RE: CMP 160 sized Texan    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 160 sized Texan
Page: <<   < prev  22 23 24 25 26 27 [28] 29 30 31   next >   >>
Login
RE: CMP 160 sized Texan - 7/23/2009 11:12 PM
RCPILOT78
Score: 100
Last Login: 5/12/2013
Status: offline
GONZALO... glad to be of help....if there is one thing I hate is ...spending a fortune on equipment and find out too late its junk !!!!!!!!.....for what we pay for this equipment we should expect the VERY BEST.......JOE
Hide Signatures
(in reply to Gonzalo38)
       Post #: 676
RE: CMP 160 sized Texan - 8/8/2009 2:21 AM
Ryon L.
Score: 100
Last Login: 4/6/2013
Status: offline
Hello All,
Lost my Texan the other day. Flying straight and level the wing seperated from the fuse. Post crash reveiw showed that the wing mounting plate ( the approx. 3/32 3 ply wood plate the wing bolts screw through via blind nuts) and fuse. former and fiberglass broke. This allowed the wing to slide rearward enough that the front wing pin disengaged from its hole and the wing pulled off the plane taking the bottem rear of the fuse with it. The wing bolts along with the broken and torn wing mounting plate and 5" wide 14" long strip of bottem rear fiberglass fuse was still connected to the wing. I flew it a couple of years with a 40 cc gas engine and almost 20 lbs. flying weight. So I was probably exceeding the limits of the airframe. Thought I would share the experience with all. By reinforcing the wing attaching plate my would still be flying. Hope this will help save some planes.
Easy come, easy go.
Ryon L.
Hide Signatures
(in reply to RCPILOT78)
       Post #: 677
RE: CMP 160 sized Texan - 8/10/2009 6:24 AM
Meschmidt
Score: 100
Last Login: 5/10/2013
Status: offline
Finishing up my 3rd AT6. Same setup, Poulan 42, Spring Air retracts, 2.4 Spectrum radio. Hope to get better luck out of this plane as it flys so good and is relatively cheap for a big warbird. First one was lost on a bad battery (15 flights). Second one had a damn 35% Extra 330 get in my way (20 flights). Hopefully this one will last 100 or more flights! Paul
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Ryon L.)
       Post #: 678
RE: CMP 160 sized Texan - 8/11/2009 4:41 AM
droman
Score: 100
Last Login: 1/4/2012
Status: offline
Paul, do you glass the wins?
Hide Signatures
(in reply to Meschmidt)
       Post #: 679
RE: CMP 160 sized Texan - 8/11/2009 5:17 AM
Meschmidt
Score: 100
Status: offline
No, all stock covering except some weathering and panel lines with pencil and spray water based satin urethane on with spray gun. Urethane makes covering a lot tougher and doesn't wrinkle as much in hot sun. Paul
Hide Signatures
(in reply to droman)
       Post #: 680
RE: CMP 160 sized Texan - 8/13/2009 4:58 AM
droman
Score: 100
Status: offline
Hello all,
Does anybody have in photos the process of reinforcing the wins of the CMP AT-6?
Dax
Hide Signatures
       Post #: 681
RE: CMP 160 sized Texan - 8/20/2009 6:20 PM
F86-Sabre
Score: 100
Last Login: 1/19/2011
Status: offline
Guys,
could anyone upload a scan of the CMPRO 160 Texan CG and throws manual page ?
I'm fixing one up but I have no manual for it. :-(
The CG and throws page would do.
Thanks a lot!
Hide Signatures
       Post #: 682
RE: CMP 160 sized Texan - 8/21/2009 12:04 AM
Meschmidt
Score: 100
Status: offline
The wings themselves are pretty strong. It's the supplied aluminum tubes I wouldn't use. Replace them with 3/4" hardwood dowels cut the same length. Hey, F86 SABRE, go to Nitroplanes.com, click on warbirds, AT6, see the instruction manual and download it! There you go! Paul p.s. Flew my new AT6 last Sunday. Flies and lands perfectly!
