Can I charge a 6V (5cell) pack with JR Wall charger?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Can I charge a 6V (5cell) pack with JR Wall charger?
Page: [1]
Login
Can I charge a 6V (5cell) pack with JR Wall charger? - 1/20/2002 6:13:51 AM
Joe McBride
Status: offline
I have a 6V 1400mah pack and my JR wall charger is rated 5.8V and 150ma. Will this charger work?
       Post #: 1
Can I charge a 6V (5cell) pack with JR Wall charger? - 1/20/2002 9:33:52 PM
jjkplace
Status: offline
nope, get a good quality peak charger and you can do all your batteries.
(in reply to Joe McBride)
       Post #: 2
Re: Can I charge a 6V (5cell) pack with JR Wall charger? - 1/21/2002 8:46:35 AM
Jackjet
Status: offline
[QUOTE]Originally posted by AAAA
[/QUOTE]
AAAA,
yes it will work-just check your output voltage of your wall charger with a dig. voltmeter -if it reads at least 6.80 to 7.50 vdc-you are good to go.
Jackjet
< Message edited by Jackjet -- Jan 21 2002 3:50AM >
_____________________________
Jack Jet Williams
Hesperia,Ca
       Post #: 3
Can I charge a 6V (5cell) pack with JR Wall charger? - 1/21/2002 7:09:11 PM
howardm4
Status: offline
I strongly doubt it'll work. If he checks the output of the wallwart
w/o a pack connected, he'll get a falsely high reading. Once the batttery
is connected, I'm sure it'll drop to the 5.8ish rating which isn't enough.
       Post #: 4
Charging 6V pack - 1/21/2002 11:41:54 PM
RJConnet
Status: offline
The output of the ordinary wall-wart charger is DC with a large AC component riding on top of the DC. As such, most voltmeters available to the hobbyist will not accurately give you any good information if you check the output unloaded. If you connect it to a battery load, the battery acts as a large capacitor smoothing out the DC to a point that a DC voltmeter will give you an accurate reading.
If you really want an accurate idea what the charger is doing, plug an aileron extension on to the charger output. cut one of the power conductors and insert the meter (switched to milli-amps) in series with the power lead. Plug the extension in to the battery pack and read the milli-amp output. If it is close to 140 mA you are good for a C/10 charge rate for your 1400 mAH pack.
Bob C.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
