RE: CMP 160 sized Texan
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Stuka - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $99.98   |  7/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  13 14 15 16 17 18 19 [20] 21 22   next >   >>
Login
RE: CMP 160 sized Texan - 5/11/2008 7:42:33 PM
RCPILOT78
Status: offline
ramduster......excellent choice on the at-6......great flyer....I originaly had the Euro Kit retracts in the plane but after a year of flying it the gear went to garbage...there not suited for grass fields....I replaced them with robarts 620 at-6 gear and they are stronger and look better installed...I advise anyone wanting to put retracts in this plane to purchase the Robart gear...they are not that difficult to install...a little more revisions to the gear mount area but well worth the effort....and don't forget to install flaps you will be surprised how well they work...
(in reply to ramduster)
       Post #: 476
RE: CMP 160 sized Texan - 5/11/2008 8:57:15 PM
ramduster
Status: offline
Thanks I will take a look at the robart gear can't wait to get the plane here and get started. also what spinner should I use for this plane.
< Message edited by ramduster -- 5/11/2008 9:38:00 PM >
(in reply to RCPILOT78)
       Post #: 477
RE: CMP 160 sized Texan - 5/12/2008 4:38:23 AM
RCPILOT78
Status: offline
ramduster...the best spinner is the ( Truturn at-6 texan spinner ) its the same one that was used on the Midwest at-6 and I used the Zenoha G-26 engine that combination is perfect for this plane...
< Message edited by RCPILOT78 -- 5/12/2008 4:39:47 AM >
       Post #: 478
RE: CMP 160 sized Texan - 5/17/2008 10:03:57 AM
ramduster
Status: offline
Will the gas tank stopper that comes with the kit work with gas or is it glow fuel only.
       Post #: 479
RE: CMP 160 sized Texan - 5/17/2008 11:04:39 AM
jcflysrc
Status: offline
The Robart gear will fit...with mods. The Sierra gear that Darrel offers are by far the best quality, and they are made for this plane. You get what you pay for. Mine operate flawlessly. No leaks, no hassles. Check em out.
_____________________________
It's all fun & games...till sombody gets hurt!
       Post #: 480
RE: CMP 160 sized Texan - 5/18/2008 1:15:59 AM
ramduster
Status: offline
Thanks I have a set of spring air retracts that I will be using but would still like to know if I will need to replace the tank stopper with one that is for gas only.
(in reply to jcflysrc)
       Post #: 481
RE: CMP 160 sized Texan - 5/18/2008 2:49:16 AM
mystar46
Status: offline
ramduster,
The stopper included with the kit is for glow only.
The Dubro 400 gas stopper http://www.shopatron.com/product/part_number=400/101.0 is a good replacement. Don't forget the klunk line too!
Dave Eltringham
http://www.chestercountyrc.com
       Post #: 482
RE: CMP 160 sized Texan - 5/18/2008 9:14:10 AM
ramduster
Status: offline
Thanks that is what I was thinking.
(in reply to mystar46)
       Post #: 483
RE: CMP 160 sized Texan - 5/18/2008 7:36:17 PM
RCPILOT78
Status: offline
Any one needing parts for this model ..I found out that ( AKmodels ) has cowls and canopies for this plane I recently ordered a new canopy. He also offers the same at-6 for less money..
       Post #: 484
RE: CMP 160 sized Texan - 5/21/2008 1:21:56 AM
GUAIO
Status: offline
I'm going to start building mine soon....any issues with the CG??? does the recomended CG works ok??
       Post #: 485
RE: CMP 160 sized Texan - 5/21/2008 4:01:55 AM
RCPILOT78
Status: offline
GUAIO...the CG is fine I just made sure the plane ballanced a little nose down 3 to 4 degrees at the recomended CG...
(in reply to GUAIO)
       Post #: 486
RE: CMP 160 sized Texan - 5/23/2008 7:16:43 PM
BenWillis
Status: offline
RCPILOT,
I'm back working on my plane to get it ready to fly in a few weeks. I'm still trying to solve my wing tube issue. Can anyone confirm for me the outside diameter of the wing tube that came in your kit? Mine has got to be WRONG. It's not even close to a decent fit in either the inner or outer wing panels so it just wonr work as a tube for a three piece wing.
I'm thinking of calling the place that I ordered it but want to be sure first.
Ben in SC
       Post #: 487
RE: CMP 160 sized Texan - 5/23/2008 9:12:09 PM
RCPILOT78
Status: offline
Benwillis....the wing tubes on my at-6 measure 3/4 of an inch in diameter..and my metal tubes seem to measure just a slight hair under 3/4 inch...you may have to change the metal wing tube diameter to fit...the fit should be fairly close for both the solid wing and the three piece wing...to be a solid connection...some hobby shops and hardware stores sell aluminum tubes in different sizes....
(in reply to BenWillis)
       Post #: 488
RE: CMP 160 sized Texan - 5/25/2008 9:43:55 PM
Thunderbolt47
Status: offline
Where's the best place to purchase one of these Texans?
Also how many different color schemes do they come in?
Kelly
"Over Macho Grande Sir".... "Oh no, I''ll never get over Macho Grande"
       Post #: 489
RE: CMP 160 sized Texan - 5/26/2008 6:40:20 AM
ScaleRCpilot
Status: offline
