RE: nitroplanes.com FW 190 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: nitroplanes.com FW 190 Build
Page: <<   < prev  15 16 17 18 19 20 21 22 [23] 24   next >   >>
Login
RE: nitroplanes.com FW 190 Build - 5/16/2007 10:37:59 PM
ticketec
Status: offline
Hey Wufnu,
You will get many opinions with this topic, some people say throw it all away and use "American" hardware.
Now, I don't know what "American" hardware is or why it's so good, because i'm almost finished building a Top Flite P-51 which is has "American" hardware in it an a lot of people replace it as well, so we will assume that they think "american" stands for a reputable name hardware manufacture...
I on the other hand used most of the supplied hadware. Here is the list of what i did.
Landing gear: already spoken about.
Control horns: compared them to Du-bro large horns i have here at home and much the same in terms of plastic rigidity and strength
Dowel rods: replaced the rudder with sullivan golden rod, and the elevator used the dowel rod but with 4-40 hardware.
Pushrods: replaced because they have a different thread to 2-56 and i couldn't get my metal clevis' on.
screws: used supplied
tank: used supplied
Wheels: way to small for scale and have du-bro 4" tires which weight heaps
Hinges: used supplied, but read below.
I have just stripped back the covering on the entire model and am preparing to kitbash it, and on removing the flight controls i simply pulled them off and was somewhat disturbed at the ease in which the hinges let go. i would recommend replacing these and i will be doing the sameduring the kitbash.
just my 2c and Hope this helps
thanks
< Message edited by ticketec -- 5/16/2007 10:39:33 PM >
(in reply to Wufnu)
       Post #: 551
RE: nitroplanes.com FW 190 Build - 5/16/2007 11:05:22 PM
Wufnu
Status: offline
Thanks bud!
Justin
www.CommonSenseRC.com
_____________________________
Justin
(in reply to ticketec)
       Post #: 552
RE: nitroplanes.com FW 190 Build - 5/17/2007 1:11:52 AM
Sturtz
Status: offline
Justin,,,, I have a completely differant subject question for you. Those Lipo transmitter batteries that Common Sense sells ???
Do you need a regulator to reduce them to 9.6 volt ? Or just how does that work ? I have several 3cell Lipos for a P38 and they are 11.1 volt. Just curious. But I do like the idea of flying several days on a single charge.
Kurt
AMA# 794291
Saito Club #121
(in reply to Wufnu)
       Post #: 553
RE: nitroplanes.com FW 190 Build - 5/17/2007 2:12:31 AM
Wufnu
Status: offline
I don't work for them, I'm just on the support crew. Consider me more like a roady If you send them an email, though, they'll be able to tell you for sure. I don't want to tell you something and be wrong and since I've never bought a transmitter pack I think it's best if they tell you.
http://www.commonsenserc.com/contact_us.php?osCsid=816003f1c4be0a27ffc0088349902ad6
Making a "things I need" list for the 190, soon as I get the engine running like a top I'm gonna place my order.
Justin
(in reply to Sturtz)
       Post #: 554
RE: nitroplanes.com FW 190 Build - 5/17/2007 3:53:12 AM
alqwad
Status: offline
About the LiPo transmitter batteries. I just got a Dualsky TX battery from Vampower http://www.vampowerpro.com for my transmitter. I had a NIMH 2500 mah battery that gave me long transmitter operating time, but weighed a ton. The new one weighs about half as much as my old one and seems to be working great for me. When it is fully charged, it shows 12.4 volts and I charge it in the radio through the normal charge jack with a LiPo charger. It has a built in cell balancer, so balancing from time to time should not be required. So far, so good...
MIGJAM
       Post #: 555
RE: nitroplanes.com FW 190 Build - 6/12/2007 4:48:28 AM
proulxlaw
Status: offline
I took over Rich Ross' 190. I swapped him a Seagull SuperStar that was given to me by a friend who I did some work for.
I decided that I wanted to paint mine like JG54 Eastern front. Paint work on fuse is done. Main wing construction is complete except for gear doors and finish painting. I have a Saito 180GK that I sent to Horizon for repairs that should be returning shortly that will go into this plane. Main wing incidence is on the money at 0-0.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 556
RE: nitroplanes.com FW 190 Build - 6/16/2007 12:00:21 PM
Ross 3951
Status: offline
Nice job Bob.
It looks great with that color scheme. Are you going to run a 180 in it?
Ross3951
(in reply to proulxlaw)
       Post #: 557
RE: nitroplanes.com FW 190 Build - 6/16/2007 2:43:35 PM
proulxlaw
Status: offline
Yup. As soon as it comes back from Horizon.
(in reply to Ross 3951)
       Post #: 558
RE: nitroplanes.com FW 190 Build - 8/27/2007 8:18:27 AM
skubacb
Status: offline
Is everyone really using standard servos? I saw the question later and no one has talked about the servos they are using.
Since nothing about the requirements for the servos is in the manual what is everyone doing with their planes?
Cheers,
Craig
       Post #: 559
RE: nitroplanes.com FW 190 Build - 8/27/2007 3:09:51 PM
Sturtz
Status: offline
I'm using all metal geared hi-torque Futaba servos except throttle and flaps. Just because that's what I had on hand at the time.
I think it's always a good idea to at least use a metal geared servo on the rudder with anything over a 60 sized plane. Lot of stress back there.
Kurt
AMA# 794291
Saito Club #121
(in reply to skubacb)
       Post #: 560
RE: nitroplanes.com FW 190 Build - 8/27/2007 11:13:34 PM
ticketec
Status: offline
I used HS-85mg servos for each aileron and flap, and then hitec 425's for everything but throttle. a hs-81 is perfect for that job.
thanks
dave
       Post #: 561
RE: nitroplanes.com FW 190 Build - 9/5/2007 3:24:04 AM
rifraff
Status: offline
well i finally did it i painted my FW 190 and i looks so much better its my first time using an airbrush and its so easy check out the before and after pics
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Wufnu)
       Post #: 562
RE: nitroplanes.com FW 190 Build - 9/5/2007 3:36:49 AM
taildragger21
Status: offline
Rifraff.. Loks nice!! I am getting mine ready right now. I got one from a friend on here(noflaps) who done a beautiful airbrush paint job in the richthofen squadron sceme along with split flap mods, and a glassed wing. Right now I am trying to find some struts that will work. The gear bays were extended to be more scale. Seems I need a 9" long strut with a 3/16 diameter. Any ideas?? Thanks
fly it like you stole it!!!!!
(in reply to rifraff)
