RE: The Evader Coalition - T.E.C.
Tower Hobbies
Logged in as Guest
Users viewing this topic: Ziggmiester, Darknest07
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition - T.E.C.
Page: <<   < prev  599 600 [601] 602 603 604 605 606 607 608   next >   >>
Login
RE: The Evader Coalition - T.E.C. - 7/24/2009 3:17 AM
rclugnut10
Score: 173
Last Login: 3/21/2010
Status: online
ohh yup what do ya know me ole' peepers playin trix on me...
the lug
_____________________________
HPI SAVAGE X SS, DTX EVADER PRO,AE RC10B4, E Choas, Evader B2 Diff Mod Go To Page 646, # 16148 of T.E.C.
Hide Signatures
(in reply to T-Frost)
       Post #: 15001
RE: The Evader Coalition - T.E.C. - 7/24/2009 6:44 PM
trx1
Score: 100
Last Login: 3/11/2010
Status: offline
turning my N to a Evader. gonna use:
a 4 cell pack,
used speedo mounted in front
gonna see if 48p will fit.
then 2 L brackets for motor mounts!
make for a nice basher.
evader ext,micro high roller, ntc3
2 outdoor, 1 indoor
Hide Signatures
(in reply to rclugnut10)
       Post #: 15002
RE: The Evader Coalition - T.E.C. - 7/25/2009 5:50 AM
sam rojas
Score: 100
Last Login: 2/20/2010
Status: offline
airmayle - good to know the wheels and tires showed up. gonna get the ST out tomorrow - up in Cambria, CA on Vacation, have some good dirt areas and some skateboard parks - gonna see how things go with some serious jumping.
Splittin time between the family, teaching my boy to skate a vert ramp (not too banged up after day one - good times), and breaking out the evader. good times (did I mention we're in a beach house overlooking the Pacific). Sorry to rub it in, but damn it's nice here.....
Hide Signatures
(in reply to trx1)
       Post #: 15003
RE: The Evader Coalition - T.E.C. - 7/25/2009 5:54 AM
sam rojas
Score: 100
Status: offline
oh yeah - chime in on the street tires -agree the Road Hawgs are good on asphalt. they pretty much suck on anything else - concrete, grass.... seems those strikers might make a better ride with a bit more tread. personnally gone to larger diam. Yoko's and other Big Spikey tires - other than running street speed runs, just no fun unless the evader's airborne.
Hide Signatures
(in reply to sam rojas)
       Post #: 15004
RE: The Evader Coalition - T.E.C. - 7/26/2009 6:18 AM
sam rojas
Score: 100
Status: offline
sent the evader on a 6' half pipe - didn't last too long. didn't have a shell - shot off the vert ramp and landed upside down. there goes the rear shock tower. shoulda brought some spare parts or maybe the jumping rig. anybody know where to get Evader parts around San Luis Obispo? lol
did some skatin' as well - damn it hurts to fall from 6' when your pushin 40. think my shoulder is about as banged up as that shock tower. Nothin a 6 pack and the sound of the waves can't fix....
Hide Signatures
       Post #: 15005
RE: The Evader Coalition - T.E.C. - 7/26/2009 11:37 PM
rclugnut10
Score: 173
Status: online
Gen 3 of the B2
The NEW evader tranny upgrade post, the following was coppied from cheech4's orginal post regarding the B2 diff mod
if you get the alloy idler gear from the nitro evader, the only gear to worry about is the diff gear. BUT, to make the tranny stronger and smoother at the same time i'd invest in the RC10 B2 diff gear B2 diff rings a 5X8 size bearing and carbide diff balls. lube the the diff balls with good silicon based lube and the gears i would use ceramic black grease. the carbide diff balls are great cuz there stronger and smoother, but i dont think its really that necessary.
