trpastor
Hey Guys... I've been promising and promising for a while that I would get some video. WELL it's up. It's not real exciting I guess but it does show these things can run and jump with the best of them. I am a novice driver also. Thank my wife for standing in the line of fire to get this. She was almost hit twice, once on a jumping shot that was just at waist level from where she was, and you will see if you watch. Also at about 4:25 I hit a pole straight on. This is becuase of the only damage that resulted from the run, which was the washer on the steering bar (that sits in the center of the car and is purple or blue aluminum) was slipping off becuase the washer was CUT away I guess from steering over and over. I think I over tightened it before my run becuase I went through and tightened everything, and I think this is supposed to be left with play in it. So all these jumps and crashes and what not and the only damage was this ... A cut washer on the steering bar a busted front nose (which I had begun earlier by being careless when putting the shell off and on) and the shock tower that was already bent from hitting a tree, got bent just a LITTLE more. Not as bad as it was before and the metal was weak from hitting a tree. For those thinking of running out and buying one... do I thought I might get an ofna hyper 7 to compare, but I might just get a second Redcat instead here's the link http://media.putfile.com/Red-Cat-18th-Buggy
