Wonderful Wonder
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Wonderful Wonder Page: [1]
Login
Wonderful Wonder - 11/27/2002 12:52:45 AM
Dsegal
Status: offline
I have always liked the looks of the Sig Wonder and after seeing an expert pilot throw an e-powered version all over the sky I hoped to build one some day. This year I built the kit for an OS.15LA engine and my heart rate hit the red line in the first two flights. It was just too sensitive in pitch for me. So I decided to make a drastic change. I cut off the stock tail with twin fixed rudders and added about 5 inches to the fuselage. I then made conventional tail surfaces and added a servo for a moveable rudder. This has turned out to be the most fun model I have ever flown. Great big loops and 3-roll 80 degree Victory zooms. My fellow club members, most of whom think no plane with less than a .60 engine is worth building, were lined up to watch me fly it even though I am not an expert. There is a small photo of the model in Randy Randolph's column in the January, 2003 issue of Flying Models.
Dave Segal
       Post #: 1
Wonderful Wonder - 12/8/2002 6:51:12 AM
Wonder
Status: offline
Dave,
That sounds like something I would like to try. Could you post a photo or two and give more detailed dimensions of the tail section.
Tim
_____________________________
Don't know if I'm coming up or down!
(in reply to Dsegal)
       Post #: 2
Wonderful Wonder - 12/8/2002 6:56:57 AM
Bipe Flyer
Status: offline
How about this?
17 1/2" Wingspan, 8 oz and a Norvel .061 up front.
Click to see fullsize image.
Click for fullsize
       Post #: 3
Wonderful Wonder - 12/8/2002 9:11:35 AM
Dsegal
Status: offline
Alas, I lack a digital photo capability at this time. But I will post a verbal description soon.
Dave Segal
< Message edited by Dsegal -- Dec 8 2002 2:42PM >
       Post #: 4
Wonderful Wonder - 12/8/2002 6:43:15 PM
ajcoholic
Status: offline
Dave,
I just got my latest issue of FM. Saw your kit-bashed wonder. Looks great! I bet it makes for a hell of a smoother flier. Do you find it is less affected by the wind now? Thats the only thing I disliked about my wonder, it seemed to get tossed all over the place in the slightest breeze.
Andrew
Andrew J. Coholic
Engine reviewer for FLY RC Magazine - andrewc@flyrc.com
       Post #: 5
Wonderful Wonder - 12/8/2002 7:41:07 PM
Dsegal
Status: offline
> Do you find it is less affected by the wind now? <
I can't compare to the first two flights but in about 25 flights since the conversion I have not been concerned about winds of 10mph or so. The weight of the stretched plane is 32 oz. including one ounce of nose ballast.
Dave Segal
       Post #: 6
Wonderful Wonder - 12/8/2002 8:20:27 PM
Dsegal
Status: offline
The aft end of the stretched fuselage measures 11-5/8" from the wing trailing edge to the fuselage end. (Measure from the wing TE and not from the aileron TE.) The extension plus the weight of the added rudder servo made it tail-heavy. I moved the engine forward by placing a 3/16" lite ply spacer behind the engine mount and put 1 oz. lead under the engine. If building this version from scratch you might extend the firewall forward about 1/2" to minimize the ballast. The plane is balanced at the point specified in the plan.
The horizontal tail spans 14". Its chord on the fuselage centerline is 7" and the chord at the tip is 5" Within these dimensions the elevator chord is 1.5". The vertical tail is 5" high with a chord of 7" at the bottom and 4.75" at the top. Within these dimensions the rudder chord is 2.25". The elevator hinge line is at the end of the fuselage so that the elevator overhangs the rear of the plane. The rudder is set so that its TE is at the elevator hinge line.
Dave Segal
       Post #: 7
Here it is! - 12/12/2002 2:45:33 AM
Wonder
Status: offline
Dave sent me a photo, so I scanned it for all to see.
Tim
Click for fullsize
       Post #: 8
Wonderful Wonder - 12/13/2002 8:36:52 PM
soarrich
Status: offline
Being so short coupled it almost looks like a CL model.
Nice job.
Rich Border
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.594RCU1
