fldmshlschroe
NY, USA Status: offline
Good luck on the build,,,, if my great planes 190 ever goes in,, I am going to go for the cmp 190 version that your building,,,, so please keep us all posted... I recently built the gsp/cmp p-40 70" http://www.rcuniverse.com/forum/m_2965010/mpage_5/key_/tm.htm which came with that same covering.... I would suggest that you change it now! I recovered the horizontal stab with flat monocote but didn't recover the wings due to the fact that the decals were factory applied. The wing covering sags in the sun, where as the monocote holds true... I went to Home Depot and colormatched, airbrushed the acrilic, and then cleared/fuel proofed with the topflight flat clear... so far so good. Also don't forget that all that paint and clear adds up to weight as well.... better off recovering so you dont add more weight by painting over the existing paint. Also, I have found that the short nose 190's tend to be tail heavy.... might want to keep that in mind when placing the internals... Best of luck
