Not24
VA, USA Status: offline
quote:
ORIGINAL: buzzingb Not24, I too have a ST90 that runs great and had the same thought as you but for now I don't want to experiment since the 2300 is running so well. But it makes sense that if a Magnum 91 carb worked, the ST90 carb might work as well. The battery/ toggle switch does help but it gets old trying to charge that extra battery. The 17X6 prop I have seems to rev-up well compared to a 18X6. The engine pulls either but I like the faster 17". Try a 17-8 or 16-10, just for kicks. The thrust comes on at a lower rpm, giving more of a four stroke torquey feel. When you do this, you don't need full throttle as often, and have to cruise at a lower power setting too, to keep the speed down. I like it better when the engine sounds like it's working, not just revving and going nowhere.
_____________________________
Fly it till you break it!