Hide Signatures
       Post #: 683
RE: CMP 160 sized Texan - 8/21/2009 6:10 AM
F86-Sabre
Score: 100
Status: offline
Thanks a lot for the tip Paul
I downloaded the picture. Unfortunately the throws are not shown in the explosion drawing.
Can you give me an idea of the throws you are using on yours??
Hide Signatures
       Post #: 684
RCPILOT78
Score: 100
Status: offline
Meschmidt....I did one better with the wing tubes.....I inserted and epoxied wood dowels into the aluminum tubes....made them very strong 250+ flights and still going strong....great flying plane...
Hide Signatures
       Post #: 685
RE: CMP 160 sized Texan - 10/2/2009 2:16 AM
droman
Score: 100
Status: offline
Hello all
My AT-6 is in progress. I remove the insignias easy but the number in the fuselage were very difficult, I tried a lot of things that didn’t work so finally I painted over the numbers with Alclad Lacquers resulting in some weathering simulation over the fuselage. Next step are more painting job in the rudder and some preparation of the cabin.
This time I post a poor quality photo, next time I post a better one.
I hope to finish next week.
Dax
Click for fullsize
Hide Signatures
       Post #: 686
RE: CMP 160 sized Texan - 10/12/2009 1:41 AM
droman
Score: 100
Status: offline
Hello
This is my work of the cabin of my AT-6.
Regards
Dax
Click for fullsize
Hide Signatures
       Post #: 687
RE: CMP 160 sized Texan - 10/12/2009 6:15 AM
mystar46
Score: 100
Last Login: 5/17/2013
Status: offline
Lookin' good Dax!
It's pretty amazing what you can do with the photo-realistic images anymore.
That's going to be a nice looking ship.
_____________________________
Dave Eltringham
http://www.chestercountyrc.com
Hide Signatures
       Post #: 688
RE: CMP 160 sized Texan - 10/12/2009 7:06 AM
droman
Score: 100
Status: offline
More progress, finish the front control panel and the cabin is finish. In person the paint of the fuselage doesn't see like that, I think the flash of my camera is the reason to see like that.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mystar46)
       Post #: 689
RE: CMP 160 sized Texan - 10/18/2009 8:42 PM
UDET
Score: 100
Last Login: 5/20/2013
Status: offline
Hi Guy's
I have a CMP T-6 I stripped it glassed it put pannel lines painted it to look like Miss Behavin I have Sierra gear and a BME 44 for it . It came out real nice but I screwed the Canopy up and have been trying to get another one for eight month from Nitro Models and I keep getting the same BS answer please check our web site for new shipments. Do es anyone have and extra Canopy the would sell me?
Thanks Carl
Hide Signatures
       Post #: 690
RE: CMP 160 sized Texan - 10/18/2009 9:10 PM
Chad Veich
Score: 265
Status: offline
I think Wing Manufacturing sell the canopy for the old 81" span Midwest Texan which could probably be made to work.
Hide Signatures
(in reply to UDET)
       Post #: 691
RE: CMP 160 sized Texan - 10/19/2009 1:38 AM
RCPILOT78
Score: 100
Status: offline
UDET...I too had the same problem with Nitro Models..I ordered a new canopy and never got it from them....I had a heck of a time getting them to reimburse my credit card payment.......I finaly got a new one from AK-Models inc....there out of Iowa City IA.....they also sell the CMP At-6 kit and they are much easier to deal with... hope this helps...Nitro Models does not stock parts they told me thay had to wait for a damaged kit to be returned to get parts....NOT GOOD BUSINESS...
Hide Signatures
(in reply to UDET)
       Post #: 692
RE: CMP 160 sized Texan - 10/19/2009 5:39 AM
UDET
Score: 100
Status: offline
Thanks For your help I contacted AK-Models maybe they will help me.
I will also chek out Wings manufacturing.
