tmw09
FL, USA Status: offline
Hey Not 24...I was from Suffolk, VA. Living in Ct now. What field do you fly out of? Now to my ST2300 question. I love the engine. It runs great now that it is fully broken in. My setup: APC 18x8 prop (pattern) OS F plug Byrons 15% fuel with castor blend (20% total oil) runs great and transitions beautifully. When I fine tuned the low end needle valve for loading up on the low end, it worked perfectly as designed. One problem...for some reason, the set screw that fits in the grove on the carb barrel gets pushed in and stuck somehow, and the carburator sticks when the throttle advances. Sometimes it gets stuck at half throttle and sometimes at full throttle. It is very scary because of the possibility of getting out of control on the ground. I have disassembled the engine twice, and found no debris or FOD (foreign object or debris), but I have notice that if you push a little against the rubber boot that protects the carburator barrel, it will rub against the set screw in the grove. I have not figured out how not to push this out of synch and prevent the throttle body from getting stuck. Maybe it is the spring in the carb barrell, or maybe the set screw in the grove of the barrel is faulty. Or maybe it is just a crappy carb all together, but I am looking for someone with help or a similar experience, so that I can learn from them.
_____________________________
name a plane you love.
