RE:    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE:
Page: <<   < prev  125 126 127 128 129 130 131 132 133 [134]
Login
RE: - 12/21/2009 6:23 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
well I'm gradually getten better...I dont have anyplace to practice which sucks so taking a lil longer then usuall I'd suspect....I have won heat races (by default..they all broke and I stayed together...lol)....I mostly have to race veteran drivers as there isnt really enuff buggies in the rookie class to hold a rookie race...not complaining though as I think it has made me better...I'm pretty competative and with everything else I continued on and got to the top of my competition area ( soft tip darts, billiards and so on)....if they think I'm gonna give up they are sadly mistaken..lol
_____________________________
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to zaintlouis)
       Post #: 3326
RE: - 1/11/2010 9:59 PM
volcanomx
Score: 100
Last Login: 6/21/2010
Status: offline
Does any body know what "other" pull start can i use on my sh.28 engine or if some one is selling one please PM. thank you.
Hide Signatures
(in reply to firebird78)
       Post #: 3327
RE: RE: - 1/11/2010 10:54 PM
RCToysNh
Score: 100
Last Login: 6/26/2011
Status: offline
quote:
ORIGINAL: volcanomx
Does any body know what ''other'' pull start can i use on my sh.28 engine or if some one is selling one please PM. thank you.
Sent you PM with options
Always Best prices and Cheap S/H at RCToysNH, NHwoods, ToystoreNH, VP Ent. Inc.
RedCat Traxxas DuraTrax AE
Hide Signatures
(in reply to volcanomx)
       Post #: 3328
RE: RE: - 6/21/2010 5:46 PM
zaintlouis
Score: 110
Last Login: 3/6/2013
Status: offline
Wow where you guys are come back here i miss you lol my redcat's still alive and has now more turning radius - also has carbon fiber radio plate from sx8 oh well gonna check this thread soon enough if you guys 're still around laterz
< Message edited by zaintlouis -- 6/22/2010 9:07 AM >
I hate onroad cars but give me a Ferrari i''''ll drive it. - PRO INFERNOS
Hide Signatures
(in reply to RCToysNh)
       Post #: 3329
RE: - 9/16/2010 5:24 AM
msrfrog1
Score: 100
Last Login: 9/29/2010
Status: offline
new hurricane xtr owner. wow this buggy is fun and durable so far. I ran it full speed under my friends lowered scion tc the other day and the only damage was a bent shock tower that i bent back! the aa battery came loose while diving and caused that one. now i zip tie them. it seems very fast and the motor runs real nice, but the glow plugs don't seem to last long compared to my traxxas vehicles. is this normal for a big block? I never had one before. I am tuned on the rich side still running at 215F . i know my tmaxx like to run at like 225F . any suggestions on glow plugs and temps for the sh .28 3p? thanks.
Hide Signatures
(in reply to trpastor)
       Post #: 3330
RE: - 9/19/2010 6:47 AM
xDIRTYSOUTHx
Score: 113
Last Login: 9/27/2012
Status: offline
Yo, anyone have the stock needles settings for LSN on .21 That's on the Backdraft 3.5? Before i started breakin the engine i see that the LSN is half turn off closed so im thnking there's no way that's right. Any help would be great.
Click to see fullsize image.
Click for fullsize
Savage XS Flux - Bullet MT Flux
Bullet ST 3.0 - Savage X 4.6
Hide Signatures
(in reply to alexgassam)
       Post #: 3331
RE: - 4/22/2011 4:06 AM
Titaniumracingtiger
Score: 100
Last Login: 4/25/2011
Status: offline
I just got a Hurricane XP from a friend that I'm putting together for my brother-in-law. Looks like I need a lot of parts as the guy that had it before really hacked it up bad. Wheres the best place for parts? So far I need.
  • Hinge pins
  • Springs that go between the lower front arms and the rear mounts along the hinge pins > Is there some way to do without the springs, just make it a normal mount like all the other buggy designs.
  • Front Shocks
  • Front lower arm mount
  • Front lower arm mount bushings I guess those plastic inserts that are in them to hold the hing pins.
  • Rear Hubs
Also what upgrades are recommended? Either OEM or Creatively adapted parts from other cars.
Hide Signatures
(in reply to xDIRTYSOUTHx)
       Post #: 3332
RE: RE: - 4/22/2011 4:46 AM
Dragonii
Score: 101
Last Login: 1/23/2012
Status: offline
rufaster.com should have the parts you need.
I have an Avalanche XP and these are the things that I have done/can recomend.
Rear shock tower is weak. Redcat sells an upgrade for like $22, or... I bought 2 regular rear shock towers on clearance for $1.50 each, bonded them together with glue and replaced the original screws with 2mm longer screws. rear shock tower is pretty strong now. I think the Hurricane has a different tower but the premice should still work.
Rear chassis brace mount is kind of weak. Replace plastic with this. It may just save you from replacing the whole chassis down the road.
www.rufaster.com/81611Y.aspx
Check front and rear diffs. They may need lube.
If your rear upper arm fixing block is plastic you may want to consider this part. The stock plastic ones can flex on a hard landing and allow the rear susspension to pop loose.
www.rufaster.com/81605B.aspx
Other things I have done is to change the muffler and aif filter.
This is my Avalanche. The pipe has now been remounted so that the exhaust points down.
That's all I can think of for now.
Hide Signatures
(in reply to Titaniumracingtiger)
       Post #: 3333
RE: - 4/22/2011 6:51 AM
Titaniumracingtiger
Score: 100
Status: offline
Thank you very much for the info. After looking over that site and also through my parts bin, it looks like I should be able to have the buggy up an running for about $30. I think I'm going to convert it to a GT Class on-road car that seems to be all the rage in the club scene.
Hide Signatures
(in reply to Dragonii)
       Post #: 3334
RE: RE: - 4/24/2011 5:59 AM
Dragonii
Score: 101
Status: offline
There was a street car version of the XP, the Typhoon.
You could find parts for it to help.
www.rcuniverse.com/magazine/article_display.cfm
Hide Signatures
       Post #: 3335
RE: - 5/25/2011 9:58 PM
NewRageRC
Score: 100
Last Login: 4/8/2013
Status: offline
I bent an axle stub on my Backdraft 3.5 and Redcat is out of stock. Anyone know of a suitable replacement? I can get parts for pretty much any other brand locally. Here's the part I'm talking about:
Hide Signatures
(in reply to zymurgy)
       Post #: 3336
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
