HiTec Rx 750 mAh NiMH pack
Tower Hobbies
Logged in as Guest
  Printable Version
JR 12X Transmitter only
Seller:  BAGOSTIX
Details:   $1,300.00   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HiTec Rx 750 mAh NiMH pack
Page: [1]
Login
HiTec Rx 750 mAh NiMH pack - 2/10/2006 1:56:00 PM
Nickolas
Status: offline
Hi,
I recently purchased a Rx HiTec 4s 750 mAh NiMH pack, the individual cells are made by GP they are 2/3 AA size. Can you please suggest how to charge this pack, what C rating? The minimum my charger can give is 100 mAh. Also will the discharge current be enough for 4 standard sized analogue servos plus one mini for throttle? The model I will use this pack is a 40 size 3D model. Is this pack ok for the application?
Looking forward to replies,
Nick
_____________________________
Please check my blog:
http://nikolas-3djunk.blogspot.com/
       Post #: 1
RE: HiTec Rx 750 mAh NiMH pack - 2/14/2006 3:31:19 PM
mglavin
Status: offline
Trickle charging 100mA is fine. Trickle charging is generally C/10. Typically you can charge this type of battery at C2. 750mA/1000=.75A C2 x.75= 1.5A. However, I would not suggest anything more than one amp specifically with a "peak" charger.
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to Nickolas)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.285RCU5
