RE: CMP 160 sized Texan    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  22 23 [24] 25 26 27 28 29 30 31   next >   >>
Login
RE: CMP 160 sized Texan - 11/29/2008 5:46 PM
speedpro 1
Score: 100
Last Login: 5/16/2013
Status: offline
thank you very much( so you didnt space out any for right thrust? )i wasnt sure because it looked like the engine mount to prop driver was 5 1/2 inch and firewall to front of cowl was also close to 5 1/2 now i known it will fit because yours looks perfect
Hide Signatures
(in reply to mystar46)
       Post #: 576
RE: CMP 160 sized Texan - 11/30/2008 6:10 AM
cpsdd56
Score: 100
Last Login: 11/28/2010
Status: offline
Ordered my AT6 on black friday from nitro, started to collect parts today. Got a kick **** deal on crrc gf26i from Valley Veiw ,started to look for retracts and got a hit on centurys site but almost fell down when I saw the price. Are they trying to punish people who buy CMP products. Over100$ more than any other set of 2 wheel retracts. makes Sierra retracts look pretty cheap. Id love to hear from Century why their retracts that are obviously of lesser quality are worth 400$ when I could get Sierra's with Air kit for a little over 300$
Hide Signatures
(in reply to speedpro 1)
       Post #: 577
RE: CMP 160 sized Texan - 11/30/2008 6:52 AM
RCPILOT78
Score: 100
Last Login: 5/12/2013
Status: offline
dd56 .....I found that the Robart AT-6 gear worked the best...requires a little surgery to install not a problem..I have over 200 flights on mine and never gave me a problem...and cost I believe around $280....and don't let that price fool you they are very stout...got them from Tower Hobbies.. good luck
Hide Signatures
(in reply to cpsdd56)
       Post #: 578
RE: CMP 160 sized Texan - 11/30/2008 7:05 AM
cpsdd56
Score: 100
Status: offline
Surgerys no problem, been a modelchopper from way back. Are the robarts for a Midwest kit or something else. If you have a part# Id appreciate it. Also is that price for complete setup.
Thanks Tim
Hide Signatures
(in reply to RCPILOT78)
       Post #: 579
RE: CMP 160 sized Texan - 11/30/2008 7:17 AM
RCPILOT78
Score: 100
Status: offline
Yes they are the ones from the Midwest at-6.... #620's ..and when I purchased mine two years ago it included everything...you will have to check current package....and again don't fret the surgery its so easy I used my dremel tool and opened the gear locations and replaced the mounts to accomodate the Robarts with hardwood ribs..
Hide Signatures
       Post #: 580
RE: CMP 160 sized Texan - 11/30/2008 7:32 AM
cpsdd56
Score: 100
Status: offline
Mmmmmm I can smell the wood and fiberglass burning now!
Hide Signatures
       Post #: 581
RE: CMP 160 sized Texan - 11/30/2008 7:34 AM
RCPILOT78
Score: 100
Status: offline
Oh yea Tower price is $259 for the gear and $37.00 for the air kit
Hide Signatures
       Post #: 582
RE: CMP 160 sized Texan - 11/30/2008 7:58 AM
Jack Devine
Score: 100
Last Login: 5/17/2013
Status: offline
The best gear for this airplane hands down are the Sierra units. They are very well made, Strong and they drop right in. Do some reinforcing on the gear blocks especially if you purchased the silver AT6 with the green stripes. That is not a CMP model but a copy of the CMP AT6. I think it's the best looking of the three AT6 offerings. The green striped plane is the same plane as close as I can see and I have one of each. The air valve, hoses and tank that come with the Sierra gear are all very high quality pieces too. Call Darryl at Sierra and see if he has them instock. He had them in stock when I called and I had the gear in my possession in about three days.
Jack
Hide Signatures
       Post #: 583
RE: CMP 160 sized Texan - 11/30/2008 8:01 AM
Jack Devine
Score: 100
Status: offline
Sorry this posted twice so I cancelled the rerun.
< Message edited by Jack Devine -- 11/30/2008 8:07 AM >
Hide Signatures
       Post #: 584
RE: CMP 160 sized Texan - 11/30/2008 7:05 PM
harleydoberman
Score: 100
Status: offline
Post 163 & 164 show the robarts installed. Great gear no problems.
tony
Hide Signatures
       Post #: 585
RE: CMP 160 sized Texan - 12/2/2008 3:58 AM
speedpro 1
Score: 100
Status: offline
for you guy running the g26ei are you mounting the module inside if so are you having to make a huge hole in the firewall to get the spark plug cable through
Hide Signatures
(in reply to harleydoberman)
       Post #: 586
RE: CMP 160 sized Texan - 12/2/2008 4:56 AM
mystar46
Score: 100
Status: offline
Yes, but not huge holes. Just big enough to get it through.
