RE: Defiant MKII
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Defiant MKII Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: Defiant MKII - 3/27/2006 1:00:35 AM
JasonS
Status: offline
I think that you should leave it naked!
I think the black/green actually looks really cool.
To bad the sun would wreck it in that state.
_____________________________
There is no such thing as too much time at the flying field!
(in reply to tschmidt)
       Post #: 26
RE: Defiant MKII - 3/27/2006 9:29:09 AM
papaone
Status: offline
Hello tschmidt
Awesome plane, great work. I love this plane a lot.
Regards
       Post #: 27
RE: Defiant MKII - 3/27/2006 12:09:42 PM
gandelin73
Status: offline
Hi Todd,
your first fuse is really beautiful!!!! Great job! The MkII version is (on my mind) really better in shapes than the first version (but it's personal).
I love this plane too
See you
(in reply to papaone)
       Post #: 28
RE: Defiant MKII - 3/27/2006 3:25:24 PM
rgreen24
Status: offline
Hey Todd, somehow, the black and green makes it look really haevy. What did the weight of the fuz come out to be?
Robert
(in reply to gandelin73)
       Post #: 29
RE: Defiant MKII - 3/27/2006 11:35:51 PM
tschmidt
Status: offline
Robert,
The total fuselage weight comes to 32oz. Not what I was hoping for, so I'll have to make some adjustment on material.
I'd be interested in hearing fuselage weights from anyone willing to give them. I'd be interested in knowing weights of the ZN Twister, Brio, Genesis (builders versions).
Todd
(in reply to rgreen24)
       Post #: 30
RE: Defiant MKII - 3/27/2006 11:53:28 PM
ual767
Status: offline
Todd:
I have weighed 2 Genesis (kit) fuses. One is fiberglass and one is glass/carbon fiber. The weights (in ounces) are:
---- fiberglass ////// fiberglass/carbon fiber
canopy ---- 4.0 ////// 3.3
chin cowl ---- 3.0 ///// 2.0
fuselage ---- 21.8 ///// 20.5
total ---- 28.8 ////// 25.8
I also have another glass/carbon fiber kit that is maybe 1oz heavier than this one.
Hope this helps.
Sorry but the formatting got messed up when it posed
< Message edited by ual767 -- 3/27/2006 11:56:39 PM >
If you never try anything new, you''ll miss out on many of life''s great disappointments
       Post #: 31
RE: Defiant MKII - 3/27/2006 11:56:02 PM
can773
Status: offline
quote:
ORIGINAL: tschmidt
Robert,
Todd
Twister is about 27 oz, including canopy and chin cowl.
It uses much less carbon than you have, only comes back maybe 12" from the nose. Your foam looks thicker as well or is it just the pics? 1/8" is in all ZN kits.
Chad Northeast
       Post #: 32
RE: Defiant MKII - 3/28/2006 12:02:48 AM
tschmidt
Status: offline
Thanks Chad and Chris for the info. I was hoping for 27 or 28. The foam in this fuse is 1/8" thick also.
Todd
(in reply to can773)
       Post #: 33
RE: Defiant MKII - 3/28/2006 2:03:20 AM
can773
Status: offline
Hi Todd
If memory serves me correctly the ZN fuses are laid up, 2 oz glass, 1.8 oz kevlar/2.8 oz carbon, 1/8" foam, 2 oz glass.
I may be off on the 2 oz glass it might be a bit lighter but its close to that.
Chad Northeast
       Post #: 34
RE: Defiant MKII - 3/28/2006 2:52:22 AM
tschmidt
Status: offline
Chad,
Thanks a bunch for the input its greatly appreciated. My first layer down was 3.1oz crowsfoot glass. It works really nice but I suspect it holds to much resin. I used used 2oz. cloth on my Def1's and will go back to that on the next layup.
I think I'll try this on the next one:
2oz cloth
1.7 Kevlar
2.9 carbon (not as far back this time)
1/8 in foam covered with .75 or 1oz cloth (and go into the top deck)
I noticed the twister Canopy is Kevlar and will go that way too. (my Def1 canopys were made that way and turned out well)
We'll see what happens, I'll keep you posted, and again, thanks for your help.
