Red Tail Project TF P-51C with scale size 5.5" Spinner
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Focke Wulf FW 190 1/4 scale
Seller:  BAGOSTIX
Details:   $5,500.00   |  7/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Red Tail Project TF P-51C with scale size 5.5" Spinner
Page: [1] 2 3 4   next >   >>
Login
Red Tail Project TF P-51C with scale size 5.5" Spi... - 1/22/2006 1:33:55 AM
Spychalla Aircraft
Status: offline
I think it very fitting to duplicate the Tuskeegee Airmen Red Tail Project P-51C Mustang. I respect the accomplishments of the Tuskeegee Airmen and applaude the efforts being taken to put the full size Mustang back in the air. As a fitting start I went on the Red Tail web site yesterday (http://www.redtail.org/) and made a donation to get my certificate and commemorative rivet. Ordered a bunch of shirts too so I can be dressed appropriately when I fly this bird. This is a really cool airplane that is rich in history and exciting to follow as they work to restore it to flying condition.
Mine will be constructed from the Top Flite ARC Giant Scale P-51D Kit. I will be making a true scale fiberglass cowl for a larger 5.5 inch aluminum spinner. I will also be constructing a fiberglass razor back as part of the modification. This will be a great project.
Leo
Click to see fullsize image.
Click for fullsize
< Message edited by Spychalla Aircraft -- 1/22/2006 1:49:10 AM >
       Post #: 1
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 1:45:59 AM
Spychalla Aircraft
Status: offline
Here is the start of the cowling form. I have positioned a 5.5 inch Tru-Turn Spinner ($185 by the way) in the proper position per 3 view drawings. The firewall had right thrust built in, so I have accomodated for that by setting a center line to the port side by about .150" at the firewall. This is a beautiful spinner. It will be a shame to paint it.
Leo
Click for fullsize
(in reply to Spychalla Aircraft)
       Post #: 2
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 2:28:51 AM
t_burley
Status: offline
very kewl project Leo. thanks for the link, I am also now a rivet sponsor for the Red Tail project
_____________________________
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin customer
       Post #: 3
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 6:08:25 AM
Ram-bro
Status: offline
Leo, you are a man on a mission. Thanks for the link also....
(in reply to t_burley)
       Post #: 4
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 11:24:34 AM
jmodguy
Status: offline
I thought about converting my tf gs P-51 to a B model also. How are you planning to deal with the leading edge extension on the wing? From what I understand this was only on the D model.
Jeff
(in reply to Ram-bro)
       Post #: 5
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 2:16:13 PM
Spychalla Aircraft
Status: offline
Good for t_burley becoming a Red Tail supporter. It would be good to see this project raise awareness and benefit the rebuild.
Jeff,
Yes I understand that the D model has the wing extension at the root and that the B and C models do not. I gave this considerable thought and decided not to change it at all. It would create a major hack job of the wing that just isn't worth it. I am building this for the Fun Scale category at the NATS. Not everything needs to be perfect plus I would wager that 95% of modelers will never notice that subtle wing detail.
A more noticable feature that is easy to change is the wing dihederal being too flat on the TF kit. 3-views show a much more dramatic dihedral. I was able to get it up to around 8.25" at one tip by putting a 1/4" ply block on the top of the center wing spar and then cutting off the bottom to fit in the wing sockets. Pretty clean and strong. I now need to fill the wedge shape it created between the center two ribs. Not too big a problem.
Leo
Click for fullsize
Click for fullsize
(in reply to jmodguy)
       Post #: 6
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 4:54:18 PM
Kmot
Status: offline
I bought a rivet too. They are tossing in a free hat at the moment too!
Ahhh......screw it!
       Post #: 7
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/22/2006 9:37:38 PM
jmodguy
Status: offline
Good luck on the mod and thanks for the heads up on teh dihedral. Post pics of the nose mod plz!
