RE: CMP 160 sized Texan
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  13 14 15 16 17 18 [19] 20 21 22   next >   >>
Login
RE: CMP 160 sized Texan - 1/25/2008 6:52:38 AM
ScaleRCpilot
Status: offline
Patzane and gridgod,
you might try increasing the size of the rx pack and move it as far forward the CG as possible.
Also if you are using a push rod for the rudd you might switch to a pull- pull wire system.
If you have to add wieght try adding a wieghted prop nut such as a Higgly Heavy hub.
If you are using one of the new electonic ignition gas motors you could increase the battery there too.
Also look at the wheels- can you use a lighter or heavier- but still scale looking wheel (like a plastic from Robart). Don't forget the tail wheel too!
I hope these ideas help and good luck!
SR/CP
< Message edited by ScaleRCpilot -- 1/25/2008 6:54:53 AM >
(in reply to patzane)
       Post #: 451
RE: CMP 160 sized Texan - 1/25/2008 8:20:10 AM
jcflysrc
Status: offline
G26 on mine and it required 8oz. of additional weight in the nose. I have Sierra retracts also. It is perfectly powered with a G26.
_____________________________
It's all fun & games...till sombody gets hurt!
       Post #: 452
RE: CMP 160 sized Texan - 1/25/2008 8:44:09 AM
AlphaWhisky
Status: offline
Mine has G-26 - not e.i. - and Eurokit retracts and required 10oz weight up front. What prop are you using on the G-26?
Alan W
From Tauranga - in the aptly named Bay of Plenty.
(in reply to jcflysrc)
       Post #: 453
RE: CMP 160 sized Texan - 1/25/2008 8:53:48 PM
jcflysrc
Status: offline
I'm using an Mejzlik 18x6.
(in reply to AlphaWhisky)
       Post #: 454
RE: CMP 160 sized Texan - 1/26/2008 11:39:43 PM
gridgod
Status: offline
when i balance my texan should i do it inverted or up rite
       Post #: 455
RE: CMP 160 sized Texan - 1/27/2008 6:24:04 AM
ScaleRCpilot
Status: offline
Inverted
SR/CP
(in reply to gridgod)
       Post #: 456
RE: CMP 160 sized Texan - 2/16/2008 10:58:40 AM
waldo
Status: offline
My Texan has flown at last. G26 is absolutely fantastic in this model. Weight 16lbs, no flaps, balanced without additional weight with battery well forward. Robart 620 gear and Dubro 4.5 wheels. Stalled it at altitude with idle power, left wing eventually dropped but nose was quiet high so not scary at all. Landing was no problem. This thread has been a great help particularly with the suggestions on the mods for the Robart gear. Thanks to all.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to ScaleRCpilot)
       Post #: 457
RE: CMP 160 sized Texan - 2/16/2008 4:45:34 PM
RCPILOT78
Status: offline
WALDO plane looks great.....congrats on the maiden flight....I like the way the robart gear look on yours they are much more scale looking than the Euro Kit ones and probably less maintenance prone than mine....I am almost ready to tear the Euro kit ones out and install the robart gear.....
(in reply to waldo)
       Post #: 458
RE: CMP 160 sized Texan - 2/16/2008 7:21:16 PM
mystar46
Status: offline
Well done waldo! Your plane really does look great. I just got my RAM landing lights today, so that should keep me busy for a while.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dave Eltringham
http://www.chestercountyrc.com
(in reply to RCPILOT78)
       Post #: 459
RE: CMP 160 sized Texan - 2/17/2008 1:37:04 AM
Ryon L.
Status: offline
Hello All, I am finally finished with my Texan! Spektrum radio, Robart 620s with gear doors and 4" wheels, operable RAM landing and nav. lights, split flaps (center section only), Bcma 40cc gas engine and a three peice wing. The joy of completion. PRICELESS. I would like to thank everyone for their great ideas and knowledge on this thread, it makes the building experience that much more enjoyable.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to mystar46)
       Post #: 460
RE: CMP 160 sized Texan - 2/17/2008 4:31:43 AM
RCPILOT78
Status: offline
Ryon...great pics......you will be glad you went with the 3 piece wing great for transport...your robart gear look very scale....have fun with it, its a great flyer..
(in reply to Ryon L.)
       Post #: 461
RE: CMP 160 sized Texan - 2/17/2008 6:34:09 PM
ScaleRCpilot
Status: offline
Waldo,
Congrads on a job well done! She looks real nice!
To RyonL: Lights look spectacular! Look forward to hearing of your successful flight as well!
As for me all projects are on hold pending completion of my new 12'x14' Shop.
SR/CP
       Post #: 462
RE: CMP 160 sized Texan - 2/22/2008 1:59:07 AM
Ryon L.
Status: offline
Hello All, I flew the Texan today! Also pics of the "crew". Total weight dry is 18 lbs 13.6 oz..
Click for fullsize
Click for fullsize
       Post #: 463
RE: CMP 160 sized Texan - 2/22/2008 3:58:40 AM
RCPILOT78
Status:
