36% KATANA PULL-PULL EXITS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> 36% KATANA PULL-PULL EXITS
Page: [1]
Login
36% KATANA PULL-PULL EXITS - 2/11/2006 3:55:55 AM
storklappe
Status: offline
Mark,
Can you tell me the measurements for the center of the rudder pull-pull exit holes in the 36% Katana fuselage?
Some time ago, Rocco gave me the following measurements: from the back of the fuse, the slot center is 10.5" and the slot center up from the fuse bottom is 3.75". The problem is, if I make the hole up 3.75" from the bottom, the straight line back to the rudder will take the cables above the rudder hard points.
       Post #: 1
RE: 36% KATANA PULL-PULL EXITS - 2/11/2006 4:02:21 AM
Mark Dennis
Status: offline
Ok just went to the basement to measure mine the exit is 10.5 and 3.25 this should locate the horn on the hard piont. Let me know if it still won't line up.
_____________________________
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to storklappe)
       Post #: 2
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 12:20:32 AM
storklappe
Status: offline
Thanks Mark. I really appreciate your help!
Are the measurements you gave to the center of the slot?
Thanks!
(in reply to Mark Dennis)
       Post #: 3
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 4:14:12 AM
Mark Dennis
Status: offline
Yes they are towards the center and you can also move it down a little if you need to in order to get it just right.
Team Aeroworks
       Post #: 4
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 4:32:26 AM
treedog
Status: offline
may i ask what is the purpose of a pull-pull system and why is it even neccesary as im not into 3d yet and dont know how it all works
       Post #: 5
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 5:33:02 AM
Mark Dennis
Status: offline
Mainly it is to help balance the plane. Some will mount the rudder servo(s) in the tail if they can get it to balance. Either way works and really dosen't have anything to do with 3D.
Team Aeroworks
(in reply to treedog)
       Post #: 6
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 5:40:16 AM
storklappe
Status: offline
Thanks again Mark!
I have been worried about cutting the slot in the fuselage because I don't know if I'll be able to get the cable to come out the center of the hole without rubbing the top or bottom.
       Post #: 7
RE: 36% KATANA PULL-PULL EXITS - 2/12/2006 3:27:16 PM
Mark Dennis
Status: offline
What i did was i took a tub and but it right where it exits so it dosent rub on the wood.
Team Aeroworks
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
