RE: CMP 160 sized Texan    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: CMP 160 sized Texan - 5/11/2008 10:42 PM
RCPILOT78
Score: 100
Last Login: 5/12/2013
Status: offline
ramduster......excellent choice on the at-6......great flyer....I originaly had the Euro Kit retracts in the plane but after a year of flying it the gear went to garbage...there not suited for grass fields....I replaced them with robarts 620 at-6 gear and they are stronger and look better installed...I advise anyone wanting to put retracts in this plane to purchase the Robart gear...they are not that difficult to install...a little more revisions to the gear mount area but well worth the effort....and don't forget to install flaps you will be surprised how well they work...
Hide Signatures
(in reply to ramduster)
       Post #: 476
RE: CMP 160 sized Texan - 5/11/2008 11:57 PM
ramduster
Score: 100
Last Login: 11/8/2011
Status: offline
Thanks I will take a look at the robart gear can't wait to get the plane here and get started. also what spinner should I use for this plane.
< Message edited by ramduster -- 5/12/2008 12:38 AM >
Hide Signatures
(in reply to RCPILOT78)
       Post #: 477
RE: CMP 160 sized Texan - 5/12/2008 7:38 AM
RCPILOT78
Score: 100
Status: offline
ramduster...the best spinner is the ( Truturn at-6 texan spinner ) its the same one that was used on the Midwest at-6 and I used the Zenoha G-26 engine that combination is perfect for this plane...
< Message edited by RCPILOT78 -- 5/12/2008 7:39 AM >
Hide Signatures
       Post #: 478
RE: CMP 160 sized Texan - 5/17/2008 1:03 PM
ramduster
Score: 100
Status: offline
Will the gas tank stopper that comes with the kit work with gas or is it glow fuel only.
Hide Signatures
       Post #: 479
RE: CMP 160 sized Texan - 5/17/2008 2:04 PM
jcflysrc
Score: 100
Last Login: 11/27/2010
Status: offline
The Robart gear will fit...with mods. The Sierra gear that Darrel offers are by far the best quality, and they are made for this plane. You get what you pay for. Mine operate flawlessly. No leaks, no hassles. Check em out.
_____________________________
It's all fun & games...till sombody gets hurt!
Hide Signatures
       Post #: 480
RE: CMP 160 sized Texan - 5/18/2008 4:15 AM
ramduster
Score: 100
Status: offline
Thanks I have a set of spring air retracts that I will be using but would still like to know if I will need to replace the tank stopper with one that is for gas only.
Hide Signatures
(in reply to jcflysrc)
       Post #: 481
RE: CMP 160 sized Texan - 5/18/2008 5:49 AM
mystar46
Score: 100
Last Login: 5/17/2013
Status: offline
ramduster,
The stopper included with the kit is for glow only.
The Dubro 400 gas stopper http://www.shopatron.com/product/part_number=400/101.0 is a good replacement. Don't forget the klunk line too!
Dave Eltringham
http://www.chestercountyrc.com
Hide Signatures
       Post #: 482
RE: CMP 160 sized Texan - 5/18/2008 12:14 PM
ramduster
Score: 100
Status: offline
Thanks that is what I was thinking.
Hide Signatures
(in reply to mystar46)
       Post #: 483
RE: CMP 160 sized Texan - 5/18/2008 10:36 PM
RCPILOT78
Score: 100
Status: offline
Any one needing parts for this model ..I found out that ( AKmodels ) has cowls and canopies for this plane I recently ordered a new canopy. He also offers the same at-6 for less money..
Hide Signatures
       Post #: 484
RE: CMP 160 sized Texan - 5/21/2008 4:21 AM
GUAIO
Score: 100
Last Login: 5/21/2013
Status: offline
I'm going to start building mine soon....any issues with the CG??? does the recomended CG works ok??
Hide Signatures
       Post #: 485
RE: CMP 160 sized Texan - 5/21/2008 7:01 AM
RCPILOT78
Score: 100
Status: offline
GUAIO...the CG is fine I just made sure the plane ballanced a little nose down 3 to 4 degrees at the recomended CG...
Hide Signatures
(in reply to GUAIO)
       Post #: 486
RE: CMP 160 sized Texan - 5/23/2008 10:16 PM
BenWillis
Score: 100
Last Login: 1/3/2011
Status: offline
RCPILOT,
I'm back working on my plane to get it ready to fly in a few weeks. I'm still trying to solve my wing tube issue. Can anyone confirm for me the outside diameter of the wing tube that came in your kit? Mine has got to be WRONG. It's not even close to a decent fit in either the inner or outer wing panels so it just wonr work as a tube for a three piece wing.
I'm thinking of calling the place that I ordered it but want to be sure first.
Ben in SC
Hide Signatures
       Post #: 487
RE: CMP 160 sized Texan - 5/24/2008 12:12 AM
RCPILOT78
Score: 100
Status: offline
Benwillis....the wing tubes on my at-6 measure 3/4 of an inch in diameter..and my metal tubes seem to measure just a slight hair under 3/4 inch...you may have to change the metal wing tube diameter to fit...the fit should be fairly close for both the solid wing and the three piece wing...to be a solid connection...some hobby shops and hardware stores sell aluminum tubes in different sizes....
