credence
ON, CANADA Status: offline
GTX Slotcar, you should not have any problems with the charging. Trickle chargers don't really need anything special as the charge rate is so low that it would not damage the battery even at peak. Delta peak cutoff is only really needed when you're speed charging your NIMH cells, where they can get damaged easily. Also, if you want a "full" charge for your NIMH cells, slow charging is the best way to do it, as it balances each cell to give you top voltage, aswell as the fullest charge. Delta peak isn't always very accurate, and it can trigger before NIMH cells are actually full. Speed charging is nice (and in some cases, benificial for topping packs off before a flight), but you should always cycle your cells using a slow charge after every few speed charges to ensure they stay in optimal condition. Edit: I should probably mention that trickle charging for LONG periods of time WILL damage NIMH cells. Aslong as you don't leave the battery on trickle charge for a week you're fine.
< Message edited by credence -- 3/9/2006 11:11:00 PM >
_____________________________
Daniel True Northern Hobbies, Inc.
