O.S. 70 FS (I)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> O.S. 70 FS (I)
Page: [1]
Login
O.S. 70 FS (I) - 11/25/2002 3:16 PM
Pepe J
Score: 100
Last Login: 1/8/2012
Status: offline
APC 13 X 6 + 15% Nitro. + OS "F" Plug, 100' alt. = 10,500 RPM
< Message edited by Pepe J -- Dec 2 2002 7:47PM >
_____________________________
"The Lord Listens, but Money Talks."
Hide Signatures
       Post #: 1
O.S. 70 FS (I) - 2/15/2003 7:35 AM
stgrlee-RCU
Score: 100
Last Login: 2/13/2004
Status: offline
My O.S. 70 is pretty new, only 3 tanks run thru it. Turns 10,200 on a 13-6 Master Airscrew.
Old age and trechery will overcome youth and enthusiasm every time.
Hide Signatures
(in reply to Pepe J)
       Post #: 2
Re: O.S. 70 FS (I) - 2/28/2003 9:24 PM
Mr T.
Score: 100
Last Login: 12/9/2007
Status: offline
Same here, 10800 peaked 10400-10500 ready to fly
[QUOTE]Originally posted by Pepe J
APC 13 X 6 + 15% Nitro. + OS "F" Plug, 100' alt. = 10,500 RPM [/QUOTE]
Hide Signatures
       Post #: 3
O.S. 70 FS (I) - 3/4/2003 11:33 AM
Keefer
Score: 100
Last Login: 4/27/2013
Status: offline
10.8K on an APC 13x6, 15% Power Master Fuel
11.25K on APC 12.25x3.75, 15% Power Master
both with OS-F plugs
Hide Signatures
       Post #: 4
O.S. 70 FS (I) - 3/14/2003 3:15 PM
Pepe J
Score: 100
Status: offline
I just recently switched to a fully synthetic fuel. 15% Nitro-18% oil which I added 3oz of castor for a 20% oil content. I gained an additional 300 RPM, but the TORQUE...... Big time torque improvement. I can't wait to try this fuel in my other 4 strokes!
Happy Fly'n....
Hide Signatures
       Post #: 5
70 II Four Stroke - 4/25/2003 8:20 PM
Toucan
Score: 100
Last Login: 2/6/2008
Status: offline
I am getting a 9500 to 10000 RPM with a 12X6 prop, 80-20 Fuel is that alright.
Sharad
Hide Signatures
       Post #: 6
O.S. 70 FS (I) - 4/25/2003 9:38 PM
Steve Guinn
Score: 100
Last Login: 9/9/2003
Status: offline
That is right where you want to be. Bax says they like to run them in the mid 9's for a smooth transition.
"The weather is here, wish you were beautiful."
J. Buffett
Hide Signatures
       Post #: 7
RE: O.S. 70 FS (I) - 10/12/2005 3:55 PM
Stoneweapon
Score: 100
Last Login: 4/19/2012
Status: offline
My very well used FS70 Surpass (10 Gall.+) turns with Coolpower 10%:
13x4W APC 11000
13x6 APC 10500 (private "blended" mix: 5% nitro, 11% castor, 5% molsyn 150)
Hide Signatures
(in reply to Steve Guinn)
       Post #: 8
RE: O.S. 70 FS (I) - 2/12/2009 10:48 PM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
15% coolpower with added castor 12x7 apc and OS F glowplug 10,800 peak and 10400 to fly, i cat wait to try it out...... i got this engine "frozen" and dissassembled it a few months ago. it, set the valve lash, and finally got around to putting her in a plane.
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to Stoneweapon)
       Post #: 9
RE: 70 II Four Stroke - 2/14/2009 12:13 AM
chashint
Score: 101
Last Login: 2/4/2013
Status: offline
quote:
ORIGINAL: Toucan
Sharad
I think you should get those numbers with a 13x6 prop.
A 12x6 prop is a little small for this engine.
Regards,
Charlie
Hide Signatures
(in reply to Toucan)
       Post #: 10
RE: 70 II Four Stroke - 2/14/2009 9:22 AM
MetallicaJunkie
Score: 243
Status: offline
you are right, but he isnt using any nitro in his fuel....according t0 him, its 80%methanol and 20 %lube
< Message edited by MetallicaJunkie -- 2/14/2009 4:11 PM >
Hide Signatures
(in reply to chashint)
       Post #: 11
RE: O.S. 70 FS (I) - 3/1/2009 1:37 AM
chashint
Score: 101
Status: offline
good catch Metallica
Regards,
Charlie
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 12
RE: O.S. 70 FS (I) - 3/10/2009 5:48 AM
buzzard bait
Score: 115
Last Login: 5/20/2013
Status: offline
I'm getting 9300 with 15% Coolpower on a 14x4W APC. That seems low to me. Someone else reported getting 10,000 on that prop. The engine has had a fair amount of use, but has been well cared for. Bearings are smooth, compression seems fine.
I adjusted the valves and noticed that when I press them down, they come up a little bit slowly. Not very slowly, but they don't pop right back up. Is that a sign that they've gotten gummed up (it has had fuel with castor in the past)? Could I get some power back by disassembling and cleaning?
Jim
Hide Signatures
       Post #: 13
RE: O.S. 70 FS (I) - 3/10/2009 7:52 AM
MetallicaJunkie
Score: 243
Status: offline
i would have to say yes
Hide Signatures
(in reply to buzzard bait)
       Post #: 14
RE: O.S. 70 FS (I) - 4/4/2009 12:18 AM
chashint
Score: 101
Status: offline
I don't think I would disassemble it.
I would take the back plate, cam cover, and valve cover off.
Remove the glow plug.
Rotate the crank so the piston is down.
Throw it in a crock pot and cover with antifreeze until 1 or 2 inches submerged.
Put the lid on the crock pot and set the heat to low and let it cook overnight.
It should come out looking almost brand new.
Dry it (blow it out with air hose if available) and apply liberal dose of WD40 through out the engine.
Dry it (blow it) again, apply liberal dose of light weight oil (air tool oil, after run oil, marvel mystery oil).
Put the covers back on and see how it runs.
Regards,
Charlie
Hide Signatures
       Post #: 15
RE: O.S. 70 FS (I) - 4/7/2010 1:33 AM
MetallicaJunkie
Score: 243
Status: offline
OS70 Supass new bearings 15% nitro apc 14x4w prop 10,050 tuned to fly
Edit* Surpass I
< Message edited by MetallicaJunkie -- 4/7/2010 3:02 AM >
Hide Signatures
       Post #: 16
RE: O.S. 70 FS (I) - 4/14/2010 9:27 PM
ton2di
Score: 100
Status: offline
OS 70 II Surpass
APC 13x7 with 15% omega fuel 9,800 rpm
Sea level
Hide Signatures
       Post #: 17
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Tachometer Readings >> O.S. 70 FS (I)
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
