RE: Top Flite Staggerwing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite Staggerwing
Page: <<   < prev  64 65 66 67 68 [69] 70 71 72 73   next >   >>
Login
RE: Top Flite Staggerwing - 12/20/2011 2:49 PM
knucklebutt
Score: 100
Last Login: 5/22/2013
Status: offline
Jim
Here's a way to check "nose/Tail heavy. full throttle from straight and level, pull up into a 45 deg up line and let go of the controls, tail heave and it will climb above the 45 deg: Nose heavy and it will start a descent.
of course that means you will have to fly it again !
Denis
Hide Signatures
(in reply to sbrackets)
       Post #: 1701
RE: Top Flite Staggerwing - 12/20/2011 2:58 PM
Staggerflyer
Score: 100
Last Login: 5/15/2013
Status: offline
Double check your thrust line on the engine. If you added any downthrust beyond what the firewall already has built in, it will do this, also.
I agree, though, it sounds nose heavy, by quite a bit.
Since you are in the ballpark now, tho', you can start removing the nose weight, a small amount at a time, till it flies like you want. On mine, the elevator is nuetral, and it is not pitch sensetive.
Don
Hide Signatures
(in reply to knucklebutt)
       Post #: 1702
RE: Top Flite Staggerwing - 12/20/2011 3:19 PM
sbrackets
Score: 105
Last Login: 5/23/2013
Status: offline
OK thanks Don.
I will start removing one lead strip at a time till she flies straight and level with a neutral elevator.
Thanks, Jim
Hide Signatures
(in reply to Staggerflyer)
       Post #: 1703
RE: Top Flite Staggerwing - 12/20/2011 3:43 PM
rowdog_14
Score: 107
Last Login: 4/29/2013
Status: offline
I had to add a lot of nose weight on my staggerwing with my OS 160FX I think it was about a lb or a little more. Good to hear it flew well with the S2000. That will open up my choices with my G2300.
How much was your final weight of the plane?
_____________________________
THE T.R.U.T.H
Hide Signatures
       Post #: 1704
RE: Top Flite Staggerwing - 12/20/2011 3:55 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: sbrackets
OK thanks Don.
Thanks, Jim
Be careful on how much you remove at a time. The break point was pretty sudden for mine. Don't know how much your strips weigh, but I would only remove an ounce or two at a time. I know, that means many test flights, but...
Hide Signatures
       Post #: 1705
RE: Top Flite Staggerwing - 12/20/2011 7:44 PM
sbrackets
Score: 105
Status: offline
Ok ! I went back and added up the stick on weights. my first number of 15oz was wrong. Was really 13.5 oz. I just removed one one partial strip of lead of 2.25oz. bring my new total added nose weight down to 11.25oz.
Are you guys setting your elevator to the manual setting of 3/4" U & D HIGH RATE, 1/2" U & D LOW RATE? If so then I will change mine back to the manual setting, rather then adding more elevator throw. And start removing added weight in the nose a little at a time.
Thanks, Jim
P.S Rowdog let me get her flying correctly with the weight and I'll be glad to give you the final weight of my bird.
< Message edited by sbrackets -- 12/20/2011 8:55 PM >
Hide Signatures
       Post #: 1706
RE: Top Flite Staggerwing - 12/20/2011 9:40 PM
Staggerflyer
Score: 100
Status: offline
I just pulled mine out of winter storage and repair, to measure it for you. My CG is at the 5.5" mark, my field finger test points might be back 1/8". Mine is electric, so the batteries can be moved slightly to adjust.
My elevator movement is set at 3/4" up and down, 5/8 up on dual rate, but I never use it. I use 40%expo on all settings to smooth out the center, normal flying area. The only time full elevator is ever used is... I don't think I've ever used it on this plane, except when taxiing. This plane is properly flown at high speed, wide open manuevers, not full throw for anything.
I did look closely at my elevator "center". It might be 1/32" up. Checked the centering on the transmitter, and it shows 6% up trim, so I could still be a smidgen nose heavy. But I like the way it flies there. My first flight, the maiden, I did not turn it upside down. I went straight up from the point and held it under top wing. WRONG!! It came out very tailheavy. Only my long years of experience and my R/C helicopter experience, (FAST thumbs!) allowed me to save it. It took two lbs on the firewall to balance. That was with the OS 1.60 TwinFS. With my electric setup, on 10cell lipos, I still have 8 oz on the motor mounts.
During it's rebuild, (new wings required,) I may strip all the fuse stuff in the rear of the fuse, also. The only one required is the tailwheel mount. I use the air ram to operate it, but it's up on the servo mount rail in front. Pushrod going back.
Hide Signatures
       Post #: 1707
RE: Top Flite Staggerwing - 12/21/2011 1:29 AM
JoeMamma
Score: 115
Last Login: 5/24/2013
Status: offline
Got mine all done except for CG adjustments.
Grabbed my trusty ol' Great Planes CG Machine. I've had this machine for many years and it has worked flawlessly on everything from 10 ounce foamies up to 30+ pound planes. Unfortunately, it won't work on this plane !
