RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not truck thread)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not truck thread)
Page: <<   < prev  125 126 127 128 129 130 131 [132] 133 134   next >   >>
Login
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 10/25/2008 9:56 PM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
I never had any luck putting kyosho parts on a hurricane...I gought some axles for a 777 and they didnt fit...nor did the knuckles...I'm going to agree with Grizz on that its to heavy to race, but its an excellent bashing buggy...I still run mine just not as much...been running my other buggy to get a good feel for it
Grizz them 5 ports seem to be really popular...I've heard the 5 ports are better suited to the truggy as were the 7 port is better suited towards the buggy...guess it just depends on who ya talk to...them 5 ports are spose to make monsterous tourqe....I fired up my sh 8 port and idled a tank through it, then ran it around a lil on another tank just burping the throttle about 1/4 to a 1/2 throttle..was doing some tuning as I went.. I did give it full throttle for just a second to see if it would die or what not...thing has a lil pop to it with that dynamite pipe..lol....should be a snappy lil engine...
_____________________________
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to zaintlouis)
       Post #: 3276
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 10/27/2008 1:56 AM
trpastor
Score: 145
Last Login: 4/15/2011
Status: offline
Hey Guys
I'm not sure the technical terms.. but on the arms that connect the wheel hubs to the shock tower (basically a metal rod with threads at each end that go into the plastic connector at each end). .... how do you know who far in to put all of those?
I guess if you mess with the top and bottom, front and back of each of those, it changes the angle at which your tires sit on the x and y axis. So you can create tires that either point in or out or straight, and sit straight up and down or have some tilt either in at the bottom or top. How do you know how much to adjust these?
Tim
Hide Signatures
       Post #: 3277
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 10/27/2008 8:22 AM
TTR_EB4
Score: 100
Last Login: 4/4/2009
Status: offline
trpastor, some people do it by eye (cz they have been doing it for years lol) but some ppl have these gadjets that you bolt onto the wheels < if thats wot ur tlkin bout
BTW Shane, u know this is michael right?? lol remember TTR_EB4 = Michael lolz, jus chekin if u remember we havnt tlked in a while
Hide Signatures
(in reply to trpastor)
       Post #: 3278
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 10/27/2008 10:22 PM
zaintlouis
Score: 110
Last Login: 3/6/2013
Status: offline
you got to replace the upper and lower arms first before you can fit in a kyosho lightweight axles and knuckle arms. but the upper plate has to be customized. Some Kfactory products for kyosho mp777 can fit too if you know what they are lol.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by zaintlouis -- 10/28/2008 9:34 PM >
I hate onroad cars but give me a Ferrari i''''ll drive it. - PRO INFERNOS
Hide Signatures
(in reply to firebird78)
       Post #: 3279
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 10/29/2008 7:56 AM
grizz5
Score: 100
Last Login: 3/10/2009
Status: offline
quote:
ORIGINAL: firebird78
Hey - Everyones back on line
Firebird - your on the mark with the Go engines. Traditionally the 7 port is the motor for a buggy. It has endless top end and more than enough bottom to pull wheelies in the buggy. The 5 Port is a real stump puller down low with reasonable top end, but not a real screamer like the 7, and is ideal for truggy.
What I am running is a modded 5 Port (Massive Mods Australia Stage 5 Mod). This involves a full work out on the sleeve, crank and piston, changing timing etc. What you end up with is a motor that has even more low down power than the original 5 Port (with a little smoother application) and the top end of the 7 port with better economy to boot. This thing hauls butt You can run this in buggy no sweat, you just have to be careful with your diff oils (not too heavy in centre) and clutch set up so you don't end up doing doughnuts out of the corners Driven smoothly (I'm trying !!!) it is a wicked combo in the buggy. My home track is pretty tight with one good long straight so this motor is very well suited with it's low end / mid range power band.
If your looking for a good value motor the new Gen 5 Go's are pretty good. The Gen 5 has a new carb and new crank (more V-Spec like). Even in stock form they rock.
Louis - Hey brother, not much Redcat left in that Redcat No wonder it's so light !!! Looking good mate.
