E_Heli
CA, USA Status: offline
GTX SlotCar, Eclipse7 on Blade CP: Refer to the manual in the Heli section. Since Eclipse has the ACRO, GLID and HELI function, you have to program the Eclipse in the Heli mode,activate the 120 CCPM, you can forget the idle up, pitch curve and throttle curve for the time being and use the default one, make sure the "Ft Mode" switch on the left top corner and the "Ft Cond" switch on the right top corner is all the way back for NORMAL flight. 1, unplug the main motor and tail motor from 4 in 1 2, remove all 3 servo arms from the servos to prevent servo gear stripping when the Rx initialize since they may not in the neutral position. 3, in order for the Blade 4 in 1 to initialize, throttle channel should be at Normal position, move the throttle trim to -30 or more, if it does not work, then you have to adjust the end point adjustment (EPA) of the throttle channel, try extend the end point adjustment to 125. 4, once you get the solid green light, you can test the main motor and tail motor control.