It shows a cute little picture of this same machine on page 37 of my manual, but apparently nobody actually took the time to try it out on an actual TopFlite Staggerwing. The horizontal rods used to support the two CG machine bases are just too short at about 12 inches.
Easy fix ! Went to local hobby shop and picked up a 48" length of 3/16" carbon-fiber tube. Chopped the tube in half. Machine bases will now span 24". Works great now.
Bad news is, I had to add 1 pound 6 ounces to the nose. Good news is, even with the addition of the nose weight, my total weight was cut from its original 23 pounds down to 19 pounds 11 ounces. My StaggerWing diet has worked ! Bad news is, now I've got to wait 'til spring to get her in the air.
Joe M.
Joe Mamma
Hide Signatures
       Post #: 1708
RE: Top Flite Staggerwing - 12/21/2011 2:09 AM
sbrackets
Score: 105
Status: offline
Hey Joe
I used my friends Great planes CG balancer. He had already replaced the Horizonal rods with longer ones to fit wider planes, so I was good to go.
I did some looking on the Net tonight about nose heavy plane characteristics And my plane fits the bill. Said if a plane needs up elevator to keep level flight(which mine does) the plane is nose heavy. And feels heavy on the stick, which mine did, it's nose heavy.
Hell, I know 3/4" up elevator wasn't enough on that maiden flight.
I'm pretty sure mine was nose heavy. I have already given the balancer back to my buddy. But I might go get it again and do a recheck now that I removed 2.25oz of lead weight from the nose.
Jim
Hide Signatures
(in reply to JoeMamma)
       Post #: 1709
RE: Top Flite Staggerwing - 12/21/2011 2:55 AM
rowdog_14
Score: 107
Status: offline
quote:
ORIGINAL: JoeMamma
Easy fix ! Went to local hobby shop and picked up a 48'' length of 3/16'' carbon-fiber tube. Chopped the tube in half. Machine bases will now span 24''. Works great now.
Joe M.
I used the Great planes CG machine on mine too when I balanced mine a few years ago...try using it on a FAT Great Planes Gee Bee
< Message edited by rowdog_14 -- 12/21/2011 2:21 PM >
THE T.R.U.T.H
Hide Signatures
       Post #: 1710
RE: Top Flite Staggerwing - 12/21/2011 5:13 AM
Staggerflyer
Score: 100
Status: offline
Mine worked jus fine on mine, other than having the tail over the edge of the table.
Wonder if the earlier ones came with shorter rods.
Hide Signatures
(in reply to rowdog_14)
       Post #: 1711
RE: Top Flite Staggerwing - 1/1/2012 9:50 PM
xcz5785
Score: 100
Status: online
Does anyone have the plans to build a wing set for the Topflight Staggerwing? I know they are discontinued but you can still get all the other pieces from Tower. This is my dream plane and it's the perfect size I was looking for! I have seen them come up for sale but they are asking out of my budget for them. Besides if you do bust up the wings what then?
Hide Signatures
(in reply to GaGeeBees)
       Post #: 1712
RE: Top Flite Staggerwing - 1/1/2012 10:08 PM
skipb
Score: 110
Status: offline
Good luck on your quest, the Staggerwing was an ARF. There were no plans available unless someone drew them up on their own
Skipb
Hide Signatures
(in reply to xcz5785)
       Post #: 1713
RE: Top Flite Staggerwing - 1/7/2012 7:11 PM
njmheli
Score: 100
Status: offline
Hi To All.
I have been away from this "thread" for sometime,great to see it is alive and well !!!
I have been away from mt S/W project,details of which I posted some time ago............I have now finished her and just awaitng to do the maiden ( at long last !!! ).
I have run in my Saito 200R3,pleased to report that there appears to be plenty of power + it sounds great !!! I found out that the idle mixture was too rich,it was giving me a bit of trouble with causing a plug to "go-out" at extened lowish RPM's......I have now in addition to the "mixture" fix added an "on-board" glow system............working great.
I know that this subject has been talked about alot.........CORRECT POSITION FOR C of G !!! ........I would just like to confirm with you all that the position I have is correct by the "flying-results" you have all acheived.I have set mine to 5 1/2" from the leading edge of the lower wing.At this point she balances with a slight "nose" down attitude ( Wheels are retracted ).If I get it right,I have posted a photo of the position of the c of g.I will set about 30% expo and will increase the upper limits of the control throws to start with.
Thanks to all for the thread.
Cheers.............Nick (UK).
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to affas)
       Post #: 1714
RE: Top Flite Staggerwing - 1/8/2012 12:10 AM
Staggerflyer
Score: 100
Status: offline
Nick, looking good.
Take your CG measurement right on the outer rib where the wing joins to it. You should be perfect there. Your marked position looks good.
Go easy on adding more elvaor movement, unless you have a 3 position switch, and want to add more for taxiing on grass only. Switch back to listed max movement just before starting take-off run. If you want to add a little more, 1/4-3/8 inch max. 30% expo good.
