fired up? That stinks. But its typical of these high end motors, with all that compression, and tight pinch. I remember my high end RB motors, and OS motors back when i had some buggies... Man.... NOT fun to break-in. But i've learned sooo much since then. Hopefully i'll have no problems. Im still not planning break-in for another week or so. I plan to sit down this week and get alot of my paint done. So i can start planning any road trips, and track time. So what mods did you do to the LST2? And how did you come across that Rap cat? Or do i even wanna know.... lol
Hide Signatures
       Post #: 6667
RE: Dirt Burner MT racers!!! - 3/31/2007 3:24 AM
Bria1
Score: 100
Status: offline
Try heating the block up with a hair drier before starting it. Makes break in much easier on you and the engine. I usually point it at the side of the block where the sleeve is and let the temp get over 100 F at the glow plug.
quote:
ORIGINAL: TQ Batman
Hide Signatures
       Post #: 6668
RE: Dirt Burner MT racers!!! - 3/31/2007 3:25 AM
Bria1
Score: 100
Status: offline
8T looks good Matt. I heard those were pretty light.
Hide Signatures
(in reply to Bria1)
       Post #: 6669
RE: Dirt Burner MT racers!!! - 3/31/2007 3:36 AM
GT Batman
Score: 100
Status: offline
We had that thing up to 240 with a heat gun, trust me, it will still get stuck. I was going through my 8T installing some goodies and found that the plug was only about 15% good...so I am sure that is the cause of the stalling. It starts up good now, and I bet the new plug will allow it to STAY running. Can't wait until tomorrow. My box sucks though, I burned my hand as I had to hold the motor and igniter at the same time with my right and the front of the truck and radio in the left on a box with no top and positioned backwards
LST mods...you will see at the races but this thing is crazy fast and very controllable....great combination Bill got to see it run before the mods.
Hide Signatures
(in reply to Bria1)
       Post #: 6670
RE: Dirt Burner MT racers!!! - 3/31/2007 2:42 PM
Bria1
Score: 100
Status: offline
Well, 240 should have it warmed up plenty. Hopefully the new glow plug does the trick for ya. Is that the same starter box you let Chris use, or does he still have that one?
Hide Signatures
       Post #: 6671
RE: Dirt Burner MT racers!!! - 3/31/2007 4:44 PM
Ken448
Score: 100
Status: offline
Any of you revo lovers need this???
I know its off a 2.5, not sure if the 3.3 is the same or not. Found it in my "junk" box.
Ken
S/E Michigan
Hide Signatures
(in reply to Bria1)
       Post #: 6672
RE: Dirt Burner MT racers!!! - 3/31/2007 5:01 PM
ThermalRD
Score: 100
Status: offline
I'd have to verify if thats the same as the 3.3 header. But that would be a good spare to have on hand. Have you guys been to the traxxas site lately? Last night i saw they updated the nitro rustler, and the nitro stampede. They have 2.5's in em now... That little stampede outta SCREAM with a 2.5 in it.
Hide Signatures
       Post #: 6673
RE: Dirt Burner MT racers!!! - 3/31/2007 5:03 PM
ThermalRD
Score: 100
Status: offline
I take that back... The info page says its a Pro .15 in there.
Hide Signatures
       Post #: 6674
RE: Dirt Burner MT racers!!! - 3/31/2007 5:15 PM
Bria1
Score: 100
Status: offline
I'm guessing the electric 4-tec and spirit will get upgraded before the e-maxx ever will.
Hide Signatures
       Post #: 6675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.625RCU1