Todd
       Post #: 35
RE: Defiant MKII - 3/28/2006 3:32:27 AM
rgreen24
Status: offline
Hey Todd, that weight is not bad at all, you can still get that plane to weigh under ten pounds, even with the fuz at 32 oz. I would not throw away that fuz. I suppose if you are not going to use it, I sure will take it off your hands
< Message edited by rgreen24 -- 3/29/2006 3:03:32 AM >
       Post #: 36
RE: Defiant MKII - 3/28/2006 7:03:53 PM
tschmidt
Status: offline
Just a note to say thanks to everyone for information and comments on this thread. It's great to get the help I need so quick. I know the weight could be better on this fuse and will be laying another up this weekend.
Whats encouraging is the information I've gotten from some friends. It seems this weight isn't to far off from a lot of fuselages on the market. My brother has an Impulse @ 31.5oz and another friend's Temptation fuse was the same. These planes are being built well within the weight as Robert states. Sorry Robert I'll probably build this fuselage.
Thanks again everyone!
Todd Schmidt
       Post #: 37
RE: Defiant MKII - 3/29/2006 4:24:16 AM
dflynt
Status: offline
Todd,
If I remember correctly, the PL Partner was 19 ounces for bare fuse, canopy, chin piece. It felt unbelievably light for its size when I held it in my hands. However, the honeycomb pipe tunnel and internal formers, stab tube, firewall started increasing the weight. The ready to paint weight with everything on it, wing tube supports, all the things I mentioned was 830 grams, or about 29 ounces. As light as it is, it is not a fragile product. The ready to fly weight of this plane with DZ 140 is 9.75 pounds. My ZNline Supreme fuse was 859 grams ready to paint, but the final weight with OS 140 RX is 9.0 pounds. The paint, covering, landing gear, and engine setup contributed to the lighter final weight. I hope this is useful information for comparison.
Your mold is a work of art. I am very impressed.
David
< Message edited by dflynt -- 3/29/2006 4:26:14 AM >
       Post #: 38
RE: Defiant MKII - 3/30/2006 2:34:52 AM
Bob Hartwig
Status: offline
Hello Todd,
Your plane is looking Bodacious!. Great workmanship and effort. The couple of tweaks in the next one should be awesome. I weighed my Prestige (electric version) and it is 28.10 ounces with firewall and landing gear plates in.
Bob
Bob Hartwig
NSRCA 41
       Post #: 39
RE: Defiant MKII - 3/30/2006 4:09:01 AM
wilga12
Status: offline
Say Todd.................................Dave here.
quote:
1. A surface coat was put down first, which is a thick epoxy based paste I tinted green. Dark colors help you see air pockets when making parts. The surface coat provides a inside mold surface that is slick, shinny, and almost ceramic like.
Would I be able to use my West systems #105 resin (Which is an Epoxy finish resin) to make this Paste that you have made here..?? If so, what was the material that you used for the thickiner and the tint..?? And unless I missed it, you didn't say just how much glass/resin went over the first half of the plug to form the mold, before you flipped it and went on to the second half..??
And do you get most of your materials off of the net..?? I don't live close to a town of any real size,so I'm guessing that I will have to.
Last but certainly not least, Thank You so much,for providing "Newbies" like myself with a blow by blow series such as this. I now, really, understand the old line "That a picture is worth a thousand words"..!!
Kudos..................................Dave
Life happens between full and empty......No??
Brownsville,Oregon
       Post #: 40
RE: Defiant MKII - 3/30/2006 6:57:34 PM
tschmidt
Status: offline
Thanks David and Bob for your comments and weights. I've definitly have something to shoot for as far as weight is concerned.
Dave, The surface coat I used while making the molds is available from www.fibreglast.com and is a thick epoxy paste mixed 100 to 11(by weight) with its catalyst. You can also by the tints from there also. The surface coat is a better solution to using thickened resin although a lot of people will use thickened resin as a surface coat.
After applying the first coat of surface coat, I let it dry till its hard, but yet tacky (takes about 2 hrs) . I then apply the