_____________________________
Dave Eltringham
http://www.chestercountyrc.com
Hide Signatures
       Post #: 587
RE: CMP 160 sized Texan - 12/2/2008 5:10 AM
speedpro 1
Score: 100
Status: offline
thanks mystar for the imfo once again you are a big help on my build. just that spark plug cap looked pretty big so i thought i better ask
< Message edited by speedpro 1 -- 12/2/2008 5:13 AM >
Hide Signatures
       Post #: 588
RE: CMP 160 sized Texan - 12/2/2008 6:17 AM
mystar46
Score: 100
Status: offline
The hole I made for mine is like a rounded teardrop shape. You just need it big enough to put the round end of the plug boot straight in and then rotate it all the way through. I'll see if I can get a picture for you.
Dave Eltringham
Hide Signatures
       Post #: 589
RE: CMP 160 sized Texan - 12/2/2008 9:47 PM
cpsdd56
Score: 100
Status: offline
Hey all I just got off the phone with Century Jet. Called to find out why their retracts for CMP AT6 was $110 more than for Midwest AT6. Turns out price was misprint and should be $290 not $400 and its complete with air system. Ordered a set today so well see how they work out. Tim
Hide Signatures
       Post #: 590
RE: CMP 160 sized Texan - 12/3/2008 8:20 AM
speedpro 1
Score: 100
Status: offline
a pic would be great
Hide Signatures
       Post #: 591
RE: CMP 160 sized Texan - 12/3/2008 3:43 PM
telejojo
Score: 130
Status: offline
I just ordered one fron Nitroplanes 160 size........is it the same airplane as the CMP?
Hide Signatures
       Post #: 592
RE: CMP 160 sized Texan - 12/4/2008 8:10 AM
speedpro 1
Score: 100
Status: offline
yes its a cmp
Hide Signatures
(in reply to telejojo)
       Post #: 593
RE: CMP 160 sized Texan - 12/5/2008 5:35 AM
patzane
Score: 100
Last Login: 1/3/2012
Status: offline
Pay day 2morrow have to order my retracts.
Don't go where the path leads
But go where there is no path
Hide Signatures
       Post #: 594
RE: CMP 160 sized Texan - 12/8/2008 1:52 AM
mystar46
Score: 100
Status: offline
Speedpro1,
Here's a picture for you. Sorry it took me so long. Hope this helps.
As you can see, I have the plug wire, ground wire, and tank vent all exiting through the same hole in the firewall. If you make it a rounded teardrop shape you can get the plug cap through by rotating it around the 90 degree bend in it.
Click to see fullsize image.
Click for fullsize
Dave Eltringham
Hide Signatures
(in reply to patzane)
       Post #: 595
RE: CMP 160 sized Texan - 12/8/2008 5:35 AM
speedpro 1
Score: 100
Status: offline
it looks just like i thought it would by your description thanks for the picture. now for a new problem i tried thier set up on the elevator. its looks like a update from the instruction mine has rubber looking stoppers with set screws with a carbon fiber tube. but it does not hold the elevator secure enough for my liking. what other options can i try
Hide Signatures
       Post #: 596
RE: CMP 160 sized Texan - 12/11/2008 3:19 PM
telejojo
Score: 130
Status: offline
The center section and wings, does all that just epoxy together? it don't look very strong.I called Sierra about rhe retracts and all I got was a recording I wonder if they are closed for x-mas?
Hide Signatures
       Post #: 597
RE: CMP 160 sized Texan - 12/11/2008 8:35 PM
RCPILOT78
Score: 100
Status: offline
jo jo.. the wings on my t-6 are not epoxied together..the outer panals just slide into the wing tubes and are secured with bolts...over 200 flights no wing problems the wing is strong...I wanted a three peice wing to facilitate easier transporting...If you decide on a one piece wing it will be strong....as far as Seirra being closed for holidays that dosen't sound right..maybe the day before the holiday but closed now ?????
Hide Signatures
       Post #: 598
RE: CMP 160 sized Texan - 12/12/2008 12:13 AM
telejojo
Score: 130
Status: offline
I don't see any way of putting bolts on it the center is solid except for the dowel and wing tube holes.It looks like I will have to drill out the dowel holes to make them fit as it is.I may foam the wings and center section.
Hide Signatures
       Post #: 599
RE: CMP 160 sized Texan - 12/14/2008 7:25 AM
patzane
Score: 100
Status: offline
I have a question about CG. Is it inverted or upright. Also did you all cg from wing tip or spot clostest to fuslage.
Hide Signatures
       Post #: 600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
