RE: The Evader Coalition ~ T.E.C.
Tower Hobbies
Logged in as Guest
  Printable Version
Wheely King 14mm Hex Wheel Extensions - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition ~ T.E.C.
Page: <<   < prev  442 443 [444] 445 446 447 448 449 450 451   next >   >>
Login
RE: The Evader Coalition ~ T.E.C. - 7/3/2008 3:02:24 PM
Stang444
Status: offline
Getting my buggy this weekend!!!!! Pics and setup will be up soon!!!!!!!!!!
(in reply to ohgrfreak)
       Post #: 11076
RE: The Evader Coalition ~ T.E.C. - 7/3/2008 3:38:17 PM
evaderkid
Status: offline
do rpm parts fit exts? Can I make them fit?
_____________________________
knowledge is reading the instructions
experience is tossing them aside!
(in reply to Stang444)
       Post #: 11077
RE: The Evader Coalition ~ T.E.C. - 7/4/2008 5:47:33 PM
AquarianGuy78
Status: offline
quote:
ORIGINAL: evaderkid
Some do...as long as they are made for AE RC10 T3, they should fit fine.
hpi E-Firestorm/Mamba Max 6900kv
(in reply to evaderkid)
       Post #: 11078
RE: The Evader Coalition ~ T.E.C. - 7/4/2008 5:53:18 PM
AquarianGuy78
Status: offline
Going brushless!!!! I just ordered a MM 6900 from RC Superstore. I wanted a 5700, but long story short, none has them in stock. I have no plans of running lipo batteries on, only nimh 7.2v for now, it so it should give me identical performance as the 5700 would on the same power. I can just program the ESC to run the motor like it's a 5700. Anyway, I also have an aluminum idler and a transmission rebuild kit, stock diff gear and thrust bearing rebuild kit (should I ever need it) on the way from Tower. Also a couple stock spurs, Robinson racing 87T spur and an AE 17T pinion on the way. Is there anything else I should know about strengthening the drivetrain to handle this beast of a motor system? I do know that I will keep my slipper as loose as possible to keep damage risk to a bare minimum.
(in reply to AquarianGuy78)
       Post #: 11079
RE: The Evader Coalition ~ T.E.C. - 7/4/2008 5:56:09 PM
AquarianGuy78
Status: offline
quote:
ORIGINAL: ohgrfreak
Good luck, hopefully they'll have a horn for the Hitec.
Check this out.... http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHEG0&P=7 It has 3 horns, one for each size of servo spline. And, it is made from the hard composite that the rest of the chassis and suspension arms are. This should definitely help as this servo I have in it is an Ultra Torque beast! I have the steering kit ordered and on the way!
       Post #: 11080
RE: The Evader Coalition ~ T.E.C. - 7/4/2008 6:21:04 PM
bethjoan
Status: offline
Good find! I might need to get it in the future, I actually have a high torque Traxxas servo in, and the stock horn worked, I was suprised. But I find I swap out servos often, I'm gonna bookmark that link.
EDIT: dang, I see my pal did not logout again, lol. I'm ohgrfreak.
< Message edited by bethjoan -- 7/4/2008 6:23:37 PM >
RC10 Championship Edition
RC18MT
       Post #: 11081
RE: The Evader Coalition ~ T.E.C. - 7/4/2008 8:14:05 PM
evaderkid
Status: offline
Im turning my ext into a MONSTER EXT!!!!!!!!!!!!!!!
Check out my thread and help me out! (My Evader EXT turns into a MONSTER EXT)
(in reply to bethjoan)
       Post #: 11082
RE: The Evader Coalition ~ T.E.C. - 7/5/2008 5:26:51 AM
AquarianGuy78
Status: offline
So, who else is running their vader from a MM 6900? What should I be aware of as far as running it off of this motor/ESC?
       Post #: 11083
RE: The Evader Coalition ~ T.E.C. - 7/5/2008 5:36:52 PM
fullauto4u
Status: offline
