Tigger N. Bennie
The servo display on the Futaba T3PK is nice when setting up and brake/servo mixing. I do like that feature. By the way, the Sensor has a "Tank Mix." According to the manual, the frame rate of the Nomadio Sensor is 100 frames per second and the latency is 10 millisecond max, 5ms typical. Whether or not the upgradeable Sensor software (both transmitter and transceiver) will be reduced down to 2ms like the HRS T3PK specific module, I don't know and haven't inquired about. Of course, the nice thing about the Sensor is the 2.4GHz transmission, the downloadable updates, ability to set up either on the computer or via the transmitter and synchronize the two, the built-in telemetry, and the ability to use any combination of analog and digital servos. Of course, the additional transceivers and sensor probes are more expensive than the "standard" Spektrum RC receivers (without the optional telemetry set up). In addition, another nice thing about the Sensor is the adjustable swivel screen--something that neither the M8/M11 or T3PK has available.
< Message edited by Tigger N. Bennie -- 2/26/2006 7:57:56 PM >
_____________________________
Lots of RCs, two cats, and a Nikon.