Hide Signatures
(in reply to BenWillis)
       Post #: 488
RE: CMP 160 sized Texan - 5/26/2008 12:43 AM
Thunderbolt47
Score: 111
Last Login: 5/24/2013
Status: online
Where's the best place to purchase one of these Texans?
Also how many different color schemes do they come in?
Kelly
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
       Post #: 489
RE: CMP 160 sized Texan - 5/26/2008 9:40 AM
ScaleRCpilot
Score: 100
Status: offline
You can get one here http://ak-models.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=AKM&Category_Code=CMPWarBirds Good luck better hurry before they sell out!
SR/CP
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 490
RE: CMP 160 sized Texan - 5/27/2008 12:58 AM
mystar46
Score: 100
Status: offline
You can also get them at Nitroplanes http://www.nitroplanes.com/at6texan.html and RaidenTech http://www.raidentech.com/atte16082arf.html
Nitroplanes carries all 3 types Yellow/Red, Silver, Marines VMT-1
Dave Eltringham
Hide Signatures
(in reply to ScaleRCpilot)
       Post #: 491
RE: CMP 160 sized Texan - 5/27/2008 2:44 AM
ScaleRCpilot
Score: 100
Status: offline
Hows your plane coming mystar46?
SR/CP
Hide Signatures
       Post #: 492
RE: CMP 160 sized Texan - 5/27/2008 2:52 AM
mystar46
Score: 100
Status: offline
ScaleRCpilot,
It's doing really good, thanks for asking. I'm fabricating a tailwheel now and my Sierra retracts should be here tomorrow. After the gear is installed it will be ready for test flight. After I get it maidened, I'll add more detail and make it look pretty.
The flaps came out better than I expected. I can't wait to fly it!
I'll post some pictures soon and some video of the maiden flight.
Only 7 weeks until Warbirds Over Delaware.
Dave Eltringham
Hide Signatures
       Post #: 493
RE: CMP 160 sized Texan - 5/27/2008 8:45 AM
ScaleRCpilot
Score: 100
Status: offline
Mystar46,
I can't wait for the video! I have been finishing my work shop and still have a few things to finish before I can begin on my silver t-6. I will be ordering the Serria retracts soon, so I will have them. I will add flaps as well. Probably G-26 but still have not ruled out a big ole 4 Stroker yet! And a 2.4GHz Radio system. We have a couple weeks to go here before the Warbirds over Bomberfield should be a nice event but its already hot down here. Never seen 100 degree temps in May. Good Luck with your t-6!
SR/CP
Hide Signatures
       Post #: 494
RE: CMP 160 sized Texan - 5/27/2008 5:12 PM
mystar46
Score: 100
Status: offline
Thanks! Good luck with yours too.
Dave Eltringham
Hide Signatures
       Post #: 495
RE: CMP 160 sized Texan - 6/1/2008 8:33 AM
GUAIO
Score: 100
Status: offline
guys that used gas engines...are you using rubber mounts to reduce vibration?? if yes...what brand??? I cant find any
Hide Signatures
       Post #: 496
RE: CMP 160 sized Texan - 6/2/2008 2:26 AM
trevtt600
Score: 100
Last Login: 12/14/2009
Status: offline
were is everyone getting their cockpits for this T6?
Hide Signatures
(in reply to GUAIO)
       Post #: 497
RE: CMP 160 sized Texan - 6/2/2008 4:33 AM
gridgod
Score: 100
Last Login: 6/12/2010
Status: offline
i have the nitro at6 but i dont have retracts i really got a bunch of good ideas from all of you guys. i am running g38 with a mej carbon fiber 16 11 three blade prop and 2 and a half inch da standoffs but i do have to order a custom cowl 2 and 3/4 longar i am getting through fiberglass specialties .com they seem to have alot of stuff and the cowl is only 36 bucks unpainted
Hide Signatures
(in reply to mugenkidd)
       Post #: 498
RE: CMP 160 sized Texan - 6/2/2008 4:41 AM
ScaleRCpilot
Score: 100
Status: offline
Trevtt600,
I don't know of a bolt-in interior and think most are being built from scratch.
Good Luck!
SR/CP
GUAIO, Check with http://bennettbuilt.com/index.html Go to page 4 also check out the site if those are not the right ones for your mtr.
Also Good Luck!
SR/CP
Hide Signatures
(in reply to trevtt600)
       Post #: 499
RE: CMP 160 sized Texan - 6/2/2008 5:37 PM
mystar46
Score: 100
Status: offline
I ran my engine for the first time yesterday. I have the Zenoah G-26ei. This is the best motor out of the box that I've ever owned. It started right up with an electric starter, did not need any tuning at all, and started by hand the second time on the 4th flip. Here's a quick video - http://www.youtube.com/watch?v=BsQ-qWMkWMA
I had some problems with my elevator control and need to do it a different way. Glad I found out on the ground instead of in the air.
Dave Eltringham
Hide Signatures
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