SO, stronger evader tranny:
Cheech4 said
quote:
rc10 B2 diff gear
B2 diff rings
nitro evader alloy idler gear ( optional ) but well worth it
5X8 bearing
carbide diff and thrust balls- ( optional ) but good to have
silicon based lube- worth it but ( optional )
ceramic black grease- ( optional )
for those of us interested in getting an aluminum B2 diff gear you can contact Hammad Ghuman (http://www.1hg.com/) at sales@1gh.com and they may be able to hook you up,
i was doing some google-ing and ebay-ing for one of these gears, i found a website that does carry them for $28 per, that was posted by a fellow RCU member in reply to a post I made, (yes i feel really dumb ) either way, www.f1rc.com has the B2 aluminum idler gear made by Hammad Ghuman Racing just go under parts, for an AE then search (i'd just use ctr+f) for the gear part # 1848 i just entered the # into my search. This is an Australian based website, however they do provide international shipping but it will be extra, and is based on what you're ordering and where you live here's the order form
for the evader EXT/EXB you now also have a mod to beef up the tranny, while you can't replace the diff without replacing the tranny case and bearings/bushings to get the B2 durability you can upgrade the idler gear with
a traxxas steel 30T idler for the VXL series cars (see not below)
2 5X11X4 bearings (most 5x11's are X4's)
in order to run a ball diff you'll need along with a complete ball diff assembly 2 12X15mm ball bearings, kyosho does sell shims that size but you'll need about 8 per side because they're .5mm thick, you can find them at www.amainhobbies.com
i've spent a while looking for some 12X15's and i can't find any if you really want to run a ball diff i would go down to your local machine shop and ask them to slap some rod on a lathe and whip some up for ya i think thats the best bet
another thing i would STONGLY recomend a change to bearings because of the amount of power BL motors put out that well be ALOT of friction on those bushings which will A kill speed, B cause some MAJOR heat issues and those are NEVER good, meaning you can expect weakened gears and tranny case
also be sure to check out kwits post right under this one has a bit more info
note regarding the 30t traxxas gear -> http://www.rcuniverse.com/forum/fb.asp?m=9049101
note#2 regadering the same thing http://www.rcuniverse.com/forum/fb.asp?m=8726925 another account of using the gear
i will also note that there is an aluminum version of this same gear for about 5X the price from tower that may fit better/require less work to install...
I previously mentioned that nitro evader rings may work, they will not due to the placement of the ball holes on the nitro diff gear they are the same distance from the center as the electric versions the gear is just bigger,
i gotta put a shout out to cheech4, kwit, and all the other people who have added their time, money, and knowlage into this mod
the lug
< Message edited by rclugnut10 -- 8/27/2009 4:37 PM >
Hide Signatures
       Post #: 15006
RE: The Evader Coalition - T.E.C. - 7/27/2009 1:17 AM
airmayle
Score: 100
Last Login: 3/20/2010
Status: offline
Hey guys. Evader is still down, should have some parts by the end of the week. Slash is up and running and added some up grades. Did a little bashing today and it was fun. Its been like two weeks since I had them running. I'll post some pics and little video soon.
Traxxas Slash modded, Duratrax Evader modded, Exceed Dynamite stock sold
Hide Signatures
       Post #: 15007
RE: The Evader Coalition - T.E.C. - 7/27/2009 6:51 AM
monsterbombs
Score: 109
Status: offline
i wanted to take my evader out the other
day but feared the diff was melted. turned
out it just needed tightening. bashed her on 3s
for about 10 mins. good fun on a gravel road.
might still be damage inside, feels a bit notchy.
its not because we cant, its because we cant be bothered.
Hide Signatures
(in reply to airmayle)
       Post #: 15008
RE: The Evader Coalition - T.E.C. - 7/27/2009 6:57 AM
Redvanmafia
Score: 119
Last Login: 3/19/2010
Status: offline
evaders good bashers?, hahaha
Stampede GT / VXL Slash / Brushless Tamiya tt-01
Hide Signatures
(in reply to monsterbombs)
       Post #: 15009
RE: The Evader Coalition - T.E.C. - 7/27/2009 10:26 AM
monsterbombs
Score: 109
Status: offline
quote:
ORIGINAL: Redvanmafia
yeh ha ha. good jawb dude.
Hide Signatures
(in reply to Redvanmafia)
       Post #: 15010
RE: The Evader Coalition - T.E.C. - 7/28/2009 12:12 AM
T-Frost
Score: 105
Status: offline
Monster i'd just switch to the ext gear diff..I've ran some insane motors and haven't had one problem since i fixed the initial slipper problem..i'm using EXT case and diff...ST plastic idler and ST top shaft..have ran 40 -60 batteries thru it ,wheelies ,jumps,bumps,flips,rolls,you name it as long as my slipper works it's all good..