Thanks again and Happy landing Carl
Hide Signatures
       Post #: 693
RE: CMP 160 sized Texan - 10/19/2009 8:28 PM
UDET
Score: 100
Status: offline
Hi all I contacted AK-MODELS by email last night and they responded in less then 20 minutes on a Sunday evening they took the time to respond to my email
WOW that is cool. They didn't have the part in stock but he said they will be in at the end of November that works for me.
Thanks again Carl
Hide Signatures
(in reply to UDET)
       Post #: 694
RE: CMP 160 sized Texan - 10/20/2009 2:33 AM
Meschmidt
Score: 100
Status: offline
Check with Hobbyking.com. They have parts for this plane too. The website is kind of hard to navigate thru, but their prices are real reasonable. I got this plane for $199! Paul
Hide Signatures
(in reply to UDET)
       Post #: 695
RE: CMP 160 sized Texan - 10/25/2009 6:43 PM
loukos
Score: 100
Last Login: 5/16/2013
Status: offline
Guys, finally finished my CMP Texan in the coulours of the Greek Airforce.
I modifyed the model to fit the Robart 620 retracts. Powered by an OS 160 twin Gemini with sullivan on-board glow, graupner digital servos and Weatronic 2.4 radio.
The wings are balsa covered and glassed, paint masks are custom cut from flightline graphics in the UK (highly recomended!!).
Test flight to follow soon
Regards
Loukis
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 696
RE: CMP 160 sized Texan - 10/29/2009 8:44 PM
UDET
Score: 100
Status: offline
Loukis.
Your model looks great. I like that you moved your tail wheel to a more scale location I did the same. Let us know how the OS 160 FS pulled the Texan around I thought about going to a 160 FS in mine sure would sound awesome.
Well good luck Carl
Hide Signatures
(in reply to loukos)
       Post #: 697
RE: CMP 160 sized Texan - 10/30/2009 7:05 AM
droman
Score: 100
Status: offline
HELP HELP
Hello, I have to balance my AT-6, it is not very clear the way the plans explain it, it say that the centre point is 117mm to 125mm from the leading edge of the wing, but what part of the wing, from the beginning next to the fuselage or where the fibreglass ended on the wing,next where the wood part begin, I am confuse.
If I balance it from where the wing begin next to the fuselage, I see that needed a lot of weight in the nose, but if I balance approximately where the fibreglass end it seen that it is well balance.
So the question is, the plans say 117mm to 125mm from the leading edge, which is the correct distance perpendicularly outward from the fuselage on the wing?
Dax
Click for fullsize
Hide Signatures
(in reply to UDET)
       Post #: 698
RE: CMP 160 sized Texan - 10/30/2009 4:34 PM
Meschmidt
Score: 100
Status: offline
Mine is balanced 4 1/2" from the wing leading edge, just outside of the gear pod. Flies great there! This plane needs alot of motor or nose weight to balance. Paul
Click for fullsize
Hide Signatures
       Post #: 699
RE: CMP 160 sized Texan - 10/30/2009 10:46 PM
mallen
Score: 100
Last Login: 12/6/2012
Status: offline
I'm new to this thread and thanks to everyone that has posted messages to it over the last few years. I've been interested in the CMP Texan for a few years now and since AK-models is running a special, I figured if I was to get one, now is the time. So I first did a search to see what all I could find out about it and the search brought me here. I've spent a few days reading everything everybody has posted and after all that, I just had to order a Texan...which should be here Monday!
Now for my question; It looks like most are running a Zenoah G26 but I was looking at going with one of the gassers that Hobbyking sales.....The XY26, RCG26, FTL26, or the Turnigy 26. Would like to know if anybody is running any of these and what you think and I'm also wondering if any of these 26's are the way to go or maybe I should consider putting a 40-50 size in it. I do like to have some extra power when needed and I will be flying off a grass field that can be a little rough at times. I just don't want to overpower it or cause an airframe failure because of trying to strap on too big of an engine......?????
Thanks for any and all help! Mark
Hide Signatures
       Post #: 700
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
