RE: The Evader Coalition - T.E.C.
Tower Hobbies
Logged in as Guest
Users viewing this topic: rawfuls
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition - T.E.C.
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: The Evader Coalition - T.E.C. - 2/2/2006 10:33:43 PM
moose_guy70
Status: offline
quote:
ORIGINAL: tamiyacrawler
quote:
ORIGINAL: moose_guy70
hey I probaly made some of you guys mad with my review on the evader but I have revised it with what I think now.
Ya, I was kinda pis*** as i've never broken anything off of big jumps never mind small ones.
It just seemed to break more because I was comeing from slower stock xxx-t but after I got my new motor I started to figure out that the faster the car the more part you will break. so sorry for making you mad.
_____________________________
If your not cheating your not trying!
(in reply to CustomTamiyas4Life)
       Post #: 26
RE: The Evader Coalition - T.E.C. - 2/2/2006 10:50:00 PM
fugaziiv
Status: offline
okay, about the diff gear.
I am running a Novak GTB and a velociti 5.5. It melts the plastic gears in no time flat. it melts ae nylon gears in a somewhat longer period of time. It doesn't melt alloy gears. the alloy gear is actually pretty light, and the weight difference hasn't made any difference. (well, at least to me) If you are looking to make the high power BL setups work, keep your eyes open for B2 alloy diff gears. (if you can find them, the HG ones are verry nice. If any one wants one, I may be coming into posession of an extra one, if the ebay guy ever ships it...
fo' sho' old schoo' since '87
(in reply to moose_guy70)
       Post #: 27
RE: The Evader Coalition - T.E.C. - 2/2/2006 11:16:02 PM
rpage83
Status: offline
I've been hiding in the shadows for the past month looking on the post about the evader. I have two and looking to get a third one. I use to own a nitro evader but gave me heck. LOve the electric, plug and play no hassle. Im looking to tinker with the chassie. My wife races with me, but has broken two chassies Need to find more suspenison and a aluminum chassie. Anyone know if kdmkysoho has made a chassie yet?
(in reply to fugaziiv)
       Post #: 28
RE: The Evader Coalition - T.E.C. - 2/3/2006 12:07:51 AM
duneslider
Status: offline
Are you breaking the pro chassis? I haven't heard of anyone breaking the graphite chassis. I know racing can be rough on parts but generally the jumps aren't big enough to break a chassis.
What are people willing to pay for an aluminum chassis?
Later
Duneslider
Toe-block Braces
The end of broken Evader toe-in blocks!
(in reply to rpage83)
       Post #: 29
RE: The Evader Coalition - T.E.C. - 2/3/2006 12:25:53 AM
rushrtr3
Status: offline
I ordered my evader st pro the other day from tower. Cain't wait for it to get here!
Nitro 3 with an OS .18 CV-RX, HPI Savage SS 4.6
Evader pro. www.rushedrc.50megs.com (Custom Paintjobs)
(in reply to duneslider)
       Post #: 30
RE: The Evader Coalition - T.E.C. - 2/3/2006 12:40:53 AM
duneslider
Status: offline
Here is that write up on adjusting the diff and slipper. If someone wants to try it with a high powered motot and see if the gear still melts I would be curious. They claim that by using the ae nylon gear and adjusting like this most people won't have problems.
Later
Duneslider
Ball diff slippage can as we know melt the diff gear. If the slipper gives before the ball diff the gear will be safe. Here is how I check the balance between my slipper and ball diff.
1. Remove the cover revealing the spur and pinion gears.
2. Tighten the slipper all the way
3. Back off the slipper ¼ turn.
4. Hold the right rear wheel and spur gear so they cannot turn I use the heel of my hand to hold the tire to a table top while holding the spur with my fingers.
5. Try to turn the left wheel with your left hand (as if truck were moving forward). It should be almost impossible to turn the left wheel. If so stop. Your diff is good. If you can turn the wheel and the slipper shaft is not turning your diff is too loose.
6. Tighten the diff 1/8th turn and re-test.
7. Repeat until the wheel will not turn without turning the slipper.
Once the diff is adjusted you will need to set the slipper.
This can be fun!
1. Turn your radio and truck on
2. Hold the truck out in front of you, holding it by the rear wheels. The truck should hang nose down.
3. Have some one pull full throttle on the transmitter. Be careful it does not hit you in the nose. If the truck comes up above level the slipper is too tight. Loosen it and re-test. If the truck comes up between ½ (45 degrees) to level you are good. If the truck does not come at least ½ way up tighten the slipper a little and re-test.
I have developed a way to do this myself, I sit down and put the truck between my knees (bottom facing me) and use the transmitter myself, I can't convince my wife to even touch my truck, not to mention help. It has also been said by Hydro_Gin that it is important to do this periodically and especially when you hear funny noises out of the rear end of the truck.
jep rc offers the following advice:
12-09-2002, 11:09 PM
Jacob -
You hit the nail on the head with your question about how snug is snug regarding the Evader diff. I think this is the main problem people have with the diff. The idea is to fully compress the little spring on the diff screw then back off just slightly while still leaving the spring compressed. I think most people stop tightening before the spring is compressed, and then back off, which results in a loose diff, and melted diff gear shortly thereafter.
The problem is, it is difficult to know when the spring is fully compressed - and tightening too much will result in a stripped nut, or broken nut carrier.
The best thing to do is to try tightening a diff while it is assembled, but out of the tranny, so you can look carefully at the spring and get a feel for when it is tight - you *can* tell the difference between when the nut initially contacts the spring, and when the spring bottoms out fully compressed.
Hope that makes sense.
Jep
Toe-block Braces
(in reply to rushrtr3)
       Post #: 31
RE: The Evader Coalition - T.E.C. - 2/3/2006 1:30:42 AM
EVADERCHAOS
Status: offline
quote:
ORIGINAL: raz54
Thanks Corry for starting this
No problemo!
Good news. I have recent worked out a sale on my Evader ST. Yess! As soon as the guy buys it (either tomorrow or sunday) I will be on Tower ordering my Evader Pro . Ooh yes, it will be red.
The Evader Coalition ~ Founder
Garage: ~ Evader ST Pro (Positive R/C : Venom Racing : Team Orion : Pro-Line)
(in reply to raz54)
       Post #: 32
RE: The Evader Coalition - T.E.C. - 2/3/2006 1:44:32 AM
CustomTamiyas4Life
Status: offline
Yaaaaaayyyyy, so now i won't be the only one besides doahh with a pro!! It's an awesome truck.
TNX / E-firestorm / Tamiya Rising Storm / mod pede-for sale / walkera 4 / mini-t
(in reply to EVADERCHAOS)
       Post #: 33
RE: The Evader Coalition - T.E.C. - 2/3/2006 1:47:23 AM
