RE: Seeker Kits
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> RE: Seeker Kits
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Seeker Kits - 1/19/2007 2:13:24 PM
clb
Status: online
Good new Dan,
Can't wait until week-end!!!
Claude.
(in reply to kane)
       Post #: 101
RE: Seeker Kits - 1/25/2007 1:21:59 PM
kane
Status: offline
Sorry,
I had a little computer trouble over the weekend. They will be up and running tomorrow.
DK
_____________________________
Dan Kane
(in reply to clb)
       Post #: 102
RE: Seeker Kits - 1/30/2007 2:20:02 PM
Stripes
Status: offline
quote:
ORIGINAL: daven
Just curious, a lot of seeker kits went out this spring.
Any comments?
Any completed pictures? I'd love to see them!
I know some were built by people who don't post much on the net but here is mine I started recently. By the time I got it last year building season was over and it was on to flying.
Click to see fullsize image.
Click for fullsize
(in reply to daven)
       Post #: 103
RE: Seeker Kits - 1/30/2007 2:55:34 PM
daven
Status: offline
Looking good!
Dave Norman
klasskote.com
supertrc.com
(in reply to Stripes)
       Post #: 104
RE: Seeker Kits - 1/30/2007 4:02:21 PM
vicman
Status: offline
I think you need another clamp there. It looks good.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to daven)
       Post #: 105
RE: Seeker Kits - 1/30/2007 4:18:16 PM
daven
Status: offline
Thats exactly how I do them with the clamps. The trick is to get the clamps secured without getting any Gorilla glue under the rubber pads. If you get any depression in the soft balsa from the clamps being too tight, I would just spray them with a little water and it would cause most of the dent to come out as it dried out.
Dave Norman
klasskote.com
supertrc.com
(in reply to vicman)
       Post #: 106
RE: Seeker Kits - 1/30/2007 4:41:50 PM
HighPlains
Status: offline
Dry steam works faster for removing dents. Slight wetter than damp rag and a soldering iron will remove almost any dent in balsa.
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to daven)
       Post #: 107
RE: Seeker Kits - 1/31/2007 5:00:14 AM
julioq
Status: offline
Hi Dave. I am finally building my seeker. Hope to post a pic in two weeks. I have a couple of questions.
I will use the airplane for 424, but I am building it so I can take four screws out bolt a Nelson and fly 428 so:
1) Do you recommend fiberglassing the wing's center section?
2) And the tail?
3) Do you prefer thin LE on the stabs?
4) I am copying the elevator and aileron size from my slingshot, any specific on this surfaces size?
5) Any recomendations regarding wing tips. They will be balsa
6) Can you send me your recommended CG, throws and expo?
7) How much rudder and aileron do you use for take off?
Thanks for your response
Julio Quevedo
(in reply to HighPlains)
       Post #: 108
RE: Seeker Kits - 1/31/2007 5:37:16 AM
jeide
Status: offline
I have 2 new seeker fuse kits I'm not going to use I sell cheap if anyone needs some. PM me if interested.
(in reply to julioq)
       Post #: 109
RE: Seeker Kits - 1/31/2007 2:36:05 PM
daven
Status: offline
It really depends on what else you did to the wing. I'm not sure what you are using. When I used foam wings from Bill Vargas, he had quite a bit of Carbon in there, and I only needed to put down one layer of 2oz on the bottom of the wing in a triangle pattern, about 8" at the TE and about 16" at the LE and I never had any problems. Also, after my wing was built, I glassed top and bottom with 3/4 oz and primed and painted which adds considerable strength over plastic covering.
2) And the tail?
My tails were all glassed / primed in a vacumn bag with the fiberglass or kevlar hinges in place. I believe I did a thread on my process somewhere here on RCU a couple years ago.
I've done them both ways. Some with a slightly rounded LE, and some with a sharp LE. I never noticed a difference myself, but the current "popular" method is slightly rounded, rather than sharp.
My ailerons were 4-5" out from the Center of the wing, 1 1/4" in from the TE and 11" long. For 428 speeds I would use a little more than an 1/8" throw on low rates, and about 3/16" on high rates for landing.
My elevators are about 2" out from the center of the V, 1 1/4" in from the TE and 6" long. For 428 speeds I would use the same throw as the ailerons above.
Because I went with a narrower (high aspect) wing with a chord of 9 3/4", it was neccessary to use a full span 52" wing. Since Bills wings weren't quite that long, I had a sacrificial wing that I would chop about 5" off and glue on to one end of his wing (left side). After that was blended in, I would cut the tips off with my table saw at a 45 degree angle, leaving the wing at exactly 52" (depending on the exact chord length, as they could vary by a 1/16" either way). This worked fine for me, but I then built a plug and had some wing tip molds made and used those for some time. A Minneapolis local has the molds, and would probably sell the tips, but they were relatively expensive.
I normally will test fly it if the CG falls between 2 7/8" and 3" from the LE. Flying with anything more forward than 2 7/8" will give you very sluggish elevator response, and anything further back than 3" will give you very responsive elevator response. The recommended throws are listed above in #4, as to rudder, start with about 3/16" right and 1/8" left and adjust from there untill full right rudder gives you a straight takeoff. I don't use expo normally on quickees, but if you want, start with about 15% (positive or negative depending on your radio) and adjust from there.
Low rates, as mentioned above. Full rudder, and full elevator, you shouldn't need any aileron. The plane will come off the ground nice and slow, it will not bounce into the air.
Good luck, and let me know if you have any further questions.
Dave Norman
klasskote.com
supertrc.com
(in reply to jeide)
       Post #: 110
RE: Seeker Kits - 2/1/2007 1:20:45 PM
Super Splatter
Status: offline
Thanks much!
quote:
ORIGINAL: jeide
(in reply to jeide)
       Post #: 111
RE: Seeker Kits - 2/1/2007 3:12:39 PM
daven
Status: offline
You racing this year Jesse? I thought you were hanging up your racing shoes and going to play in a Rock and Roll band!
Dave Norman
klasskote.com
supertrc.com
(in reply to Super Splatter)
       Post #: 112
RE: Seeker Kits - 2/1/2007 6:01:41 PM
Super Splatter
Status: offline
That too, no 428 this year, just maybe half of the 426 and of course Q40 at Amery.
I do need to spend some Saturdays this summer on the homestead,
And of course I want the best that I can get, Seekers rule, R2 D2's drool.
But I'm sure Randy won't take it personally and sell a wing or 2, right ??
(in reply to daven)
       Post #: 113
RE: Seeker Kits - 2/2/2007 4:14:58 PM
Randy Etken
Status: offline
Dave eat your heart out, check the color of the wing. All new fully composit R-200.
Click for fullsize
Randy E.
I feel the need for speed. NCPL racing
       Post #: 114
RE: Seeker Kits - 2/2/2007 4:38:09 PM
HighPlains
Status: offline
Do you guys fly fast and turn right up there?
Click for fullsize
(in reply to Randy Etken)
       Post #: 115
RE: Seeker Kits - 2/2/2007 4:59:09 PM
daven
