Defiant MKII
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Defiant MKII Page: [1] 2 3 4 5 6 7   next >   >>
Login
Defiant MKII - 2/5/2006 2:57:42 AM
tschmidt
Status: offline
Here's a few pictures of my Defiant MKII. I've been working on this mold plug for the last 3 or 4 months. It still needs a little work but the molds should be done sometime this month. Hopefully I'll have one flying by June or July.
Todd Schmidt
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Defiant MKII - 2/5/2006 2:25:57 PM
flyintexan
Status: offline
That's beautiful work.
_____________________________
www.insightrc.com
(in reply to tschmidt)
       Post #: 2
RE: Defiant MKII - 2/5/2006 3:35:50 PM
papaone
Status: offline
Hi
I like the design.
Awesome 'll be this plane.
A+
(in reply to flyintexan)
       Post #: 3
RE: Defiant MKII - 2/5/2006 4:21:26 PM
byoung466
Status: offline
Awesome work as usually Todd. You'll have it done just in time for the NATS......
Brian
(in reply to papaone)
       Post #: 4
RE: Defiant MKII - 2/5/2006 4:38:41 PM
tschmidt
Status: offline
Thanks guys for you comments!
Hey Bian, good to hear from you, Still have a lot of work to do, might have one by NATS time. . . but probably not enough air time for proper set up. I'm looking forward to see how this one will compare to the current design I'm flying.
Todd
(in reply to byoung466)
       Post #: 5
RE: Defiant MKII - 2/5/2006 5:20:28 PM
MHester
Status: offline
Wow that looks SWEET Todd! I hope you bring it to the Nats this year.
-Mike
Team Cool Power, YS Parts and Services, Mercury Adhesives, Dragonfire Customs, owner Custom Airframes of America
       Post #: 6
RE: Defiant MKII - 2/17/2006 2:49:02 AM
tschmidt
Status: offline
The plug is ready to make a mold of. A few pictures of the parting plane for the first half of the main fuselage mold, and the main fuselage fitted into the parting plane. This is where you conclude you have a straight fuselage. Happy to say the fuselage centerline is dead on from the nosering back to the tail post. Now its time to wax/polish the plug to a class A finish and putty it into the parting plane.
After that, HOURS of back breakin fun begin!!
Click for fullsize
Click for fullsize
(in reply to MHester)
       Post #: 7
RE: Defiant MKII - 2/17/2006 3:11:52 AM
mups53
Status: offline
Thanks for the update. I've never seen the step by step process of making a mold and laying up a fuse. Very interesting. Mike
       Post #: 8
RE: Defiant MKII - 2/17/2006 3:36:50 AM
rgreen24
Status: offline
As Usual Todd, you do great work. I can't wait to see it.
(in reply to mups53)
       Post #: 9
RE: Defiant MKII - 2/26/2006 5:28:25 PM
tschmidt
Status: offline
A few pics of the first half of mold construction.
1. A surface coat was put down first, which is a thick epoxy based paste I tinted green. Dark colors help you see air pockets when making parts. The surface coat provides a inside mold surface that is slick, shinny, and almost ceramic like.
2&3. First half of the mold removed from the parting plate. Now its time to wax and polish the flange in preparation of making the second half.
Todd
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tschmidt -- 2/26/2006 5:30:51 PM >
(in reply to rgreen24)
       Post #: 10
RE: Defiant MKII - 2/27/2006 3:02:48 PM
checksix
Status: offline
Todd,
Beautiful craftsmanship. What materials do you use to build the plug? Hot-wired foam? Strip planking?
--Derek
       Post #: 11
RE: Defiant MKII - 2/27/2006 6:22:31 PM
tschmidt
Status: offline
Hi Derek,
Thanks for your comments,
The plug is made from balsa and polyurathane foam. The plug started as a main box framed from balsa (front end of the canopy hatch to the tail post) The nose, fin, canopy, chin, top and bottom decks were shaped from poylurathane foam. All was glassed then primed with a catalyzed polyester primer.
I've completed first half molds on all three parts, hopefully be done building molds by next weekend. I'll keep the pics coming as the project progresses.
Todd
(in reply to checksix)
       Post #: 12
RE: Defiant MKII - 2/28/2006 2:54:06 AM
Clavy
Status: offline
A Birdy told methat you were going to sell fuselages and patterns for $50.00. Is that true? I'd like to order a couple .
       Post #: 13
RE: Defiant MKII - 2/28/2006 3:08:39 AM
tschmidt
Status: offline
Clavy,
You must of talked to a turd bird!
Todd
(in reply to Clavy)
       Post #: 14
RE: Defiant MKII - 3/1/2006 4:47:31 AM
PatternPilot
Status: offline
Todd,
Sent you email thru rcu
Scott Anderson
NSRCA D3 AVP
Team Tanicpacks.com
Team PMA
       Post #: 15
RE: Defiant MKII - 3/5/2006 11:18:38 PM
tschmidt
Status: offline
Well, after about 30 hours and 3 gallon of epoxy the molds are finally done!! They came out really good. It's time to wax these puppies up and make an airplane!!
Todd Schmidt
Click for fullsize
Click for fullsize
Click for fullsize
