RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not truck thread)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not truck thread)
Page: <<   < prev  105 106 [107] 108 109 110 111 112 113 114   next >   >>
Login
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/22/2007 7:51 AM
mozzzy_2000
Score: 100
Last Login: 4/24/2011
Status: offline
quote:
When you are putting the two sets of gears back into the diff housing are they going back with the centre cut out sections mated together
Hey grizz thats worth mentioning! Sorry I forgot about that but yeah makes sure when you put those internal gears in that the cross bars "mate" up together as Grizz suggested. You'll notice that the 2 gear spindle/rods have a flat spot in the middle. These need to mated correctly or it will definately bind when the diff is tightened up. Its so easy to do/miss and infact its the number one thing I used to do when putting diffs back together myself.
Also once you have a free moving diff, dont forget to fill it up with some quality silicone diff oil. I'd suggest a wt of 10000wt for the centre diff. If you decide to fill the front and rear diffs up as well, and I highly suggest you do, use 5000wt in the front and 3000wt in the rear. Do this and you will turn the hurricane into a completely different beast and it will handle like a completely different vehicle.
Hide Signatures
(in reply to mozzzy_2000)
       Post #: 2651
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/22/2007 9:00 PM
bocajrs
Score: 100
Last Login: 8/25/2009
Status: offline
Hello,
I was checking glow plug and noticed it was black all the way around.
I have ran through 6 tanks of fuel, and made one small turn to HSN. Is it running too rich, lean?
Hide Signatures
       Post #: 2652
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 4:55 AM
grizz1
Score: 100
Last Login: 4/15/2008
Status: offline
Hi bocajrs, The glow plug on your engine will be a little black due to the rich settings from the factory for run in. You need to run the engine fairly rich during the break in period, then you can start to lean it out 1 hour at a time on the HSN as you run a few more tanks through it. Everyone has a slightly different idea on run in time etc, but I normally start leaning my engines out after 12 tanks of careful rich running, not having gone near wide open throttle, just doing figure of eights and varying the revs up and down continuously.
After 12 tanks I lean the HSN out to achieve peak performance over the next 4 - 6 tanks, setting LSN at the same time. When you start leaning the engine out you should replace the original glow plug as the overly rich running during break in normally kills the plug to some extent. A new plug will give you better performance and easier starting. When tuned correctly the glow plug should be a light brownish colour on the bottom with the filament a silvery/white colour. The bottom of the plug should also be a little moist when you remove it. If it is burnt dry and there is any distortion of the filament then you are running too lean.
There are some good articles on tuning and glow plug reading out there on the web, just Google them up
_____________________________
Don't take life too seriously - No one gets out alive anyway.
Hide Signatures
(in reply to bocajrs)
       Post #: 2653
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 5:28 AM
bocajrs
Score: 100
Status: offline
Thanks grizz..i will probably run 3 more tanks and then start leaning out..
Hide Signatures
(in reply to grizz1)
       Post #: 2654
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 5:55 AM
grizz1
Score: 100
Status: offline
No worries. I will track down some of those web sites from my favourites folder and send the links to you. I will probably send you a personal message with the links as some of them are from sites outside of RC Universe, and we cannot post links to outside forums on these pages.
Remember when you are leaning or richening needles to only adjust small amounts at a time ( if the top of the needle was a clock face, adjust in 1 hour amounts) otherwise you can chase your tail around all day trying to get things running correctly. You will notice a huge increase in power and performance as you lean the HSN out. When you get it set right you will be impressed !!! Just make sure you always have a good trail of exhaust smoke right through the rev range, and that the engine in not ¨running on¨ on over run as you come off the throttle (a tell tale sign that things are getting a little too lean and temps are getting too high). Have FUN
< Message edited by grizz1 -- 10/23/2007 6:07 AM >
Hide Signatures
       Post #: 2655
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 6:33 AM
mozzzy_2000
Score: 100
Status: offline
Hey grizz that was some very well written advice you gave there! Very concise and to the point. This is pretty much exactly the way I run in an engine too and so far its worked for me flawlessly.
Hide Signatures
       Post #: 2656
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 7:42 AM
dtsn280z
Score: 100
Last Login: 11/11/2009
Status: offline
In response to your tire question... I just used these guys. They have a great selection and the prices are right. My neighbors pitbull ran down my car and I got in a tug of war with him. LOL. I got the black wheels with the mohawks. They were like $20.00 shipped. Also you can get 50 feet of fuel line for $10.00. Fast shipping too.
http://stores.ebay.com/Supra-Sales
Can't beat that HUH?
Hurricane XP, Tornado BB X 3, CEN Nemesis-
What started as a Hobby has become a habit...
Hide Signatures
       Post #: 2657
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 7:46 AM
DJack
Score: 100
Last Login: 1/28/2008
Status: offline
just looked at that site. Whats with this chasis??
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190165918039&indexURL=0&photoDisplayType=2#ebayphotohosting
Ready to race again!!!
