Help with my OS .52
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Help with my OS .52
Page: [1]
Login
Help with my OS .52 - 1/23/2006 10:36:47 PM
Zman39
Status: offline
Hey All,
I have an OS .52 FS that is several years old. It ran good, but I could tell the bearings were getting bad and may have lost some of its compression so I decided to do a rebuild on it. I replaced both front and rear bearings and put a new head gasket on as well as an intake gasket. I reassembled it without problems, made sure the cam was aligned where it was suppose to be and set the valves to 2/1000". I ran about 4 tanks through pretty rich and then leaned it a little and flew it. The engine runs fine but it doesnt seem to have much compression. I can turn the prop and feel just a little bit of resistance and I go through compression. I am used to engines "popping" through compression. Is this normal for the OS 52 or should it have more compression then this?
Thanks for any help
Z
       Post #: 1
RE: Help with my OS .52 - 1/23/2006 10:44:38 PM
w8ye
Status: offline
I just rebuilt one and it will take a half gallon of fuel for the compression to return.
On a used engine like this you most probably moved the ring. It is no longer seated with the cylinder. The cylinder no longer has the ideal surface for seating a ring so it will take longer than on a new engine.
There is a possibility that you may have one of the valves too tight and you are loosing compression out the valve. You can hear this in the muffler or the carb.
There's no reason you can not just fly it and see of the compression returns?
Enjoy,
Jim
Click to see fullsize image.
Click for fullsize
< Message edited by w8ye -- 1/23/2006 10:50:20 PM >
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Zman39)
       Post #: 2
RE: Help with my OS .52 - 1/23/2006 10:50:23 PM
Zman39
Status: offline
Thanks for the reply. I was thinking (hoping) this will be the case but wanted to make sure I didnt miss something obvious. Only other thing I think I could have replaced was the sleeve but was hoping it wasnt necessary sinced it is a ringed engine. I will run some more fuel through it and see how it goes.
Z
(in reply to w8ye)
       Post #: 3
RE: Help with my OS .52 - 1/23/2006 10:52:25 PM
w8ye
Status: offline
It is unlikely the sleeve will ever need replaced.
You may need a ring in the future but the piston and sleeve usually last a long time.
Enjoy,
Jim
Original AMA #31261
       Post #: 4
RE: Help with my OS .52 - 1/23/2006 10:53:16 PM
Zman39
Status: offline
Speaking of valves. What is the ideal spacing on the valves when at room temperature?
Thanks again
       Post #: 5
RE: Help with my OS .52 - 1/23/2006 10:54:56 PM
w8ye
Status: offline
The tolerance works out to be .0015" to .004" but .002" is fine.
Original AMA #31261
       Post #: 6
RE: Help with my OS .52 - 1/25/2006 2:55:39 AM
philfun
Status: offline
Hi Zman,
I have to reassemble an OS 48 FS.How to align the camshaft ?
Phil
(in reply to w8ye)
       Post #: 7
RE: Help with my OS .52 - 1/25/2006 6:46:17 AM
donkey doctor
Status: offline
Hello Phil; With the crank held at top dead centre, slide the camshaft into mesh with the crank gear so that the timing mark on the cam, aligns with the lifter and the push rod. It's easier to do it then to type it.
(in reply to philfun)
       Post #: 8
RE: Help with my OS .52 - 1/25/2006 3:18:49 PM
w8ye
Status: offline
The gear teeth are helical so the cam will twist as it goes into position. So you will need to lead the position a little when inserting so the cam will be correct when seated.
enjoy,
Jim
< Message edited by w8ye -- 1/25/2006 3:21:00 PM >
Original AMA #31261
(in reply to donkey doctor)
       Post #: 9
RE: Help with my OS .52 - 1/26/2006 1:01:08 AM
philfun
Status: offline
Thanks very much for your explanations.
Seems pretty straightforward
When I'll get a new connecting rod I'll reassemble.
Thanks again.
Phil
(in reply to w8ye)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
