SHOULD I "SEAL-OFF" THE FUSELAGE?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> SHOULD I "SEAL-OFF" THE FUSELAGE?
Page: [1]
Login
SHOULD I "SEAL-OFF" THE FUSELAGE? - 2/13/2006 8:29:12 AM
storklappe
Status: offline
Hi Mark,
I am not using cannister mufflers. Should cover the inlet to this area so the fuse is sealed?
Thanks!
       Post #: 1
RE: SHOULD I "SEAL-OFF" THE FUSELAGE? - 2/13/2006 10:21:34 PM
Mark Dennis
Status: online
Yes i did it just so no oil would leak into the fuse. I just used some covering on mine so it added little to no weight.
_____________________________
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to storklappe)
       Post #: 2
RE: SHOULD I "SEAL-OFF" THE FUSELAGE? - 2/13/2006 11:22:06 PM
storklappe
Status: offline
Mark,
I can't thank you enough for your help!
My next plane is going to be your 260. How does it fly compared to the 36% Katana?
Thanks again!
(in reply to Mark Dennis)
       Post #: 3
RE: SHOULD I "SEAL-OFF" THE FUSELAGE? - 2/13/2006 11:35:42 PM
Mark Dennis
Status: online
Well that is a very hard question to answer. The 260 is lighter than your Katana so that is a large part of it. For sequence flying I prefer the 260 as it has very little if any coupling and is lighter which means a better power to weight at my alltitude at sea leval you will have planty of power with both planes. I really like my Katana for 3D and all around fun which is why i am going to keep it together even after i finish the 260 and yak. So really if i had to pick one it would be the 260 since it will 3D and to imac like no other plane i have flown before.
Team Aeroworks
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.750RCU1