  I did replace the pins on the outdrives in the diff with filed allen wrenchs..I tend to replace all pins with them cause i've never had an allen wrench pin break yet..
Hide Signatures
       Post #: 15011
RE: The Evader Coalition - T.E.C. - 7/28/2009 12:48 AM
monsterbombs
Score: 109
Status: offline
i have an ext lying around. i run my slipper tight
and need the ball diff to soak up some power. thats
why i like the ball diff. and the way it handles.
the gear is old and probably not lubed thats why its
failing. and it was loose. i found the ext outdrives
(where the wheels bolt on) dont like cartwheels
at high speed. i also found that the ext diff case,
for me anyway let go before the b2. i really need
to pull it down and relube everything.
a vxl on 3s is pretty unforgorgiving to any tranny.
good to see people giving advice.
Hide Signatures
       Post #: 15012
RE: The Evader Coalition - T.E.C. - 7/28/2009 1:55 AM
T-Frost
Score: 105
Status: offline
I deffinately agree with the ext outdrives..Mine bent from cartwheels..Love the cvd's though ,they take seem to be taking my abuse ..They actually seem to be made really well..
Hide Signatures
       Post #: 15013
RE: The Evader Coalition - T.E.C. - 7/28/2009 2:15 AM
monsterbombs
Score: 109
Status: offline
are the outdrives to the wheels any stronger?
or bigger? i know the bit that comes from the
gearbox is beefy on the cvd but what about
the wheel end? the ones off the st are nearly twice as big
and still snap occasionally with a huge cartwheel.
Hide Signatures
       Post #: 15014
RE: The Evader Coalition - T.E.C. - 7/28/2009 2:38 AM
T-Frost
Score: 105
Status: offline
I don't think they're any bigger but seem to be stronger..Have done alot of cartwheels and no problems with em yet..When i got them 1 didn't fit had to file a little..After that it fit but both fit rather tight in the bearings..If i get bored i'll throw them in my 4 wheel drive..Seems like when that cartwheels they always bend..lol
Hide Signatures
       Post #: 15015
RE: The Evader Coalition - T.E.C. - 7/28/2009 3:07 AM
Aimlessone
Score: 100
Status: online
I'll vouch for the EXT CVDs as well, durable and shiny
Though it was an absolute pain to get the hub bearings onto the axle stubs at first, I had to resort to using a press to get them on. When I got a new bearing kit, I chucked the axle stubs onto a drill and sanded off a bit of the plating on the part that holds the bearings, now the bearings can be pressed on with a bit of muscle.
Also, hook-and-loop material is awesome. I don't bother with the battery strap anymore as it keeps breaking in crashes, the entire truck seems to fare better during impacts without it anyway. I should get a new battery pack or two, as these Tenergy packs don't provide enough amps, but then again I did buy the two 3800mah 7cells that I use on a daily basis for $12 a pack, they would work great in less demanding vehicles though.
< Message edited by Aimlessone -- 7/28/2009 3:27 AM >
Hide Signatures
       Post #: 15016
RE: The Evader Coalition - T.E.C. - 7/29/2009 5:08 AM
Aimlessone
Score: 100
Status: online
Managed to clip the rear left wheel on the tire of a parked car while zooming around at 30+mph on a street covered with a fine layer of dust, broke a piece of the A-arm off, snapped a ball-cup on the camber link, cracked the wheel and destroyed a CVD. The Schumacher Venom tires don't seem to grip well on anything besides clean highly-textured concrete and clean hot asphalt. I should go get a bottle of traction compound and see if that helps before springing for another set of wheels and tires.
I epoxied the A-arm piece back together with some plastic-welder, good stuff.
The CVD swing shaft is a total loss however, swapped back to the stock dogbones and stub axles. As for the ball-cup, I have plenty of spares.