Michael - of course it's you Mr Stenic
trpastor - Those steering arms set your toe in / toe out. You want around 1.5 - 2 degrees toe out on the front for good steering response. Just use the old "Eyecrometer" to get them the same. Hold a ruler along the outside of the wheel and get the angle on both sides the same. You want the same measurement between the threaded turnbuckles at each end, on both sides of the car. Otherwise you will have uneven steering travel.
< Message edited by grizz5 -- 10/29/2008 7:57 AM >
Hide Signatures
       Post #: 3280
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 10/29/2008 8:43 AM
firebird78
Score: 105
Status: offline
quote:
ORIGINAL: zaintlouis
so looks to me besides the knuckles and shafts...you have the upper and lower arms for a 777 on a hurricane?...I know them shock towers arent redcat...lolall that I see that resembles a hurricane is the rear armsand servo tray....everything else looks totally different..the front of the diff case looks sim as well as the servo saver,,,,but thats it...lol..nice looking buggy by the way
Hide Signatures
       Post #: 3281
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not ... - 11/1/2008 1:44 PM
zaintlouis
Score: 110
Status: offline
Still have to replace the rear arms with plastic lower arms, & with my new tg throttle servo i can just use dual brake disc. i think replacing the brake disc with carbon disc would also help. well what brake disc are guys using? mine's still stock gonna need to replace it soon
Hide Signatures
       Post #: 3282
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/1/2008 7:03 PM
firebird78
Score: 105
Status: offline
still running stock here also
Hide Signatures
       Post #: 3283
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/2/2008 11:17 PM
grizz5
Score: 100
Status: offline
Still running stock disc on the CL-1, but with upgraded thicker brake pads on the shoes. No brake fade at all.
< Message edited by grizz5 -- 11/2/2008 11:19 PM >
Hide Signatures
       Post #: 3284
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/6/2008 1:37 PM
grizz5
Score: 100
Status: offline
Hey guys - Louis, Jas, Michael, Firebird. I know this is a Redcat site, and I haven't owned a Redcat (Bazooka) for ages, but I really enjoy chatting with you guys. Just to let you know I am changing to the XRay camp. I have my order in for a new XRay 808. The rest of the "team" are all changing too. The GS distributor here is dragging the chain, so we have all gone up-market. Two of the guys have already changed to the 808 and the performance difference is astounding. Trusty CL-1 Advanced (with a million spares - ha) will be a nice back up / bash buggy with modded Go 7 Port. When I have the new beast built up and running I might post some pics on here (if they will let me).
Sorry Redcat owners - the thread is back to you guys now. Cheers all
< Message edited by grizz5 -- 11/6/2008 1:38 PM >
Hide Signatures
(in reply to grizz5)
       Post #: 3285
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/7/2008 5:15 AM
firebird78
Score: 105
Status: offline
I think we all have went a diff route Grizz...like you I enjoy talking to yall and hope to do so for some time in the future...yall have some good tips on everything to do with rc and I value yalls opinions...if I can only find a reliable pit man I will be asking yall for tips and pointers on racing next year...congrats on the new ride
Hide Signatures
       Post #: 3286
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/7/2008 6:45 AM
grizz5
Score: 100
Status: offline
Cheers bro. Get out there and do it. It's a whole heap of fun
Hey guys - check out the new "WIDE" buggy tyres from VP Pro. They come in a set of four. Two standard size fronts and two new wide rears. Come in two models - 802 (normal track conditions) and 804 mini pins (blue groove conditions). Going to try them out this weekend. Hey, if they don't work any better than a standard set at least they look cool. Get some on the Redcats and go hard !!!!
Will let you know how they go. Later - grizz
Click for fullsize
Click for fullsize
< Message edited by grizz5 -- 11/7/2008 11:13 AM >
Hide Signatures
       Post #: 3287
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/11/2008 11:02 PM
grizz5
Score: 100
Status: offline
802 Wides work very well. Looked at the results from this weekends racing, and my best lap time with the "wides" was 2.5 sec faster than with the other two types of tyres I used during qualifying. Even at my lower level of competition this is a big difference. I didn't use them for the finals as track conditions were very dry and hard by then and nearly blue groove after a days racing. These conditions really suit the 804 model from VP. The 804 also comes in a wide now, so guess what I will be saving my pennies for next
Hide Signatures
       Post #: 3288
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/13/2008 11:54 AM
grizz5
Score: 100
Status: offline
What's happening with all those Redcats out there guys ? Very quite on here the last week or so.
