RE: CMP 160 sized Texan
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  13 14 15 16 17 [18] 19 20 21 22   next >   >>
Login
RE: CMP 160 sized Texan - 1/14/2008 1:35:36 AM
mystar46
Status: offline
I've received my VMT-1 AT-6 from Nitroplanes. It came with some damage but Nitroplanes immediately shipped out some replacement parts to me and they should be here Wednesday. If you're looking to buy one of these CMP AT-6's I'd recommend Nitroplanes. They stand by what they sell.
I see why the Marines version is a little cheaper than the other two. Ironically, it's also the most accurate to the full scale plane. It comes painted but none of the decals are pre-applied.
I finally found another good picture of the full scale plane on an aircraft photo database in England. I then saw a website link painted on the plane, went to it and found where the full scale plane is based (in Australia) and a couple more good photos. I've emailed the company that owns it and asked if they have any more photos.
For you guys with the silver Scream N Rebel plane, I have a good illustration from a Squadron/Signal Pub. book. If you would like a bigger better copy of it, just PM me and I'll email it to you.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Dave Eltringham
http://www.chestercountyrc.com
(in reply to ScaleRCpilot)
       Post #: 426
RE: CMP 160 sized Texan - 1/14/2008 5:09:32 PM
darjen38
Status: offline
Sorry to bother you, any chance you could show some picture on how you connected the flaps to the servo? Nice job excelent pictures
(in reply to RCPILOT78)
       Post #: 427
RE: CMP 160 sized Texan - 1/14/2008 7:13:05 PM
AlphaWhisky
Status: offline
Hi mystar46,
Can you advise where in Australia that aircraft is based. I`m going over there in a while and wouldn`t mind tracking it down for some photos if I was in the vicinity.
Alan W
From Tauranga - in the aptly named Bay of Plenty.
(in reply to mystar46)
       Post #: 428
RE: CMP 160 sized Texan - 1/14/2008 7:19:49 PM
jcflysrc
Status: offline
When I added my flaps, I put an control horn on the middle flap. The Servo is mounted on the top of the center wing section. The pushrod is also only visible on the top side...the horn sticks up through the wing. Hope that makes sense. The weather is really nice here, and since I have not flown mine yet, I'm heading out to the field right now. I will give my impressions of the first flight here later on tonight. Wish me luck!
It's all fun & games...till sombody gets hurt!
(in reply to AlphaWhisky)
       Post #: 429
RE: CMP 160 sized Texan - 1/14/2008 8:48:05 PM
mystar46
Status: offline
quote:
Hi mystar46,
Alan W
Hi Alan,
The website that I got off the plane was http://www.shortstop.com.au and the address that they have listed on the web site is:
Shortstop Jet Charter
Hangar 5, Wirraway Road,
Essendon Airport
VIC, Australia 3041
I guess that's why the plane is named "Miss Victoria".
It looks like they'll take you on a training mission in it for $795.
If you do get there and take pictures, I'd love to have a set. Thanks!
< Message edited by mystar46 -- 1/14/2008 8:49:02 PM >
Dave Eltringham
(in reply to jcflysrc)
       Post #: 430
RE: CMP 160 sized Texan - 1/14/2008 8:51:09 PM
mystar46
Status: offline
I've found another plane in the US with the same registration numbers. The US plane is an SNJ-6 and the AU plane is an SNJ-5B. Their markings are slightly different. One must be a copy of the other.
Dave Eltringham
       Post #: 431
RE: CMP 160 sized Texan - 1/16/2008 3:36:37 AM
mystar46
Status: offline
Question for anyone using the G26. Are you using the stock muffler or did you get an aftermarket muffler?
Dave Eltringham
       Post #: 432
RE: CMP 160 sized Texan - 1/17/2008 10:09:23 AM
jcflysrc
Status: offline
I'm using the stock muffler. My maiden went smooth too. Plane is a great flyer. Little aileron trim was needed, and the G26 pulls it along nicely at half throttle. landing was uneventful, but takeoff did require staying on the rudder. I am pleased with the way this plane flew.
       Post #: 433
RE: CMP 160 sized Texan - 1/17/2008 3:18:51 PM
mystar46
Status: offline
Congrats jcflysrc!
Did you use flaps at all?
Dave Eltringham
       Post #: 434
RE: CMP 160 sized Texan - 1/17/2008 6:35:08 PM
ScaleRCpilot
Status: offline
jcflysrc,
Glad it went well sounds like its a good flyer. Congads and may you have many great flights with it.
SR/CP
       Post #: 435
RE: CMP 160 sized Texan - 1/17/2008 7:39:23 PM
Ryon L.
Status: offline
Hello All,
Just got back from the AMA convention. Had a great time. Concerning the wing tube, I sanded the tube with 60 grit paper then applied a thin coat of 30 min. epoxy over it. This morning I slide it in to the center section, with no sanding, and it fit very well. There is no play in the tube now. Does anyone think there could be the potential for the epoxy to crack off of the tube? Maybe I should try fiberglass 3/4 oz cloth rapped around the wing tube. Any thoughts?
       Post #: 436
RE: CMP 160 sized Texan - 1/17/2008 8:35:26 PM
RCPILOT78
Status: offline
Ryon...I think you will be fine with 30 minute epoxy applied, that stuff sticks well and is strong...I was thinking of suggesting that fix to all who have a loose fitting wing tubes...If the fit is ok leave it...there is no movement of that tube other than removing it when taking the wing apart...and thats not enough to wear or loosen the epoxy...
(in reply to Ryon L.)
       Post #: 437
RE: CMP 160 sized Texan - 1/17/2008 10:21:41 PM
Ryon L.
Status: offline
I have sanded the epoxy with 60 grit now, and reapplied another coat to smooth out the high and low spots. When the epoxy was just a little tacky I rolled the wing tube on the counter to smooth it out a little more. Seems to work pretty well.
       Post #: 438
RE: CMP 160 sized Texan - 1/18/2008 4:10:30 AM
Ryon L.
Status: offline
The application of epoxy on the wing tube and then sanding it to fit the center section worked great. Now time to epoxy the other end of the tube into the wing section. Engine is installed.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 439
RE: CMP 160 sized Texan - 1/20/2008 3:36:10 AM
ScaleRCpilot
Status: offline
Ryon L.
You gonna use that radial dummy engine or keep it clear?
SR/CP