Jeff
       Post #: 8
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/26/2006 10:46:40 PM
scalebirdman
Status: offline
quote:
ORIGINAL: jmodguy
Jeff
It's not that the B didn't have a crank in the leading edge, it just wasn't quite as pronounced as the D. You have to go to the lightweight late marks to find a wing without the leading edge extension.
       Post #: 9
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/27/2006 12:12:43 AM
ghendrix01
Status: offline
As scalebirdman said, the B model had a similar wing to the D model, just not as pronounced. The only model P51 that had a straight leading edge was the H model. Jetco had a H model CL kit in the 60s. Wish I had not sold it although it flew like a rock.
George
(in reply to scalebirdman)
       Post #: 10
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/28/2006 4:03:14 PM
Spychalla Aircraft
Status: offline
I joined the center section of the wings. Since I increased the dihederal I filled the bottom gap with hard balsa and sanded it flat ahead of time with a large flat sanding block. After some filling and touch-up I glassed the center section joint today. The materials used are 6 oz. 2 inch wide fiberglass tape and Bob Smith Finish Cure Epoxy. I love to pull a lot of positive "Gs" so I added a band of 2" glass on the bottom of the spar all the way out to 4 inches beyond the gear on each side. It was then time for the "Toilet Paper Trick". You lay your glass first. Wet it with the epoxy resin and spread with a credit card. Then you roll a toilet paper roll against it to soak up the excess resin and push the glass against the balsa. You don't roll out the paper, just roll against the roll and then peal the outer layer off periodically and toss it. There is no better way to glass. Wait till you see this done on the whole wing. When your done there is little to no sanding required before paint.
Leo
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ghendrix01)
       Post #: 11
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/28/2006 4:07:11 PM
gary9648
Status: offline
And here I thought that I was the only one still using the ol spare toilet paper trick. Excellent job! Glad to see more guts building Red Tails also. Can not wait to fly my "C" model this spring.
Gary Webb
       Post #: 12
RE: Red Tail Project TF P-51C with scale size 5.5"... - 1/29/2006 1:05:25 AM
Spychalla Aircraft
Status: offline
Good progress today. The cowling area is shaping up well. The chin scoop looks realistic compared to the photographs I am referencing. The top curve and spinner position look better than before. I drew the location for the exhaust stacks on the side. They will be longer and in a different position than the TF kit. They measure accurate per the 3-view. Kelvin at KELEO said that he will make a set of exhausts to fit this specific cowling modification. All I need to do is send him a fiberglass cowling set when I am done. He'll get the first one as far as I am concerned. That will be exciting if he can get them done by May 06. I'd like to use them in this bird.
Leo
Click for fullsize
Click for fullsize
(in reply to gary9648)
       Post #: 13
RE: Red Tail Project TF P-51C with scale size 5.5"... - 7/6/2006 5:04:32 AM
Spychalla Aircraft
Status: offline
Back from 5 month delay on this project. I have new motivation and a deadline to a magazine editor to have a fiberglass cowl and "B" model conversion razor back kit in his hands by the first week of Sept. 06. So I'm at it again. I was having trouble with the air intake look on the cowl so I cut it off and started over. I created a new technique working with a male plug that I shaped first and then applied bondo around it and pulled it out. This is much better and it looks right. I have started to a light glass on the shape in plug preparation. I also ordered a second TF 1/5 RTC kit so that I can apply the parts to that airplane with out wrecking this plug. I never want to wreck the plug until I know my molds are good.
I also called Great Planes and confirmed that the "B" model canopies are still available. They are via special order for around $27 so I ordered 5 of them and will be using that canopy in the design of the back deck conversion. No reason to reinvent the wheel on that canopy until it is time to make the Malcomb Hood version which I can now see is inevitable considering the outcry of e-mails I get on the subject. The Malcomb Hood guys are just nuts.
Leo
Click for fullsize
Click for fullsize
       Post #: 14
