RE: ST2300 Testing and Experimenting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ST2300 Testing and Experimenting
Page: <<   < prev  23 24 25 26 [27] 28 29 30 31 32   next >   >>
Login
RE: ST2300 Testing and Experimenting - 8/13/2007 2:13:28 AM
blw
Status: offline
Just for reference, is that the CG Sukhoi? I have one still in the box.
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to Not24)
       Post #: 651
RE: ST2300 Testing and Experimenting - 8/13/2007 2:59:53 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: Not24
14-8, are you serious? What are you turning, about 13000? I'm getting just over 9000, and I like it a lot there. The 16-8 was too little prop (for my plane).
I had been flying my OS 1.08 lately. I forgot how sweet the 2300 is with the slimline pitts muffler. It really sounds good. I haven't heard a better sounding two stroke yet.
Yeh , It's been on that Dago I've been ragging on you about since you started this thread . I'm getting in the mid 11's but I'm at 5000ft so could be in the 12's in dog years or around sea level. Bob has a photo on the Jett page of when it was purple and i rebuilt it for the heck of it a couple winters ago. Basic hobbico retracts. i drilled them out and installed 3/16 struts and made the nose solid instead of a cowl. Let me see if I can find some old shots here.
I originally bought this off ebay as an intentional POS beater to just slap together but darned if it didn't turn out to be one of my better flyers.
This things is really a solid flyer.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Cyclic Hardover -- 8/13/2007 3:06:12 AM >
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to Not24)
       Post #: 652
RE: ST2300 Testing and Experimenting - 8/13/2007 2:49:04 PM
MikeRuth
Status: offline
quote:
ORIGINAL: Not24
Well, the engine ran perfectly today for two flights. I had forgotten what a sweet flying plane my Sukhoi is. The only concern I have is that my high needle was very vague, and seems to do next to nothing. This is strange, because that's what the ST carb did. I know it's not a fuel pressure issue, because it did the same thing with the pump, only I could never get it set right. I still think I have an issue somewhere in the fuel system to find. Everyone commented on the sound of my engine, especially when throttled back in a dive. I must say, now at this point, it's the best engine I ever had.
you have a great deal of experience with this engine, but sometimes a simple thing is overlooked.
Usualy if the main needle is having little effect or none, it is over propped.
could that be the case?
Mike R
(in reply to Not24)
       Post #: 653
RE: ST2300 Testing and Experimenting - 8/13/2007 10:00:54 PM
Not24
Status: offline
quote:
ORIGINAL: MikeRuth
quote:
ORIGINAL: Not24
Mike R
No way, not on this engine. They call for an 18-8 prop, but I run a 16-10 or a 17-8. A 16-8 winds up closer to 10000, and gets very loud with no more performance to show for it. I have it propped to be between 8800 and 9200, depending on conditions. Bax says it should only turn 7300, which it will on a 18-8. That is really lugging for a two stroke.
Fly it till you break it!
(in reply to MikeRuth)
       Post #: 654
RE: ST2300 Testing and Experimenting - 8/13/2007 10:08:36 PM
Not24
Status: offline
quote:
ORIGINAL: blw
Yes, it's the newest version with the gear on the fuselage. It weighs 11 lbs and the 2300 is the perfect engine for it. If you use a four stroke, you'll want a 180 and a bigger gas tank.
This plane is draggy enough for slower aerobatics than say an ultimate or the extra 300. It flies very scale-like and has no bad habits. The build was a pain, but well worth it in the long run.
Click for fullsize
Click for fullsize
(in reply to blw)
       Post #: 655
RE: ST2300 Testing and Experimenting - 8/13/2007 10:27:54 PM
Cyclic Hardover
Status: offline
I run an 18/8 on my BGX 3500 in a WM P-51.
(in reply to Not24)
       Post #: 656
RE: ST2300 Testing and Experimenting - 8/14/2007 2:06:45 AM
Not24
Status: offline
That's right. But you wouldn't think of putting that prop on the 2300, would you?
(in reply to Cyclic Hardover)
       Post #: 657
RE: ST2300 Testing and Experimenting - 8/14/2007 2:10:20 AM
blw
Status: offline
Very nice paint job on the cowl and bellypan, and stripping on the canopy. Very sharp looking. I guess mine is the newer kit too. I got it about 5 months ago. Just had to ask about yours. I have a radial with about the power of a 1.20 4 stroke.
       Post #: 658
RE: ST2300 Testing and Experimenting - 8/14/2007 3:29:52 AM
Not24
Status: offline
Do you know what prop it can swing? This plane really needs an 8 pitch to get the speed up for good penetration. Hopefully you can turn a 17-8, but a 16-8 will fly it okay.
(in reply to blw)
       Post #: 659
RE: ST2300 Testing and Experimenting - 8/14/2007 3:43:50 AM
blw
Status: offline
I think a 15x8 or 16x8 would be okay. What prop are you using with your 2300?
(in reply to Not24)
       Post #: 660
RE: ST2300 Testing and Experimenting - 8/14/2007 3:46:45 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: Not24
Heck no. I would think the 15's 16's woud be a decent area you think?
< Message edited by Cyclic Hardover -- 8/14/2007 3:47:29 AM >
(in reply to Not24)
       Post #: 661
RE: ST2300 Testing and Experimenting - 8/14/2007 10:02:53 PM
Not24
Status: offline
I like the 16-10 the best. The 17-8 is good also, but not fast enough for me.
       Post #: 662
RE: ST2300 Testing and Experimenting - 8/15/2007 2:01:37 AM
Cyclic Hardover
Status: offline
With my 14/8 and those rpms on this, I'm really pushing the limits and its just cruising along without a care in the world.
(in reply to Not24)
       Post #: 663
RE: ST2300 Testing and Experimenting - 8/18/2007 1:10:54 AM
boex
Status: offline
Well, finally I installed my home made onboard glow system on my extra 330. All I have to say is wow. Now I have good idle, good midrange, good transition and even more power. I test flew it today and did various maneuvers. The engine responded without any hesitation. Before this ¨ignition assisted system¨ I couldn't even maintain a knife edge because of a drop in rpms. I haven't tried yet any 3d flying but from what I saw today at the field, I'll be going that way pretty soon, I guess. I still am not sure about the battery I chose, which is a 2200 mah Nicd, maybe I'll switch to a larger capacity cell. More testing coming up.
       Post #: 664
RE: ST2300 Testing and Experimenting - 8/18/2007 5:05:16 AM
MikeRuth
Status: offl