Good luck on the maiden, hopefully you will get video.
Don
Hide Signatures
(in reply to njmheli)
       Post #: 1715
RE: Top Flite Staggerwing - 1/8/2012 11:16 AM
GaGeeBees
Score: 313
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: njmheli
Hi To All.
I have been away from this ''thread'' for sometime,great to see it is alive and well !!!
I have run in my Saito 200R3,pleased to report that there appears to be plenty of power + it sounds great !!! I found out that the idle mixture was too rich,it was giving me a bit of trouble with causing a plug to ''go-out'' at extened lowish RPM's......I have now in addition to the ''mixture'' fix added an ''on-board'' glow system............working great.
I know that this subject has been talked about alot.........CORRECT POSITION FOR C of G !!! ........I would just like to confirm with you all that the position I have is correct by the ''flying-results'' you have all acheived.I have set mine to 5 1/2'' from the leading edge of the lower wing.At this point she balances with a slight ''nose'' down attitude ( Wheels are retracted ).If I get it right,I have posted a photo of the position of the c of g.I will set about 30% expo and will increase the upper limits of the control throws to start with.
Looks "good"
...and then the unthinkable happened!
Hide Signatures
       Post #: 1716
RE: Top Flite Staggerwing - 1/8/2012 7:21 PM
njmheli
Score: 100
Status: offline
Hi Don / "Gageebees".
Thanks for your response to my "question",much appreciated..............thought I had got it right !!!
Was up the strip today,having a good fly,my club members are eager for me to maidend my S/W...............so yes,all things in place will be very soon and I hope to get the vid posted.
Thanks again.
Nick...............(UK).
Hide Signatures
       Post #: 1717
RE: Top Flite Staggerwing - 1/14/2012 4:18 PM
njmheli
Score: 100
Status: offline
Hi Guys.
Staggerwing c of g checked,should be ready to go for the maiden now,just waiting for the weather !! Have "widened" my GP balancer..........works great.It is" slight" nose down at 5 1/2" as photo in other thread.
Click for fullsize
Hide Signatures
       Post #: 1718
RE: Top Flite Staggerwing - 1/14/2012 7:07 PM
sbrackets
Score: 105
Status: offline
I'D say it's too nose heavy per the photo. And will use a lot of runway to take off. And will need up trim for level flight. Just like mine.
If I were you I would remove some weight in the nose till she's perfectly level.
But that's just me speeking.
Jim
Hide Signatures
       Post #: 1719
RE: Top Flite Staggerwing - 1/14/2012 8:05 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: sbrackets
Jim
I agree, it is too nose heavy, however, personally, for first flight, I would remove enough to get it ALMOST level. Only SLIGHTLY nose down. Just for the first flight, so it won't be to pitch sensetive. Mine tended to tip stall far to quickly until I returned to slight nose down.
Just my 2 cents
Don
Hide Signatures
       Post #: 1720
RE: Top Flite Staggerwing - 1/14/2012 8:58 PM
njmheli
Score: 100
Status: offline
Hi Don / Jim.
Many thanks for your advice.....funny,in the photo,I agree it does look too nose "heavy", but in "real-life" it didn't look as much as that !!!I have to change out one of the batteries at the "firewall",so will do that first and then see what weight I can remove to get her SLIGHTLY nose down.
I have re-checked all the control throws and they are as the "high" rates as stated in the manual + 1/4"max,I 've added to them.Expo is set at 30%.......so hope that will be good.
Thank you again for your advice,all very much appreciated.......watch this space for anothe c of g pic !!!!
Cheers............Nick (UK).
Hide Signatures
       Post #: 1721
RE: Top Flite Staggerwing - 1/14/2012 11:19 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: njmheli
Hi Don / Jim.
Many thanks for your advice.....funny,in the photo,I agree it does look too nose ''heavy'', but in ''real-life'' it didn't look as much as that !!!I have to change out one of the batteries at the ''firewall'',so will do that first and then see what weight I can remove to get her SLIGHTLY nose down.
I have re-checked all the control throws and they are as the ''high'' rates as stated in the manual + 1/4''max,I 've added to them.Expo is set at 30%.......so hope that will be good.
Sounding good.
use the horizontal stab as the "level" point.
Your movements and expo should give you a nice flight. Enjoy.
Hide Signatures
       Post #: 1722
RE: Top Flite Staggerwing - 1/15/2012 12:14 AM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: njmheli
Hi Don / Jim.
Looks "fine" to me.
Hide Signatures
       Post #: 1723
RE: Top Flite Staggerwing - 1/17/2012 5:21 PM
mobyal
Score: 110
Status: offline
I have one for sale, new/unassembled w/ retracts. It's posted here on RCU if anyone's interested.
Al
MobyAl
Hide Signatures
       Post #: 1724
RE: Top Flite Staggerwing - 1/17/2012 7:52 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: mobyal
Al
AAARRRRGGGHH and I'm on layoff right now.
Hide Signatures
(in reply to mobyal)
       Post #: 1725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.906RCU1
