ST2300 Testing and Experimenting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> ST2300 Testing and Experimenting
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
ST2300 Testing and Experimenting - 1/28/2006 10:16:57 PM
Not24
Status: offline
Today was my second day of flying the 2300. I am running a MA 18-8, turning up at 7700. I was successful in adjusting the carb to get satisfactory performance without any pumps or regulators. I then switched to an 18-6 prop, which turned over 9000 and really sounded nice. I had three flights and three dead stick landings. I would be at about 1/2 throttle and the engine would just die. One time it happened in level flight, and I was able to cut the throttle and get it going again, for a little while. I had really good smoke trail and never ran lean. I put the 18-8 back on and tweaked the needles again, just a little, and had three more flights without a hitch. I would say that had I only bought an 18-6 prop, I would think this engine is junk, but it runs really good on the 18-8. I'm burning 10% powermaster and using an F plug. I had another engine do this very thing. That was an ASP 1.08. I gave up on that engine after too many dead sticks. Anybody have any ideas as to why a lighter prop load would cause flameouts? I am baffled.
< Message edited by Not24 -- 2/18/2006 11:39:09 PM >
_____________________________
Fly it till you break it!
       Post #: 1
RE: My 2300 only likes one prop - 1/28/2006 10:38:18 PM
Flyer95
Status: offline
Maybe the muffler is restricting the engine at those higher rpms?
Also two more things to try would be too remove the headgasket to raise the compression with the lighter load and also lean the idle needle slightly maybe about 1/16 of a turn and try again. Good luck
(in reply to Not24)
       Post #: 2
RE: My 2300 only likes one prop - 1/28/2006 10:52:06 PM
Not24
Status: offline
I did pinch the exhaust nozzles closed to gain muffler pressure. Not closed, but restricted to match what the stock muffler has for backpressure. What I would like to know is what is the test for achieving the optimum back pressure? What I would do is adjust the back pressure to the point that I could still get the high needle to go full rich at full throttle. Hopefully, it would still draw well at lower rpms. Openning up the exhaust would yield more power. More power is always nice to have.
(in reply to Flyer95)
       Post #: 3
RE: My 2300 only likes one prop - 1/28/2006 11:11:35 PM
carrellh
Status: offline
In the tech notes on the Tower site they mention back pressure when using non-stock mufflers
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV80&P=0
You could put a tee fitting in the exhaust pressure line and hook up a pressure gauge to measure
Regards,
Carrell
(in reply to Not24)
       Post #: 4
RE: My 2300 only likes one prop - 1/28/2006 11:23:13 PM
Flyer95
Status: offline
I dont think pinching the exhaust nozzles is the best way for feeding an twostroke engine. Twostroke engines needs to breathe and restricting the muffler would cause overheating and loss of power. However some engines seems to handle more backpressure than others which is good for fueldraw but on all engines the needle settings becomes more narrow, only very very small increments are needed.
Your tachometer readings are good so your muffler is probably fine. Maybe only some low end needle adjustments are needed?
(in reply to Not24)
       Post #: 5
RE: My 2300 only likes one prop - 1/28/2006 11:42:22 PM
buzzingb
Status: offline
Not24, this engine is known for this kind of behavior, that is the reason it is so cheap. I have been working with a 2300 for a year now and just recently have I gotten it halfway running. It is a power house though, at a cheap price. I find my 2300 runs best with a 17X6 apc and I have even thought of going down to a 17x4 so the engine can revup quickly. The 18X8 is propping your rpms too low even though you may have achieved better results, you aren't in the power band. My engine seemed over propped with the 18X6. I have tried ever trick in the book to get this engine running and the only thing that gave a noticeable improvemant was a home made on board glow to keep the glow plug lit in the midrange rich condition this engine has. I am running an OS #8 plug. Some people use the F plug. Like you I peened the ends of the bisson to give back pressure. Recently due to a deadstick and rought landing I lost one of the stacks and I used JB Weld and a piece of can to close that hole up. Now I only have one stack. Still runs just as well. After I play with this thing some more I may try one of the Jett carbs. I am looking for 3D type performance and I don't know if I will ever achieve this with this engine. Give me a PM if you have questions.
Buzz
(in reply to carrellh)
       Post #: 6
RE: My 2300 only likes one prop - 1/29/2006 12:56:39 AM
Not24
Status: offline
I'd like to add that the high needle seems to be not so sensitive, while the low end needle is very sensitive.
The easiest way to match the bisson muffler to the stock one would be to open one tube fully, and plug the other completely. To save time, I compromised both tubes to a point that somewhat equals one open tube. I may be off a little bit, but I won't know till I try some test runs with different settings. I may hack the corner off the fuse and go with the stock muffler to test different props. That will remove the muffler pressure from the equation.
