Not24 -> RE: My 2300 only likes one prop (2/7/2006 11:42:18 PM)
Got her running tonight on the pump. I tried two configurations. One is the bypass, and the other is direct. Amazingly, it seems to behave exactly like the OS 1.08 in both configurations with one exception. There is not enough fuel flow with the bypass to go rich on the high needle. This is similar to how it runs without the pump and the open muffler. Let me talk about the direct system first. With the pump as lean as it will go, I could richen and lean the high needle, and the low needle, but the midrange is excessively rich. That's the way the 1.08 runs. Definitely not flyable. I saw a peak of 8000 with the 18-8, and an idle of 1400 all day long. Just don't add power quickly, because it'll load up really bad, and never clears in the midrange. The Bypass system works really well, but still needs one little tweak. The pump is set to full RICH, the high needle won't allow for slobbery rich, but will allow for finding peak and backing off a few hundred revs. The low needle acts just as it does without the pump. Idle is good, good as any I have seen, and will run forever at 2000 rpm. It will load up slightly if you do let it idle for a long time, but it is manageable with smooth throttle inputs. 15-30 seconds of idling won't load it up enough to be bothersome, and it definitely won't quit. The good thing about this setup is that the engine runs perfect from 3000 to 8000 rpm with NO BAD HABITS. Transition is perfect, and spool up is what I would call very good for such a heavy prop. Noticeably better than without the pump. It gets right on up to peak rpm within 1 second. Also, I can run the engine to 5000 and raise the nose to vertical and it won't lean out. Overall, a very flyable setup that is easy to tune. The pump is not even part of the tuning equation. Set it to full and forget it. I might also add that I did stretch the spring to 2X original length. The only thing to play with now is to install a needle valve in the return line between the engine and the check valve. This will allow me to increase the pressure at the needle valve, making it possible to get it to go rich. It should also allow me to lean the low needle a little more, making for long idles with no hiccup on acceleration. This restriction was also required on the 1.08 to make the mid range rich enough. So, for all of those who still think the carb on the 2300 is not worthy, I say, so far it hasn't proven that to me. The real test is in the flying. I'll report on that in a few days. These pics are with the engine chugging at 2k.