Hide Signatures
(in reply to dtsn280z)
       Post #: 2658
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 7:52 AM
dtsn280z
Score: 100
Status: offline
I saw that.. Not sure, but it looks like a durable roller. They respond pretty fast to questions through email though. I'm sure they can give an idea what engine will go on it.
Hide Signatures
(in reply to DJack)
       Post #: 2659
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/23/2007 11:46 AM
mozzzy_2000
Score: 100
Status: offline
Hey good find. Yeah those supasales certianly have cheap tyres and wheels. I have no idea what the quality is like though compared to known brands. Probably just as good. Not a racers choice but who really cares when you're bashing.
Wow that rolling chassis is certianly dam cheap! $80US?? Man that was a good find! The only thing I'd be wary of is the quality. Looks ok but good knows how long it would last. Parts would be the main concern. If it was compatitable with other brands it would an absolute bargain but if you couldn;t get parts for it it would be pretty much useless in my opinion. Although having said all that it, at US$80 its so dirt cheap you could almost through it away if it was too badly damaged and just get another! lol
In terms of engine & what to put into it; It's definately a 1/8th buggy so you would put anything from a .21 to .32 in it. Radio; likewise just put a cheap AM radio into and bung some cheap servos in and way you go! Unbelievably cheap setup. Actually I'm going to drop them an email & see how much to send one to Oz. If the postage is good it would make it an awesome buggy to thrash around recklessly I reckon.
< Message edited by mozzzy_2000 -- 10/23/2007 11:57 AM >
Hide Signatures
       Post #: 2660
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 4:39 AM
Mercyful Fate
Score: 100
Last Login: 11/9/2007
Status: offline
Dumb question I know how to put pictures on the computer but how do you post them on the fourm?
Hurricane XP
Hide Signatures
       Post #: 2661
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 5:04 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
On the bottom of the screen you will see this Click here to upload images and files!
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
(in reply to Mercyful Fate)
       Post #: 2662
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 5:08 AM
ehroof
Score: 105
Last Login: 6/6/2013
Status: offline
you need to click on the reply on the last thread first though and then click what clermont said below where you would post.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to Chubbysdad)
       Post #: 2663
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 7:42 AM
RCKen
Score: 421
Last Login: 6/18/2013
Status: online
quote:
ORIGINAL: Mercyful Fate
How to Post Images on RCU
Ken
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
Ultra Sport Brother #1
www.gettingairborne.com
Hide Signatures
       Post #: 2664
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 11:02 AM
mozzzy_2000
Score: 100
Status: offline
Nice to see you're still with us RCKen! Just checkin up on us hey?
Hey Ehroof just noticed your post count!! wow all that in what? 20mths? Thats like 10+ posts on average a day! keep up the good work!
< Message edited by mozzzy_2000 -- 10/25/2007 11:05 AM >
Hide Signatures
(in reply to RCKen)
       Post #: 2665
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/25/2007 10:51 PM
ehroof
Score: 105
Status: offline
yeah bro, this forum stuff can become a little addicting, lol
Hide Signatures
       Post #: 2666
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:18 AM
bocajrs
Score: 100
Status: offline
Hello,
I just accidently broke one of my shock absorber caps, can anyone tell me the REDCAT Part#?
Hide Signatures
(in reply to ehroof)
       Post #: 2667
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:28 AM
ehroof
Score: 105
Status: offline
i dont think you can get the caps, i think you need to get the whole shock, if you need a place, try clermontmotorsports.com, email him and see but i am pretty sure about it. you may be able to find another company's shock parts that may fit or someone in this thread may know of a replacement.
Hide Signatures
       Post #: 2668
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:35 AM
bocajrs
Score: 100
Status: offline
I just looked in the manual and it was listed. I dont know why i would need to buy the entire shock. There's nothing wrong with the shock?
Hide Signatures
       Post #: 2669
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:45 AM
ehroof
Score: 105
Status: offline
what was the part number in the manual?
Hide Signatures
       Post #: 2670
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:57 AM
bocajrs
Score: 100
Status: offline
81059
Hide Signatures
       Post #: 2671
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 5:59 AM
ehroof
Score: 105
Status: offline
http://www.redcatracing.com/itemdetail_part.asp?partno=81059
thats the rubber cap that goes between the shock body and the top nut, thats not the nut though
< Message edited by ehroof -- 10/26/2007 6:00 AM >
Hide Signatures
       Post #: 2672
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 6:04 AM
bocajrs
Score: 100
Status: offline
By the cap, i mean the circular piece of plastic that maintains the shocks in place and not allowing them to fully extend. I guess i'll call tommorrow and find out if they have this part, i'd hate to buy two rear shocks...
Hide Signatures
       Post #: 2673
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 6:07 AM
ehroof
Score: 105
Status: offline
sorry bro, i am not 100% sure what part your talking about. maybe post a picture of what you need.
Hide Signatures
       Post #: 2674
RE: "OFFICIAL"Redcat Racing 1/8th BUGGY thread (not tru... - 10/26/2007 6:09 AM
bocajrs
Score: 100
Status: offline
If you look at part# 81002, i need the circular piece of plastic with the screw on it. Look at the left shock towards the bottom.
Hide Signatures
       Post #: 2675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
