blax1
Joined: 11/11/2005 From: Sydney, AUSTRALIA Status: offline
NVSFlyer Thank you for your help, I understand what you are saying and I will check it out and let you know the outcome, also I 've been told to check travel adjustment which is set to factory 100% may have to alter, to maybe 115--130% to get full negitve swing, but not bottom out the servo at full positive pitch, it sounds like a fine balance, like I said in previous post everything is centred and level as per the instructions that were posted earier on this forum and also Bob Whites, I will give a good go over this weekend I've probably missed something Cheers Ralph
_____________________________
DF36/T-Rex 450SE/Blade CX/ SIM G3.5 Keep them choppers rotating!!