Hide Signatures
       Post #: 3289
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/22/2008 8:35 PM
euphorik
Score: 100
Last Login: 11/24/2008
Status: offline
I just got mine up and running again. I moved back to New York and right now after a good snowfall I am building a track in my backyard on the snow. Heres some pics of my buggy.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3290
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/23/2008 4:50 AM
firebird78
Score: 105
Status: offline
wow look who the cat dragged in....I'm suprised your still using that radio system ( thats if you still are)....you musta got the only good one..lol..thay were recalled...anyways good to hear from ya...looks like ya had some fun with the buggy..havent ran in awhile hear with the weather...was nice today but had to go to my folks house and cut down a big honkin tree...kewl pics grizz like that buggy...yall take care
Hide Signatures
(in reply to euphorik)
       Post #: 3291
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/23/2008 4:56 AM
euphorik
Score: 100
Status: offline
No the Radio sucks big time. I just broke out my RC Again after about a year idle So a radio system is in the works. But for now, some thrashing around the neighborhood with thats radio isnt too bad.
Hide Signatures
       Post #: 3292
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 11/24/2008 10:05 AM
grizz5
Score: 100
Status: offline
Hey euphorik - good to hear from you bro. Buggy looks in good shape, seeing it has had a bit of a rest.
Hmm, Hawaii sun to New York snow, that's a bit of a contrast
Buggy thrashing in the snow - now that sounds like fun
Hide Signatures
       Post #: 3293
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 12/16/2008 11:49 AM
TTR_EB4
Score: 100
Status: offline
Hey guys, hows everyone, havnt been on this forum in a while, as you all know i bought some Hobao's, a buggy and a truggy. and they have been nothing but trouble ever since i got them, im currently selling my old hyper 7 buggys and K8T truggy, so i can buy a new competitive buggy, i got offered a Caster Racing ZX-1R for a trade with my K8T, how are the ZX-1R's???
< Message edited by TTR_EB4 -- 12/16/2008 11:52 AM >
Hide Signatures
       Post #: 3294
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 12/20/2008 2:37 AM
firebird78
Score: 105
Status: offline
never seen one personally...I do however know a guy that swears up and down they are top notch and are very competative...he has always been a straight up guy with me so I've no reason to doubt it
Hide Signatures
(in reply to TTR_EB4)
       Post #: 3295
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 12/29/2008 5:50 PM
TTR_EB4
Score: 100
Status: offline
well i ended up selling my old cars and bought a Losi 8IGHT kit
this thing is crazy! way better suited for my driving style, and ive got a 4 second faster lap time on my first go with it!!! yay
Hide Signatures
       Post #: 3296
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 12/31/2008 5:46 AM
firebird78
Score: 105
Status: offline
congrats on the new buggy
Hide Signatures
       Post #: 3297
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 1/3/2009 12:16 AM
grizz5
Score: 100
Status: offline
Happy New Years guys. Best wishes for a safe and prosperous 09 - with lots of chances to burn some nitro
Cheers - Grizz
Hide Signatures
       Post #: 3298
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 1/3/2009 6:42 AM
firebird78
Score: 105
Status: offline
yeah happy new year yall...burn some go juice and make some video
Hide Signatures
       Post #: 3299
RE: "OFFICIAL" Redcat Racing 1/8th BUGGY thread (not tr... - 1/10/2009 12:50 AM
alexgassam
Score: 100
Last Login: 2/3/2009
Status: offline
i have a ofna hyper 7 with a os 21 vg motor and i have a bump box for it the box works fine buts its not grabbing the teeth on the flywheel and it will on my friends box does anybody have a solution for this problem.and another thing does anyone know whats i would need to make it a pull start or a torque starter id greatly apperiate it
alex gassam
Hide Signatures
(in reply to zymurgy)
       Post #: 3300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
8.125RCU1
