mvvs grrt engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> mvvs grrt engine Page: [1]
Login
mvvs grrt engine - 11/29/2002 8:49:55 PM
shawn quintin
Status: offline
looking for any info on this engine,just ordred it for an open class formula one plane. (not for compitition just like to fly fast)props fuel anything you thing i should know.
       Post #: 1
mvvs grrt engine - 12/7/2002 1:00:21 AM
SSAN
Status: offline
Shawn,
I guess I'd have to help you out since no one has reply yet.
Anyhow... for the GRRT FAI .40 Pylon engine, it should be run with a pipe and there are several different size props you can use. However, depending on the plane and weight, you may have to experiement with these recommended props.
Try APC 8x6, 8x7, 8x7.3 D-1 Hub, Carbon Fiber 7.5x7-7.5 and APC 7.4x8. With these props you will know what's best for your plane. I've used mostly the 8x7 or 8x7.3 on my Quickie plane and my GRRT .40 turn over 22,000+ (which is low due to load) on the ground, but when it unloaded in the air... it's scream!
As for the fuel and plug... I used 15% nitro and McCoy #9 cold plug. Although, you can run the alcohol or 5% nitro with good result. Hope this help a little.
Sam
< Message edited by SSAN -- Dec 13 2002 9:45PM >
_____________________________
SAM-RAI... The Ultimate WOOD Q-500!
www.Sam-RaiRacing.com
(in reply to shawn quintin)
       Post #: 2
mvvs grrt engine - 12/8/2002 12:11:34 PM
SSGSPEEDMAN
Status: offline
Hi now is this Q500 plane have a MVVS Q-500 .40 OR NElSONOR
. It cause I need alot of help with my engine. If you can help I
apree/she/ate it you could help me.
thanks . speedman
       Post #: 3
mvvs grrt engine - 12/14/2002 2:52:27 AM
SSAN
Status: offline
Hi Speedman,
The engine that I used with the Quickie plane is a MVVS FAI GRRT .40 with a tuned pipe (not Quickie 500 engine). It's timed for high rpm and tuned pipe use.
What kind of help do you need with your engine?
Sam
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.343RCU1