(in reply to buzzingb)
       Post #: 7
RE: My 2300 only likes one prop - 1/29/2006 1:23:58 AM
turbo.gst
Status: offline
I like APC 17 x 8 or 17 x 8n on mine. The spool up is very good. I like the Pro Zinger prop for power, but the spool up is slower. I guess it depends on your application.
turbo
(in reply to Not24)
       Post #: 8
RE: My 2300 only likes one prop - 1/29/2006 3:02:05 AM
Ed Cregger
Status: offline
quote:
ORIGINAL: turbo.gst
turbo
Most of you fellows should look up the old pattern oriented G2300 articles of some years ago. You could learn a lot about the G2300.
The G2300 is not a high revving engine design. It certainly is not a 3D engine. It simply isn't ported for that kind of throttle response.
The pattern folks determined that the 18x8 was perfect for their version of pattern flying. Revving the engine any higher did not yield good results in terms of thrust generated.
In order to obtain a really crisp throttle response from this engine, it will need to be fitted with an accelerator pump, or a much smaller cfm carburetor. A 17x8 is not too small of a prop, but it is moving away from the 18x8 optimum prop.
Engines that quit after being tuned successfully on the ground have a fuel system issue, not a prop issue. The 18x6 diameter/pitch is not causing the problem. But its balance and or sympathetic resonance of the airframe may be causing fuel foaming problems. Remember, you cannot see fuel foaming problems with the model sitting on the ground. It must be checked for foaming with the model being held off of the ground by its wing tips. Even then, visually spotting fuel foaming can be tough, however the engine will let you know that something is amiss without your having to actually see foamed fuel in the fuel line.
Now, I am sure that everyone is experienced enough to be doing a fine job of static balancing their props, so I'm not insinuating that anyone is falling down on the job in this regard. However, dynamic balancing is another thing altogether. One thing that can make a difference is to true up the prop hub so that the blades of the prop track properly. How many of you do this? I don't either, but I do check for blade tracking on problematic props and then replace the prop if it is too far out. That often makes the difference.
There is nothing "wrong" with the G2300. It is now a housebrand engine and the Chinese manufacturing savings is being passed along to the consumer. It helps Tower gain consumer loyalty. It worked for me. I now own more ST engines than I have ever owned. Don't let the low price fool you into thinking that it is inferior. It is not. However, it is dated and is not the ideal choice for 3D flying in its stock form. Most two-stroke glow engines fall into the same category. If you really want to make this engine perform, spend the bucks on the Jett made parts for this engine.
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
(in reply to turbo.gst)
       Post #: 9
RE: My 2300 only likes one prop - 1/29/2006 3:44:03 AM
Not24
Status: offline
I would like to comment on Mr Cregger's remarks. I think he is right about this engine not being designed for the higher rpm's and crisp throttle response that is necessary for 3D. Although I have this engine on a F90, I like it fine flying as a sport plane, with the throttle stick basically left alone at around 1/2 stick. I knew before I bought this engine that it had these types of issues, so I am not disappointed at all. The plane flies about the same with either the 18-8 or the 18-6, but it pulls more like a four stroke with the higher pitch. I'm still in the break in process, so there is room for improvement. If the engine never runs any better than it does right now, I will be satisfied. However, I think I can get it better without too much trouble. I think I'll try my VP 30 pump on it anyway, just to satisfy my own curiosity. Who knows, maybe we can all learn something from this.
(in reply to Ed Cregger)
       Post #: 10
RE: My 2300 only likes one prop - 1/29/2006 4:06:42 AM
cyclops2
Status: offline
Post # 7 states a touchy low speed adjment. Usually low carburator vacumm and or blunt needle tips. Your choice.------All needles MUST have a tight pressure on the threads to prevent movement.
I usually regrind most needles to sharp long points on a VERY smooth wheel.
(in reply to Not24)
       Post #: 11
RE: My 2300 only likes one prop - 1/29/2006 8:58:53 AM
Kweasel
Status: offline
Lightening the load on a model engine, without changing anything else will make the mixture richer. Any time you change the load you must re-tune the carb. If the engine was smoking a lot at half throttle and died, then its probably too rich. Some engine and glow plug combinations will never fourcycle, they just stop running. Often an idle bar plug will allow an engine to run very rich and fourcycle without stopping. A K&B idle bar plug will be more forgiving of overly rich mixtures while tuning your carb. Once its correct it won't matter what you use.
(in reply to cyclops2)
       Post #: 12
RE: My 2300 only likes one prop - 1/29/2006 2:34:35 PM
Cyclic Hardover
Status: offline
I am not going to contradict Eds comments but I run this thing inverted on a 60 size P-51 with a Jett Pipe on it and 14/14 apc screaming the )(*&^ out of it for a year now and no problems. I think a large part of it is "proper adjustment". I cannot tell you how many people I run into on a regular basis who think they have their engine dialed in when it is still way off.
Revving up the engine after each adjustment, does not tell you everything.
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to Kweasel)
       Post #: 13
RE: My 2300 only likes one prop - 1/29/2006 2:59:25 PM
buzzingb
