RE: The Evader Coalition - T.E.C.
Tower Hobbies
Logged in as Guest
Users viewing this topic: The Hybrid, Redvanmafia
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition - T.E.C.
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: The Evader Coalition - T.E.C. - 2/3/2006 8:45:12 PM
lcnet
Status: offline
yes, it's still the original connector..
_____________________________
XXX-t and T4 , Evader pro BX Chameleon pro2,bunch of aluminum... by the way nothing beat my ZZR 1200 !!! hahaha
(in reply to raz54)
       Post #: 51
RE: The Evader Coalition - T.E.C. - 2/3/2006 10:48:59 PM
Flyojumper
Status: offline
Talking about filling shocks, I have the biggest problems in filling up mine with absolutely no air whatsover... (I have an Evader BX pro)
I tried everything, wait 15mn for air bubbles to surface, twist the piston gently as you push it down, put some drops of oil of the top cap (inside part of course) before inserting it, followed the instructions to the smallest detail, etc... and I still can't get them to be 100% air free.
I even took my car to the LHS and even the "veteran" guy over there couldn't get them to be air free after 20mn of tries (but he admitted he never worked on bottom filled shocks before).
Could someone give pointers or even better pics/videos?
BTW, once the shocks are filled very properly (100% air free) are they supposed to stay this way or will air eventually find its way in?
< Message edited by Flyojumper -- 2/3/2006 10:49:41 PM >
(in reply to lcnet)
       Post #: 52
RE: The Evader Coalition - T.E.C. - 2/3/2006 10:51:32 PM
CustomTamiyas4Life
Status: offline
Air can eventually get in if a seal is bad or other things.
TNX / E-firestorm / Tamiya Rising Storm / mod pede-for sale / walkera 4 / mini-t
(in reply to Flyojumper)
       Post #: 53
RE: The Evader Coalition - T.E.C. - 2/3/2006 10:56:59 PM
duneslider
Status: offline
Once you get the shocks done you need to get some sort of shock covers. (some use balloons) The seals start getting sand in them and will let air in and oil out. I read somewhere that the duratrax seals aren't the best out there. They kept refering to blue seals if that helps any. I don't know who makes them but they said tower sells them.
Good luck
Duneslider
Toe-block Braces
The end of broken Evader toe-in blocks!
(in reply to CustomTamiyas4Life)
       Post #: 54
RE: The Evader Coalition - T.E.C. - 2/4/2006 2:34:07 AM
jakjr
Status: offline
The "blue" seals are made by MIP I've been using them in my shocks and they work great. http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAX28&P=7
BTW, I have removed the off topic posts that were in this thread, if you want to discuss bikes try the OT forum, if you want to sell stuff try the marketplace.
< Message edited by jakjr -- 2/4/2006 2:38:42 AM >
{o,o}
|)__)
(in reply to duneslider)
       Post #: 55
RE: The Evader Coalition - T.E.C. - 2/4/2006 2:36:01 AM
CustomTamiyas4Life
Status: offline
I was hoping someone would do that.......
(in reply to jakjr)
       Post #: 56
RE: The Evader Coalition - T.E.C. - 2/4/2006 2:54:43 AM
discgolfer72
Status: offline
well my speed gems 15 t motor in my evader finaly needs a com cut so untill the lhs can get their new lathe i bought this orion method r 11t motor for it anyone ever used them are they good motors this is the first motor i have bought that has not been trinty or reedy how does it compare
i dont really run my evader all that much any pinion size ideas for the 11t motor iiv been running the stock one so far
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
boom
vintage rc will rule
       Post #: 57
RE: The Evader Coalition - T.E.C. - 2/4/2006 3:02:31 AM
CustomTamiyas4Life
Status: offline
I'm ordering some new stuff since i broke another servo. My limit is 150. I wanna go fast, but i need other stuff, so it's tuff. I def. need new radio system(mx-a) and a mg servo. I think the cheapest 12t esc is the streak, but i've had bad past experiences with it, so i dunno. For a 12t i won't spend over 40 most likely so i have only a handful to pick from. I want deans plugs, but to replace everything i need like 25 of em, so i don't think i'll do that yet. Wait, i have 46.50 to spend on a motor kuz i have a little credit. I want the cobalt or team checkpoint, but may be a little too much. I wonder how the epic intense mods are? Pretty cheap. I'm hoping to get my truck up to 35mph. I haven't broken anything, but it may be because i can't get over 4 feet of air with the motor i have now. Well, i gotta decide in like 3 days so if anyone has some motor info or suggestions i'll listen.
(in reply to discgolfer72)
       Post #: 58
RE: The Evader Coalition - T.E.C. - 2/4/2006 3:04:07 AM
CustomTamiyas4Life
Status: offline
