POWER SUPPLY PC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> POWER SUPPLY PC
Page: [1]
Login
POWER SUPPLY PC - 1/15/2006 5:09:14 PM
ZX1
Status: offline
any one know if a pc power supply can push out 10-20 amps and how do you wire it all up thanks
       Post #: 1
RE: POWER SUPPLY PC - 1/15/2006 5:22:05 PM
R/C fan-addict
Status: offline
umm this is an R/C forum...
_____________________________
Savage 25 RTR|Emaxx w/ dual s-600 setup|TA-05|TLT (x2) |Baja King|TRF415 w/ GTB 4.5|Tamiya Pajero|Jammin CRT.5 BL
(in reply to ZX1)
       Post #: 2
RE: POWER SUPPLY PC - 1/15/2006 5:44:24 PM
Doahh
Status: offline
Yeah he's looking for one to power his charger
Racing Cars: FT 18T with Mamba 8000kv system, XXX-S with 24T Birdman Pro Pro motor and Novak GTB, FT RC10T4 with Chamelion and GTB
Sponsored by: Driven Pro
Performance Devices
BoomBoomBatteries
(in reply to R/C fan-addict)
       Post #: 3
RE: POWER SUPPLY PC - 1/15/2006 5:51:48 PM
ZX1
Status: offline
DUHH
       Post #: 4
RE: POWER SUPPLY PC - 1/15/2006 5:52:10 PM
kostaktinos_mt
Status: offline
i suppose you want to use a pc power supply to power chargers, right?
any pc power supply capable of delivering 9-10 amps minimum at the 12V output will be OK. i use an old 300W one, which gives 15 amps at 12V and i use both the e-zilla`s GT charger and the Duratrax intellipeak charging at full amps without any problems. around 9amps for the GT and another 5-6 for the intellipeak are needed, but the power supply never gets even warm. great deal...i bought it used for 5euros! you can get a new pc power supply for 20$ or less. keep in mind that the wattage of a PSU is not the best consultant. i have seen PSUs with 400W output delivering only 10amps at the 12V output wires. all PSUs have a label on them which notes the maximum amps delivered at each voltage state [-12V,-5V,-3.3V,3.3V,5V,12V]. be sure to check those specs and emphasize the +12V one. that is the one you will be using for RC DC chargers. for full 12V stable voltage capability, 99.9% of PSUs have to have a small load on the 5V output as well. use a bulb or something there and you will get the smooth 12V output. you can also keep a pair of 5V/Ground output leads/wires as well to break in motors or power a lathe or so. to power on the pc ps, you need to attach a switch [or solder permanently] to the power_OK/Power_ON wire [usually that is purple] to the ground [usually any black wire]. if you have a pc mainboard/motherboard manual, open it and find the page with the ATX connector chart [nearly all MB manuals have this chart] to find the power_on wire that has to be connected to the ground for the ps to power on. if you don`t have a manual, go to a mainboard manufacturer`s web page and download one. hope that helps....
"the only thing that i know for sure, is that i am sure i know nothing..." --socrates
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
