can773
AB, CANADA Status: offline
quote:
ORIGINAL: Greg Covey ExFokkerFlyer, I agree with you also. I must have interpreted your post wrong since it came after my post #12 where I stated that the 3200mAh cell was not a good solution for pattern flying. Adam from Dragonfly tends to tout ThunderPower solutions without any real data to back up the claims. The truth is that we never had a 5AH pack solution before. The Saehan cells used in the ThunderPower packs are good cells. In fact, we plan to release a new Cellpro Slimline series using these cells because the thin shape will work in places the Kokam or PolyQuest cells cannot fit. The new Slimline series should have been released in January but the U.S. owner of Saehan, Emerging Power, cannot produce the handmade cells in sufficient quantities, and, R/C is not their primary business. To date, I am only aware of one plane in Europe that was built so light from carbon (as an e-pattern plane) that the 2p 6400mAh (using 3200 cells) pack worked for him. Personally, I don't consider this a mainstream solution and I didn't like the look of the custom-made e-pattern plane. A 5AH capacity seems to be the right choice so I am anxious to get these new packs tested this spring. In the last post above, Steve seems to state what I believe is the mainstream problem with flying electric pattern planes. Unless you are a sponsored pilot, or have money to burn, the cost of flying electric pattern is far greater than flying a glow-powered plane. We feel that the new Kokam 4800mAh cell combined with the Cellpro or BalancePro systems will change that advantage. Educating users about cell temperature and true cell discharge ratings is also key to increasing pack longevity. Greg You obviously missed a few of Adam's posts.....he was was of the first to post CBA plots of cycled packs (6000's Prolite cells) vs new packs back in September. If I remember correctly (I know he is planning on posting them shortly...but he is at my house building new planes....) it was around 3% after 50 cycles or so.....so your comments are a bit off base. I just finished capacity testing my 5300's vs new packs yesterday and will post the results here shortly as well, but it appears to be about 3-5% loss in 50-70 cycles. The tests we do are on real packs, use in the Worlds, US Nats and dozens of other events....well travelled well abused packs (I have discharged mine to 90%+ more than once by accident) so its not some hand picked company performed test. If you have data like we do to back up your claims from people in the field please provide it. Unless you come up with new tech in cell chemistry the cycle life of current cells is not going to improve much with chargers/balancers......my packs have always remained within 0.010V balance during their life (checked with a calibrated Fluke DVM)....and I have yet to see them reach beyond about 120-130F after a flight. Average 5-6C and burst to maybe 12C.
_____________________________
Chad Northeast
