RE: ParkZone NEW FW-190 Butcher Bird
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> RE: ParkZone NEW FW-190 Butcher Bird
Page: <<   < prev  18 19 20 21 22 23 24 25 [26] 27   next >   >>
Login
RE: ParkZone NEW FW-190 Butche... - 6/14/2007 2:01:05 AM
gundamnitpete
Status: offline
just thought i'd share my FW-190 experience....
bought the planea few months ago as my first RC aircraft, after hours reading here on RCU i decided it was the better plane, over the mustang (my first choice).
i spent a little time on a simulator at the hobby shop, and took the plane for a flight.
first flight went great, i got a little over board with it tho, flew for a lil to long and the motor cut off at a not so good time. landed the plane on it's belly, no damage whatso ever.
second flight, also great, until i got disorented, got inverted about 10 feet off the ground, and pulled up right into the ground, broken inner structure.
replaced the structure, and went for a third flight. it went well, until some wind knocked the plane over, and again, went nose into the ground.
just replaced the fuse, and gearbox, and flew it again today.
the plane flys like a dream, i honestly find no downsides with to what so ever, aside from the motor pinion, which slipped in flight today, i was able to glide the plane down fine tho.
it'll loop, roll, fly inverted.
all in all, a VERY good buy for 180$, just wait for a good day to fly it, my most expensive repair was from being impateitn on a non calm day.
(in reply to manuel frias)
       Post #: 626
RE: ParkZone NEW FW-190 Butche... - 6/15/2007 1:15:18 AM
mezd
Status: offline
I had simmilar problems with my FW, i also had the same thing with a Hobbyzone Aerobird extreme.
In both cases i have been very lucky, my local hobby shop is the importer for PZ & HZ and both times they have swapped the reveiver over for me - no questions asked.
I can only assume that it is a very common problem - however like someone else said, you get what you pay for.
All this asside - i love my FW, think its great fun!
_____________________________
I feel the need, the need.......... to stop crashing!
(in reply to rleed)
       Post #: 627
RE: ParkZone NEW FW-190 Butche... - 6/15/2007 1:16:43 AM
mezd
Status: offline
Hey Pete,
Good to hear you doing so well - did you say this is your first plane? How was the addrenalin on you first launch?!!
(in reply to gundamnitpete)
       Post #: 628
RE: ParkZone NEW FW-190 Butche... - 6/17/2007 2:37:33 AM
gundamnitpete
Status: offline
haha, yes my first plane, and i'm very much into the hobby, tons fo fun!
bad news tho, yesterday i took the plane for another flight. the first one went okay, but at the end the motor cut and i didn't have enough power to avoid a tree (entirely).
plane clipped a small branch and did one cartwheel on the ground, i went and took a look, and it was fine, to my eyes anyway.
we rechared, and went for another flight.
apparently, the wing suffered major spar damage, because on the second flight, during a split S, the right wing folded.
the plane lawndarted directly into a tree. lucky, ALL the electronics were fine, and i had a spare fuse (i ordered one a while back, and it was damaged at the LHS, so i got a new one and the damaged one free).
so today, i swapped all the eletronics over to the spare fuse, and bought a new wing.
took the plane for a flight today, and it flew beautifully. perfect flight and perfect landing.
tomarrow we will see how things go
(in reply to mezd)
       Post #: 629
RE: ParkZone NEW FW-190 Butch... - 6/18/2007 1:25:31 AM
mezd
Status: offline
Yes i have just finished rebuilding mine after a.. lets say radio glitch! Was doing a full throttle bank turn and the stick went dead - so i watched it do a beautiful nose dive!
Put a new internal structure into it, glued up the fuse and put in a new receiver ( off other plane).
My front cowl is now held together with clear packaging tape, but i dont want to put a new one on until im sure she's ok!!
Wont get her out until the weekend now though!
