RE: Sig Hog Biplane Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Hog Biplane Build Thread Page: <<   < prev  1 [2]
Login
RE: Sig Hog Biplane Build Thread - 6/30/2008 11:08:04 PM
MasterAlex
Status: offline
quote:
ORIGINAL: preparation_h
Would I just add washers between the top of the engine mount holes and the firewall?
Correct... somewhat a trial end error process. You might find the following .pdf handy. I don't recall where I found this in my internet travels or I'd tell you who created it to give credit. Regardless, this will help you as you trim out any plane.
-Alex
Click to see the file in new window.Attachment.pdf
_____________________________
"Few good landings result from poor approaches, while few poor landings result from good approaches." -S. Stoops
(in reply to preparation_h)
       Post #: 26
RE: Sig Hog Biplane Build Thread - 7/1/2008 5:20:56 AM
chashint
Status: offline
It is also possible that your wing incidence is slightly off.
If you have flying buddies ask to see if any of them have an incidence meter and will help you check out your plane.
If the incidence if off it is almost certainly the top wing that will be out of adjustment and it is easy to adjust with shims at the back of the cabanes where the wing bolts on.
regards,
Charlie
(in reply to MasterAlex)
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU1