Hide Signatures
(in reply to Aimlessone)
       Post #: 15017
RE: The Evader Coalition - T.E.C. - 7/29/2009 5:16 AM
rclugnut10
Score: 173
Status: online
yeah the same thing happened to my nitro cvd's in the vid that i posted, you couldn't see it but at the end of the opening clip (which was the end of our day) it kinda had a bit too much speed coming to the end of the parking lot hit the grass got airborn and took a hard hit into the bank, and busted a hub and a the cvd parts cracked only in one place and one ring,
and ball cups i've busted 3 this summer, good thing i bought 40
yup epoxy good stuff i got an arm held together by that, tho no real testing done on it seeing as i got parts from nitro for it by the time i next drove it but no way am i chucking it...
the lug
Hide Signatures
       Post #: 15018
RE: The Evader Coalition - T.E.C. - 7/31/2009 1:53 AM
x-c
Score: 100
Last Login: 3/13/2010
Status: offline
Hey guys! I got the evader bx months ago when it was only $99. The stock motor has burnt out on me, and I was thinking of upgrading to the 8.5t ezrun brushless. I will be running it at 7.2v
What do you guys think? Should I do anything the car before upgrading? Also will the aluminum idler from the nitro series fit in the bx?
Hide Signatures
       Post #: 15019
RE: The Evader Coalition - T.E.C. - 7/31/2009 4:58 AM
rclugnut10
Score: 173
Status: online
yup it sure will the idler that is, if you set your diff and slipper properly you should be safe, you will need to run quality cells, but if not scroll up to the rather long post i made, that has just about every tranny mod out there, tho i may see if my B4 slipper assembly can be mounted imo its a better design... for the most part...
the lug
Hide Signatures
(in reply to x-c)
       Post #: 15020
RE: The Evader Coalition - T.E.C. - 8/1/2009 4:31 AM
rclugnut10
Score: 173
Status: online
another evader mod...
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3189&P=Z
that is a direct drop in imo it has much less slop than the stock due to more threaded portion so its more durable and give better steering...
the lug
Hide Signatures
       Post #: 15021
RE: The Evader Coalition - T.E.C. - 8/1/2009 4:45 AM
glancyguy
Score: 100
Last Login: 1/20/2010
Status: offline
Sorry I am late to this thread (#14991 from aimlessone), I have been away for a couple weeks. You are running a EZRun 5T? What pinion/spur are you using here? Does the motor run hot? I have an EZrun 9T in my Tamiya DF-03 MS and I am looking to put it in my BX.
Evader Bx, Traxxas Slash 4x4, DF-03 MS, DF-02, DT-02
Hide Signatures
       Post #: 15022
RE: The Evader Coalition - T.E.C. - 8/1/2009 4:48 AM
rclugnut10
Score: 173
Status: online
i run the castle sidewinder 4600 combo geared 20,22,24 still experimenting liking 22 best tho with a 85t RR spur, may try a 32p spur, i run either matched Ep 4200 or 4600 6 cells or a zippy 5000mha 20 c lipo, my motor hits about 140-160 with proline badlands tires
the lug
Hide Signatures
(in reply to glancyguy)
       Post #: 15023
RE: The Evader Coalition - T.E.C. - 8/1/2009 6:05 AM
Aimlessone
Score: 100
Status: online
quote:
ORIGINAL: glancyguy
Im running the EZrun 8.5T motor (which is a true 540 size) geared 20/86 though I have an EXT, not a buggy, so the gearing will be different. The motor runs at about 120-130F while driving 2.2 truck size Schumacher Venom tires, maybe 140F if I try to get the truck to wheelie repeatedly (it does not want to wheelie without a fight ). The 540 size EZrun motors with the finned casings are actually 380 size motors finned out to 540 dimensions so that will affect gearing as well, but since the Evaders are relatively light-weight compared to other trucks/buggies, try using the stock gearing on the BX first which is 23/81 IIRC, then adjust from there.
quote:
ORIGINAL: rclugnut10
the lug
160F?! That's a bit high for extended running IMO, but then again, I've seen brushless out-runners that have been regularly pushed past 170F for extended periods of time with little ill effect, though the fact that they're out-runners that have forced cooling might help.
Hide Signatures
       Post #: 15024
RE: The Evader Coalition - T.E.C. - 8/1/2009 8:28 AM
Sunfirefoot
Score: 100
Last Login: 2/25/2010
Status: offline
Kinda been checking this thread out. Here's Pics of my evader st, mostly stock, its nothing special but soon it will be as soon as i get $$$ i plan on puttin a 5600KV brushless on it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.078RCU1