       Post #: 630
RE: ParkZone NEW FW-190 Butche... - 6/18/2007 3:05:03 AM
rleed
Status: offline
Wow ..Horizon replaced my wrecked FW-190 no questions asked! I had a radio glitch that resulted in its destruction, sent it back and they replaced it. Hats off to Horizon, this kind of service is becoming very, very rare these days. On another note, has anyone ever considered/attempted to add a couple of degrees of dihedral to the wing of the FW? I think it would be pretty easy. Simply split the wing and re-attach it with ca and some fiber mesh material with spacers under each wing tip to get the desired angle. If more strength is desired you could insert a couple of sub spars into the foam at the joint. I think this may add some inherent stability to this plane and make it a little easier to fly. Any comments would be appreciated. Thanks, RLeed
       Post #: 631
RE: ParkZone NEW FW-190 Butche... - 6/18/2007 5:11:28 AM
gundamnitpete
Status: offline
flew again today. the plane flies great, although i did notice a big tendency to snap roll when pulling hard G's (pulling up from a high speed loop)
i've found the plane flies best with the CG about 1/4 to 1/2 and inch forward of the front line of the "CG box" on the bottom of the wing. even with this setup, the plane wants to climb at full throttle, and flies extremely gracfully at 1/2 throttle.
one word of adivce, when banking, keep the nose down, the plane will tip stall very easy, i find that banking into the turn, and then givving it a little bit of out alieron works well.
(in reply to rleed)
       Post #: 632
RE: ParkZone NEW FW-190 Butch... - 6/18/2007 5:31:27 AM
mezd
Status: offline
Yes mine climbs as full throttle, i have mine trimmed to fly straight at just above 1/2 throttle.
I usually use quite a bit of elevator when i bank mine - but i like pulling the turns tight... thats just me.
Have you inverted yet - i find with mine that you need almost full down elevator to keep it straight...... but that just could be because of the way i have it trimmed.
       Post #: 633
RE: ParkZone NEW FW-190 Butch... - 6/18/2007 3:49:09 PM
gundamnitpete
Status: offline
inverted mine will fly level with about 1/2 stick, which kinda feels like full, haha.
what clevis is your elevator at? mine is second from the shortest, i was thinking of going with the shortest, but it's very pitch sensitive anyway.
(in reply to mezd)
       Post #: 634
RE: ParkZone NEW FW-190 Butche... - 6/18/2007 6:06:21 PM
gunracer
Status: offline
quote:
ORIGINAL: rleed
has anyone ever considered/attempted to add a couple of degrees of dihedral to the wing of the FW?...I think this may add some inherent stability to this plane and make it a little easier to fly.
low wing warbirds, especially the fighters, are meant to be inherently unstable to some degree...this is what gives them their aerobatic capabilities...if you add dihedral to the wings, she won't roll, turn and fly inverted as well...the really crucial thing on this model is the center of gravity...once you get that figured out, she's solid...
(in reply to rleed)
       Post #: 635
RE: ParkZone NEW FW-190 Butch... - 6/18/2007 6:12:32 PM
gundamnitpete
Status: offline
lol, well i flew it directly into a tree at 1/2 throttle, accidently. luckily it was at the park just down the road form my house, it's still about 100 feet up in the air, i'm hoping for a big gust of wind to bring it down sometime today, otherwise it's spitfire for me! haha
(in reply to gunracer)
       Post #: 636
RE: ParkZone NEW FW-190 Butche... - 6/18/2007 9:56:19 PM
rleed
Status: offline
I may get a bare wing and give it a try just for the heck of it. I had 5 flights on my previous FW till the radio freaked out. I was flying it w/o the extra nose weight and the battery located foward in the battery tray. It balanced out per the instructions this way. Now I get to start all over again. I'll advise on how it turns out and maybe post some pics of the wing mod. RLeed
       Post #: 637
RE: ParkZone NEW FW-190 Butch... - 6/19/2007 1:08:28 AM
gundamnitpete
Status: offline
rleed, while you've got the wing sperated, you might as well throw a carbon fiber rod in the wings to give the spar some extra strength.
i find the plane flies best with the prop weight, imho.
i got the plane back, the tail was ripped off, so i'm glueing ti back now, and the interstructure is broken so i have one ordered already.
< Message edited by gundamnitpete -- 6/19/2007 1:09:29 AM >
(in reply to rleed)
       Post #: 638
RE: ParkZone NEW FW-190 Butch... - 6/19/2007 3:08:20 AM
rleed
Status: offline
That was the plan for the wing, For $35 it may be fun to see if 2 degrees of dihedral affects its flight characteristics. I can't leave well enough alone, I'll probably end up crashing another one!!
